BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > DIY Guides/ Discussions
European Auto Source (EAS)
      08-17-2020, 06:58 AM   #23
Helmsman
Helmsman's Avatar
Sweden
4489
Drives: 2011 AW E90 M3 ZCP
Originally Posted by da jemster View Post
Thx again Theodore ! I was able to move the driveshaft out of the way, without uninstalling the guibo, when I dismounted the CSB carrier. And yes, I marked the position of the 2 screws before dismounting :-)
And...I learned a hard lesson - NEVER, NEVER lower the tranny when you don't have the engine on its mounts and only having it hanging by the single lift hole by the passenger side. As I lowered the DCT and as I was inspecting the Mechatronics, I didn't realize it swung so far out and was pressed against the passenger side of the tunnel. I lifted the tranny back up but it was so cock-eyed leaning to the passenger side. So I decided I need to put back the subframe, hoping it would straighten it out. Unfortunately, I couldn't line up the subframe to the chassis because it was off as much as 6 inches! It took me a couple of hours, a Harbor Freight engine jack holding the tranny, 3 different jacks to line eveything up again...all on my back.
Jeez, that sounds like a scary experience before you managed to get it back in place!
      11-08-2020, 09:13 PM   #24
WayneM3
Drives: F90M5
I did this job today and it was VERY difficult to get the new o-ring back on and I had the complete driveshaft, guibo and transmission mount all off.
My center support bearing was completely shot and torn about 80% of the way around so while everything was out I decided to change the o-ring.
I had all kinds of crap up there that came out when cleaning it but even with my head up in there I still couldn't actually see much of anything other than the bolt that holds everything together. Getting the old o-ring off was just a little difficult but not terrible but getting the new one on was extremely difficult. You can only have one hand in there, can't see anything and getting it over the little arm where the screw goes took a long time. The replacement gasket I got from the BMW dealer was not directional and there definitely was not a thicker or taller side - it was the same both ways so I hope it is in there correctly. It was also black where the one that came out was red. I had the transmission brace fully off and the transmission didn't tilt down much, if any, so maybe one of my supercharger parts was blocking/holding everything from tilting back - probably the hose from the intercooler part to the manifold. With the transmission out it would take 5 minutes and I would have been able to do the side cover gasket at the same time so that is what I would do if I had to do it again.
I am very good at working on cars and had it on a lift and every tool I could possibly need available and still had a tough time - this isn't for the faint of heart. The rest of the driveshaft, flexdisc, center bearing, etc. was pretty easy. I had planned on doing the bottom pan and fluid too but the o-ring took so long I didn't feel like doing any more so I put everything back together and will change the pan at a later date (that is much easier to get to - don't have to remove much at all).
DrFerry6734.50
      11-11-2020, 12:42 AM   #25
kyippee
kyippee's Avatar
Drives: E92 M3, Supra MK5, F44 235GC
reading these latest posts makes me glad the shop I go to did it without any complaints. I asked them if it was difficult... they basically said it wasn't a problem at all!
We were doing trans + diff + subframe mounts, as well as the guibo at the same time, so maybe that made it easier
      11-11-2020, 08:22 PM   #26
da jemster
da jemster's Avatar
78
Drives: E46 M3,E93 M3,F22 M235i,i1 i3
How's your DCT pan? Bone dry?
'04 E46, '08 E93, '16 F22 M235i, '17 i01 i3
      11-12-2020, 01:04 PM   #27
kyippee
kyippee's Avatar
Dry so far! There was a tiny little bit of fluid that looked like it came from that mechatronics O-ring. Otherwise the slon bottom and side pans seem to be doing well.
      12-31-2020, 05:01 PM   #28
DubSport
DubSport's Avatar
Drives: 2008 E92 M3
I'm doing rod bearings right now (well over the course of the next two to three weeks) and discovered leaking from this top O-ring. Does the fact that I have everything disassembled right now for the rod bearings - engine is suspended, subframe about to come off, etc., help me in any way to access this top mechatronics O-Ring? Or am I better off to finish the rod bearing job, put subframe back on, then follow the original post instructions?
PS. huge thanks to this thread - seems like it could save me hundred$ in avoiding a fluid refill and side/bottom gasket swaps.
      12-31-2020, 06:36 PM   #29
da jemster
da jemster's Avatar
78
Replied to your PM.
      01-13-2021, 07:50 PM   #30
Genes1s
Genes1s's Avatar
33
Drives: 1997 E36 M3/4/5. 2011 E82 135i
@Theodore and anyone else did this, when you re installed the drive shaft to DCT output shaft, did you have to do any preload on the flange?
I'm having a leak on my output shaft and tempted to drop the tranny and do all 3 seals (top, side, and side) at the same time.
Thanks
1997 Artic Silver E36 M3/4/5
2000 Sunlit Sand Nissan Maxima 5 SP
2011 Space Gray E82 N55 DCT.
      01-13-2021, 10:45 PM   #31
Theodore
Theodore's Avatar
Drives: 2011.5 E92 M3
Thanks
The BMW TIS doesn't provide any pre-load information for the driveshaft, so just try to place the center support bearing bracket back into the same location as it was placed originally at the factory.
What I Wish I Knew When I First Bought My E9X M3 Can Be Found Here
E9X M3 Exact Original Equipment (OE) Equivalent Parts Can Be Found Here
E9X M3 Common Torque Specs Can Be Found Here
E9X M3 "Factory" Tools Can Be Found Here
      01-14-2021, 12:50 AM   #32
Genes1s
Genes1s's Avatar
33
Sorry, I probably said it wrong. I meant Item #3 Flange Nut. I guess I could still mark the nut and flange together for reference when you put it back together?
      01-18-2021, 11:25 AM   #33
Theodore
Theodore's Avatar
You should create a new thread about that question to get more views. You'll need someone with BMW TIS access to check for you. If no one responds you can pay for access here. Be careful as I know for some other BMW models the torque spec for that flange is a two stage process, first a very high torque is applied, then it is loosened and then a lower final torque spec is applied.
      03-03-2021, 08:59 AM   #34
EDWYER
Yoda of mods
EDWYER's Avatar
1679
Drives: X5 RWD
2015 X5 RWD  [0.00]
2016 BMW M2  [10.00]
Good info.
Theodore673.50
      11-01-2022, 03:19 PM   #35
DrFerry
Field Marshal
DrFerry's Avatar
Drives: '08 E92 M3
2008 BMW M3  [5.25]
2015 BMW X5  [4.50]
Oldie but goodie.. for newbies.
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
Dpc2u11503.00
      04-12-2023, 01:16 PM   #36
spxxx
Boost
spxxx's Avatar
1355
Drives: 135i M-Sport
Talked to my local performance shop and they mentioned that you need to pull a release mechanism from inside the DCT itself (pull off lower oil pan) to release the mechatronics sealing sleeve. Has anyone heard about this process? They made it sound risky pulling the top sleeve out to replace the o-ring without using this release as it could damage the internal connections? I'm a pretty handy DIY but don't have a ton of time for an intense DIY. (I have a lift which helps).
      04-16-2023, 11:41 AM   #37
Theodore
Theodore's Avatar
The DCT in this model has a more maintenance friendly design with the external screw and bracket. What the shop told you is true for many DCT transmissions used by BMW as the mechatronics sleeve is normally locked in place by an internal connection and released from inside the DCT usually by removing the lower DCT pan, but for the E9X M3 it is not true. For this DCT it is held in place by the external screw shown in the photos above. This is a difficult DIY and you need very long arms to reach it if you don't remove the transmission or the engine to gain better access. I would maybe try to find a shop that is more knowledgeable about this job specifically for the E9X M3 so they give you an appropriate repair quote.
DrFerry6734.50
      05-09-2024, 11:08 PM   #38
active_m
Drives: E92 M3
Originally Posted by Audioslave686 View Post
that's doubtful.
I just finished that DIY (it was not fun at all)
you can only lower the transmission for about 2 inches.
that's definitely not enough to get to the whole side cover
Actually, it's really easy to do this with the DCT hanging a bit you have enough room if you use a 1/4 ratchet with the correct bit... I did mine this way and it only takes about 10 minutes.
      05-11-2024, 05:12 PM   #39
spammysammich
spammysammich's Avatar
1627
Drives: 2009 E92 M3 Dakar Yellow II
2009 BMW M3  [10.00]
Can you please outline the process you used to tilt the transmission enough to gain access?
m3post
