04-09-2022, 08:39 AM | #2 |
Rep 1,550
It is a very simple retrofit for you. Depending if your vehicle have the proper camera already or not. If it does, all you need to do is add 8TH to your vehicle. If it doesn't, you will need to swap camera and then code.
To check if you have the proper camera, open the plastic cover for your rear view mirror. It should look like the attached photo. |
07-08-2022, 07:59 PM | #3 |
BAD-F85
24
Rep 88
Can Bimmercode add 8TH or does it have to be done via e-sys?
Also, would this camera then allow for lane change, etc? I'm also guessing that this would require other coding? |
07-09-2022, 10:10 AM | #4 | |
Rep 1,550
You will need the following: Windshield (to mount camera w/heating) KAFAS2 module Wire harness Camera Driver Assist button Dashboard (if you want to mount the button properly) FSC certificates Vibrating motor and control unit Clock spring (if you don't have the right one) Rear view mirror, duct and cover |
