2010 2011 BMW 5 Series Forum F10 BMW 535i f10 (2010) engine issues |
12-24-2022, 08:49 AM | #1 |
Rep 3
Hi guys I was hoping somebody in this forum might have encounter or fix a similar issue to what I’m facing.
Recently I got a 535i and did all this wear and tear fixes. Valve Cover Set BMW Timing Chain Set BMW Camshaft Sprocket x 2 BMW Oil Pump Chain Set BMW Oil Pressure Valve BMW Valvetronic Sensor BMW Solenoid Switch O-Ring x 4 BMW Mickey Hose BMW Main Seal + Cover BMW Front And Middle Undercarriage Cover BMW Fan Belt and Fan Tensioner Set OEM Suction Door Soft Close Motor OEM Rear Differential Oil Ignition Coils eldor and ngk -2 step colder plugs Turbo Oil Return Pipe Coolant Tank Coolant Tank Cap Oil Filter Housing & Oil Cooler Gasket Oil Sump Gasket with Screw Set + 8L Monsil Pure Boost 5W40 Engine Oil with Filter Transmission Oil and Oil Pan Rear Differential Oil Current running on bootmod stage 2 93 octane mapping. So basically what I’m encounter now is that when I’m on neutral gear and I step on the accelerator slowly when needle hits 2000rpm - 2500rpm I get a some sort of engine knocking sound. Like something came lose, but when driving everything is smooth no problems whatsoever. Also after excessive heavy driving we talking about sports + mode and lots of high rpm’s from 0-100 the engine will shut down when the car comes to a complete stop only at a complete stop but amazingly no fault code or error code comes with it and I just start the engine again and I can start driving, engine is flawless for daily driving btw it doesnt die on me. I have a video of it and will post it here for you guys to take a look. Hoping somebody can shed some light. Cheers. Click here to see the video : click here |
12-24-2022, 10:21 PM | #4 |
Rep 5,409
