2010 2011 BMW 5 Series Forum F10 Turn off auto ON AC when turing ON car |
08-22-2017, 11:13 AM | #1 |
Rep 697
Hate it when the AC is ON when I turn on the car. Even if i turn off before turning OFF car, it still turns ON to slow speed when ignition is ON.
Is there a way in iDrive or Coding to disable this? Am i missing something? |
08-22-2017, 12:03 PM | #3 | |
Rep 697
Where/how can I code this? http://support.mycarly.com/knowledge..._campaign=home |
08-22-2017, 02:14 PM | #4 |
Rep 107
IHKA Module:
A/C System Remembers Last Setting 3000 OFF_MEMORY set to aktiv Iam not sure for Carly but with standard coding with esys is possible. |
08-22-2017, 08:31 PM | #5 |
Rep 479
I kinda have the same mental issue u have. I sometimes hate it too. Lol
try to turn off the AC about 5min (while driving home) before turning off the car. I noticed if I turn ac off then ignition off it won't consider that a command.
LeXxiNGToN aka LeXxDiAMoNDS
08-23-2017, 07:33 AM | #6 |
Rep 1,876
Not to nitpick - it's important to separate "the AC" (the snowflake) from the entire HVAC system when getting into specific coding. I'm not trying to be a jerk, but coding is "nitpicky". When you say "the AC always comes on", when I read it I'm not certain whether you mean the snowflake, or the system.
It drives me nuts that all the newer bimmers (mid 2000s+ at least) are always turning on the snowflake in auto mode. On my E39 the system was fully automatic (if you chose) but it was always up to the driver whether to turn on the AC (snowflake) or not. That's how I want my cars to behave... The coding functions to remove "constant snowflake" are different from those to stop the HVAC system from turning on when the car is powered after a full sleep cycle. In my case, I have also coded IHKA > 3002 Funktionskodierung_HO, 06 > AC_NICHT_EIN_BEI_AUTO. I don't have all my notes with me but I think that's the appropriate one. |
08-24-2017, 08:09 AM | #7 |
Rep 697
Thanks guys. Based on the feedback, sounds like I need to be able to code within the IHKA module.
I am referring to the "snow flake" (AC ON). I have noticed the same nuisance on other BMWs, this is the first BMW I have owned that also has this nuisance. Basically, I don't like starting the car with unnecessary load (AC compressor ON), etc. and many days I don't want to use my AC at all! |
08-24-2017, 03:42 PM | #8 | |
Rep 1,876
The OFF_MEMORY quoted by someone else will allow your HVAC to be fully off and remember that state on next restart. Honestly this is how I often drive my F10 when just doing commutes to the train station - the HVAC never comes on. This means my water pump doesn't even run allowing the engine to warm up extremely quickly despite the fairly short trip. I know it's not the life for everyone but in a lot of cases it's just fine for me - open the window when it's warm out and no big deal. |
08-25-2017, 07:42 AM | #9 | |
Rep 697
The snowflake light will never be ON if the fan is off. The snowflake light is always lit with the fan being set at low speed minimum. I do not want to run the fan only with snow flake off either. I want fan off (snowflake light is off since fan is off). Thanks, |
08-25-2017, 08:32 AM | #10 | |
Rep 1,876
The OFF_MEMORY coding does not affect the way the system always wants to turn the AC (snowflake) on. You'll need my other coding value for that. I still haven't found IHKA coding which will completely disable AUTO AC (snowflake). In certain humidity conditions, the IHKA will still turn on the AC compressor without illuminating the snowflake button. This is a feature meant to keep your windshield from fogging up, but I'd still rather it didn't do it. Sometimes I've been driving with the windows down on a warm summer night and suddenly it's blasting icy air at me and I have no way of turning it off. When I coded my E90, I believe that one setting stopped both behaviors. |
08-25-2017, 11:21 AM | #11 | |
Rep 697
10-16-2020, 12:40 PM | #13 |
Rep 104
Trying to do this on my 2016 BMW X5M, is there any other app or scanner that can do this? Seems this Carly app is $85 per year, i have other basic scanners but only looking to disable this feature.
Thanks, Frank |
10-16-2020, 01:16 PM | #14 |
Rep 5,409
10-17-2020, 03:22 PM | #15 |
Rep 639
A laptop running ESYS and a $20 ENET cable will let you do coding modifications.
10-12-2022, 01:05 PM | #16 | |
Rep 1
Surly73
Hello Surly73, I have the same problem with my BMW, " In certain humidity conditions, the IHKA will still turn on the AC compressor without illuminating the snowflake button" Did you find a solution for this issue ? Any coding ? Thank you! Quote:
10-12-2022, 02:31 PM | #17 | |
Rep 1,876
Sometimes on summer evenings when I'm driving around with the windows and roof open if I turn the system on at all (just wanting some air movement) I get air conditioned air and no snowflake light. I suppose maybe some time I'll get to exploring again to see if I find anything. I thought I had it completely stopped in my E90... EDIT: Found with google on the "other" forum: Code:
3001 Funktionskodierung (Function coding), 29 BESCHLAGSVERMEIDUNG (FITTING AVOIDANCE??) (fogging prevention) AKTIV (Active) = 01 (default) Comment = OPTIONS NICHT_AKTIV (not active) = 00 AKTIV (Active) = 01 changed to nicht_aktiv 3001 Funktionskodierung (Function coding), 29 KMV_AKTIV_BESCHLAG (KMV ACTIVE BRACKET) (fogging prevention) AKTIV (Active) = 01 (default) Comment = OPTIONS AKTIV (Active) = 01 NICHT_AKTIV (not active) = 00 changed to nicht_aktiv Given my personal preferences, I never want the IHKA to turn the AC compressor on for me EXCEPT if I touch the front defrost button (full fan, full heat, AC on, windscreen vents only). Right now my use of AC_NICHT_EIN_BEI_AUTO means I need to hit defrost + snowflake to get this function now. I don't know what effect these "fogging prevention" codes might have on how it behaves. It would be really sweet if I could dial it in... Last edited by Surly73; 10-12-2022 at 02:51 PM.. |
