2010 2011 BMW 5 Series Forum F10 Importance of dynamic damper control |
04-26-2012, 12:33 PM | #1 |
Rep 2,312
So I've searched a lot and there are many threads on this issue but none that address driving feel. I have a chance to spec dynamic damper control without ARS on a 535xi, I know what dynamic damper control does in theory but I'm wondering does it really make your suspension feel sportier/is the drive sportier when the dampers tighten up?
I'm having trouble finding a demo model at the dealer with just DDC. So for those who have it, does it give the car more of a sports suspension (ie. tighter?)? That's what I'd be looking for. |
04-26-2012, 12:53 PM | #2 |
Rep 6,842
It makes a huge difference. If you are not in a location to order the MSport suspension that does not have adaptive dampers, then this is a must if you want any kind of sportiness.
04-26-2012, 02:56 PM | #3 |
Rep 1,346
Drives: 2011 E92 335 M-Sport
It's not only DDC. In order to get DDC you have to have the sport package, which means 19 inch tires. The driving feel (ride and steering) is completely different from non DDC cars with 18 inch tires. If you have a sporty inclination, it's a must.
04-26-2012, 02:56 PM | #4 |
Rep 1,430
Drives: '23 i4 M50, '15 M3, '18 911
I can't really compare a car with DDC and without. I ordered my car with DDC and I can tell you that it definitely tightens up the suspension going from Comfort to Normal to Sport. (Now it's called Comfort+ to Comfort to Sport)
04-26-2012, 03:21 PM | #5 |
Rep 2,312
I can order it separately in Canada for the 535 xdrive - In fact I can only order DDC. Not the other ARS option.
So there is a handling difference then. I want the car to tighten up and feel smaller, exhibit a little less body roll etc |
04-26-2012, 05:09 PM | #6 |
Rep 1,312
I believe it also alters the engine dynamics with different shift points. I have it on my 535xi and it seems to run at higher rpm. I believe you can turn off the engine characteristics in the idrive
04-26-2012, 10:31 PM | #7 | |
Rep 41,229
Drives: 2018 Alpina B6 650ix GC
DDC though is Dynamic Driving Control, which adjusts the damping rates of each wheel independently with control modules on each wheel that automatically adjust the shocks. "A control unit on each wheel evaluates movements four hundred times a second and adjusts the shock absorbers accordingly. The electronics system works so fast that when the front wheels encounter a pothole, information is sent to the rear wheels so that sufficient cushioning is in place. The rebound and compression damping are continually and independently set to end the need for compromise which means that the dampers adapt to the state of the road irrespective of which Dynamic Driving Control mode is selected, for exceptional ride comfort even when driving hard on bumpy surfaces."
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
04-26-2012, 11:33 PM | #8 | ||
Rep 133
I was under the impression that the M-Sport version had some kind of suspension difference to a non M-Pack? I guess this explains why I'm missing the Comfort+ and Adjustability in Sport mode!? During my test drive my sales guy told me that switching to sport mode hardened the suspension? |
04-27-2012, 03:44 AM | #9 |
Rep 205
shawnsheridan has done an excellent job of describing it.
The M-Sport does have a different suspension setup from the Standard 5 series it is a harder (Sportier) ride and I think a little lower but it is not electronically adjustable. There is an option to delete the M-Sport suspension on the M-Sport cars at least here in the UK. My personal opinion on whether you should order the DDC Dynamic Damper Control is that it depends on how you like to drive. I also have a Ford Galaxy MPV fitted with DDC (Very similar system to the BMW) it has 3 settings, Comfort, Normal and Sport and yes you can tell the difference between them but for 99% of the time I have it in comfort mode. So when I purchased my new M-Sport I decided t0 spend the money of the DDC on other options instead. Having driven the M-Sport now for 6K Miles I am very happy with my decision as it handles very well on the standard suspension. But then I only occasionally have fits of fast driving. I guess this is why its an option. |
04-27-2012, 08:24 AM | #10 |
Rep 112
If you are in the US, the Dynamic Damper Control comes standard with the Sport Package or the M-Sport Package. Not sure about other markets. If you are looking for a more sporty drive, I'd definitely spec it. I have yet to read any reviews of the 5 series with sport suspension being too stiff.
04-27-2012, 10:09 AM | #11 |
Rep 2,312
Hmmm...next question is how reliable do you think these dynamic shock absorbers would be over 10 years? I want to keep the car for that long. If they are anything like an air suspension, I'd rather go without them/upgrade to kw v3 later. I wonder what the engineering is behind them
04-27-2012, 10:18 AM | #12 | |
Rep 205
04-27-2012, 08:02 PM | #13 | |
Rep 6,842
Volvo S60R and V70R owners have been running adjustable shocks (by Ohlins / Monroe) since 2003 as part of their 4C suspension (Continuously Controllable Chassis Concept). They have been very reliable (the shock / strut units themselves). Sensors and accelerometers were more common failure points, but there were very, very few shock failures. |
05-18-2012, 04:27 PM | #15 | |
Rep 33
05-20-2012, 05:04 AM | #16 |
Rep 1,544
Anybody have experience on the passive M-sport suspension on the F10? In terms of sportiness how does it compare to DDC & also to the standard passive setup?
05-20-2012, 08:19 AM | #17 | |
Rep 29,203
I've also tried an F10 with m-sport suspension and 19" wheels, and that was much better, but it still had lots of comfort.
