2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Help! Dropped a screw in the engine bay . . .
      08-05-2022, 12:51 PM   #1
FiatLux
Drives: 535i, X5 M50i
I was changing the engine air filter and the last torx screw fell over into the engine bay. It fell between the engine air filter cover and engine cover. Is it safe to drive or do I need to try to find it ? I don't see it in the pan underneath. I don't know what to do
      08-05-2022, 08:15 PM   #2
zvery777
zvery777's Avatar
Drives: 2021 M550
Get one of those things from Walmart that extends, has a light and a magnet. Good luck!
https://www.walmart.com/ip/54245181
FiatLux11.50
      08-14-2022, 11:01 AM   #3
Richardc88
Richardc88's Avatar
Drives: 2015 BMW 535i M-Sport
Seen quite a few N55 air filter housing bolts stripped from overtightening. Don't feel sad about 5 out of 6 doing their job. Just buy another one and move on if you can't find it. More than likely it's caught in the belly pan or on top of the DME wiring mess under the intake manifold. Good luck!
      08-14-2022, 07:56 PM   #4
FiatLux
Thank you for the replies.
I forgot I had posted this . . . I ended up taking a rideshare to Lowe's (and back) and got the magnetic tool. I finally found it after poking around for 15 minutes . . . It was hanging out in those wires. I just wanted to make sure it wasn't going to fly out and cause damage to the engine when starting my car or driving 😅
zvery777292.00
zrile104.00
      08-15-2022, 02:09 PM   #5
I dropped a screw once on a previous car. It landed on top of the brace between the (unibody) frame and front subframe. I looked forEVER!!
      08-21-2022, 06:22 PM   #6
4nscdoc
Drives: F10 535i
Those magnetic tools have saved me a number of times. I’ll move it around in the area where the screw fell, and can often retrieve it even if it can’t be seen
