2010 2011 BMW 5 Series Forum F10 BMW M5 to F10 DIY Brembo Brake conversion |
03-19-2016, 09:16 AM | #23 |
Rep 14,521
any updates Mike?
03-20-2016, 08:13 AM | #24 |
Rep 14,521
what are you doing gold plating them?? tell them time is money!
03-21-2016, 10:44 AM | #25 | |
Rep 14,521
03-21-2016, 11:01 AM | #26 |
Rep 14,521
nevermind! i just Googled it and now you got me thinking some crazy ideas! damn you lol!
03-22-2016, 05:04 PM | #27 |
Rep 14,521
Planning on doing the interior trim, mirror covers, side marker, reinforcement bar in the engine and maybe the steering controls
04-10-2016, 12:22 PM | #28 | |
Rep 5,110
http://teilecar.com/?2342,bmw-m5-f10...rembo&sLang=en [IMG]http://teilecar.com/files/bmw-m5-f10...bo%5B10%5D.jpg[/IMG] |
06-11-2016, 06:03 AM | #30 | |
Rep 414
Mike F
06-11-2016, 08:50 AM | #31 |
Rep 14,521
+1! already been a couple of months Mike!
06-22-2016, 02:27 PM | #32 |
Rep 14,521
Finally an update!
07-18-2016, 04:59 PM | #33 |
Rep 1,084
Drives: 2013 BMW F10 550 Xdrive Msport
Got the Brakes back from paint FINALLY this past weekend. Everything has two coats of paint and 2-3 coats of Soft Clear Coat (same stuff put on bumpers). So nothing should chip now. Rear brakes were sanded smooth to match the Front Brakes in appearance. Rotors are sprayed and just enough metal sanded off so once the brakes start being applied, no rust ring will occur on these. ///M painted in OEM colors.
Dust shield for front painted in Black, again 2 coats paint and 2 coats clear with the soft rock absorbing clear. I only posted one set of brakes, but they all match and all the rotors match obviously. Brake adapters are painted in Black too. So all of this should look sweet when looking between spokes of rims. Shooting for the next month or so to install. I need to dedicate a whole weekend for this and still need to order either OEM brake lines or after market stainless steel. Have not decided on that yet. Just need to sell the extra set of Calipers that I have for the front now. Only have 300 miles on them from a 2015 model. Last edited by mikekilpatrick; 07-18-2016 at 05:07 PM.. |
07-19-2016, 08:33 AM | #34 |
Rep 14,521
Whoa those turned out Bada$$! glad you did the shield black and not blue! Did you paints the hats too or did they come black? So these are the M5 Brakes? I gotta go back and reread the thread to catch up in things since you made us wait 10 years man they turned out really good!
BTW that's a floating rotor correct? Besides removing the calipers is it just a set screw holding the rotor in place? I ask because like I mentioned before I still have to paint my calipers and I wanted to paint the hats and the shield gloss black but I thought it would be cleaner if I just removed everything
09-09-2016, 06:21 PM | #35 | |
Rep 1,084
34336799903 5' F10 (06/2010 — 05/2016) 6' F06 GC (10/2011 — 02/2015) 6' F06 GC LCI (09/2014 — 05/2016) 6' F12 (03/2011 — 02/2015) 6' F12 LCI (05/2014 — 05/2016) 6' F13 (03/2011 — 02/2015) 6' F13 LCI (06/2014 — 05/2016) 34336796729 5' F07 GT (03/2010 — 06/2012) 5' F10 (01/2009 — 06/2013) 5' F10 LCI (08/2012 — 05/2016) 5' F11 (01/2009 — 06/2013) 5' F11 LCI (08/2012 — 05/2016) 6' F06 GC (05/2011 — 03/2015) 6' F06 GC LCI (05/2014 — 05/2016) 6' F12 (10/2009 — 02/2015) 6' F12 LCI (05/2014 — 05/2016) 6' F13 (03/2010 — 02/2015) 6' F13 LCI (05/2014 — 05/2016) Looks like Overlap on certain years, which lead me to think they are interchangeable. |
09-13-2016, 09:01 AM | #36 | |
Rep 336
I can try to check this evening in Rheingold to see what it has for M5 brakes Matt |
09-14-2016, 08:12 AM | #37 |
Rep 336
Mike, here are some screenshots I just took of Rheingold for an M5 front brake.
I have never used the TIS service, so not sure how it compares. If you want me to check something specific let me know and I will see what I can find. Matt
2011 Space Grey 550i - Eisenmann exhaust, ACS Springs, Dinan Intercoolers, Intake, & Stage 5 tune
2011 Space Grey 335i - M Performance exhaust - Wifes Past: 2000 Avus Blue M5 - Dinan exhaust, flywheel, & tune 180k+miles |
02-21-2017, 12:20 AM | #39 |
Rep 1,084
As soon as the weather gets warmer I WILL have the answer. Going to run the stock 550 Brake master cylinder and see how everything works. Others have used the 550 master with no issues.
02-21-2017, 10:03 AM | #40 |
Rep 14,521
still don't have these on Mike?
02-22-2017, 07:19 PM | #41 |
Rep 14,521
I'll save you the headache and buy those skirt extensions from you one less thing for you to install
04-18-2017, 12:20 AM | #43 |
Rep 1,084
Thanks
Thank you for confirming that. I have done much research and all real OEM research shows cross compatible master on these but I was a little hesitant till confirmed. Now I can put this project on deck
07-31-2017, 02:51 PM | #44 |
Rep 1,158
can you send me his information? I'm doing the same process, does it come with brake lines as well?
BMW f10 550i Msport
