2010 2011 BMW 5 Series Forum F10 550 n63 engine problems?? |
05-10-2016, 02:28 PM | #23 |
Rep 337
I was driving a little aggressively this past weekend in Sport Mode with the Sport Shifter, and after about 10 minutes (from cold) got the dreaded Drivetrain Malfunction, Power Loss message. It ended up going away after I reached my destination but of course that error still logged in the computer.
So, took it in this morning (they gave me an M235i as a loaner.. omg, WHAT a great little car!!), and the FOB read that it was a timing chain error. Still under diagnosis but I know the timing chain was part of the CCP that very few had replaced. My S.A. told me only 1 of all the N63s they did had to have one redone, so I'm not sure what that means for me. Really sucks though. I'd gone right at a year with zero hiccups. Glad I paid for that aftermarket warranty... whew!
2012 550i///M-Sport///Carbon Black Metallic///Oyster+Black Dakota///ZCV+ZLS+ZMP+ZPP+ZPS+ZSP+ZTP...M5 exhaust///iND Tricolor grilles///H&R Sport Springs///Turner Motorsport 12mm+15mm spacers
05-11-2016, 08:23 AM | #25 |
Rep 337
Got a call from my S.A. afternoon after tests were run.
It's the VANOS Bank 1. VANOS Bank 2 was replaced last year around this time, I'm not sure if it was part of the CCP or not. I asked her how many of those there were and she said 4, and I said great, only 2 more to look forward to failing! lol... Why do these things always go bad? I mean, I have a slight idea of what they are/do but I don't get why they fail so much. It seems to be with every BMW too going back to as long as I've been reading about them. Either way it's not the timing chain (which is good) so I should have it back today/tomorrow. My mileage is right under 54k miles.
05-11-2016, 09:49 AM | #26 | |
Rep 479
Drives: 11 F10 550xi
05-12-2016, 09:10 AM | #27 |
Rep 337
Got the car back this morning. My aftermarket warranty didn't cover diagnostic fees, but it did all parts and labor so I wasn't out of pocket too much.
Car is back to driving like it should! Only 2 more VANOS banks to fail lol...
05-18-2016, 09:45 PM | #28 | ||
Rep 1,684
Get a Honda or Nissan if you want an unremarkable motor that hits it's limit under 100 mph. The n63 tractor when married to the 550 chassis is a beast---if you want it to be. At the same time, driving the 550 like a granny is like having a goldfish in a small bowl. Your growth will be stunted whilst you swim in your own feces. You can push the n63 without living dangerously or being overly risky. From time to time, it's gonna need parts. The n63 customer care pack was not necessitated by a faulty design. The n63 care pack was necessitated by BMWs failure to predict how the car would be driven. Drive it hard, get its innards to learn to sing harmoniously and you'll be rewarded with a long life with tons of fun. If you overly baby this car, it's innards will never learn to synchronize in harmony---this will lead to asymmetrical forces combined with dangerous harmonics that will ultimately produce a Tacoma Narrows Bridge of shame. Drive it. |
09-14-2016, 02:59 PM | #29 |
Rep 25
Hello,
Like all the other guys here, having problems with the N63 engine, it seems that it is my turn. Unlike US cars and BMW NA, in Europe , we dont have the CCP. I had done only a recall for high pressure fuel pumps. The first problems with the car where that it did not cool down. I could drive it only for 2-3 minutes, and then the air cons was shutting donw, and the car was not pulling anymore. Took off the radiators, separate them and clean them individually. There was a lot of dirt between them, and the air was not getting through to the las one, wich is the coolant radiator. Replaced 2 electrical water pumps. one for the intercoolers and one for the cooling sistem. the mecanical water pump, remained untouched. All good, the car was running perfectly. After a while, the engine start was taking too long than normal. also there was an issue with the starter. Replaced that with new and original starter. I also replaced the spark plugs. Bosch equivalent, not BMW original ( although they are also Bosh, but somehow minor differences ). All good again. After another while, the car was starting to throw black smoke, and drive train error. But somehow, i could anticipate it: it started to run in shocks, like it would be overcoming some obstacle. After 3 shoks like this, the CEL appears and the drive train error , alltoghether. First diagnose, misfire on cilinder 2, lambda probe bank 1 faulty. Erase error, drive it again, again error. after some internet reading, decided to replace all 8 injectors and lambda probe. All good, car was running flawlessly for 100km. Then, misfire on cylinder 3 and 5. erased erors, drove it again, and instantly missfire. cilinder 2. then decide to switch the spark plugs between 1 and 2. Instantly , erorr moved to 1st clilinder. I said ok, let's change the sparkplugs again, with original ones. Done that, same errors. It varies from 1 to 4 cylinder. reprogrammed the DME. reprogrammed the whole car. switched all coils between them. all good, the error remains the same. today i took off the turbo on bank 1 to check the exhaust baldes and catalist. all good. Compression ok. the car is 2011 and 69.000 km, 43,125miles. Russian car. ordered for Russian market. at this point i dont know what to do next. the SA told me that he spotted some coolant between the turbos. i dont know where it camed from. It was not much.. What do you think ? because i dont know what to do next.. where to look ? Vanos ? Head gasket ? Now all the errors are only on bank 1. passenger side.... thank you
Actual:BMW F10 2011 550Xi - stock
Gone:BMW F30 2012 328i - replaced engine. Gone:BMW F13 2012 640i Gone:BMW F10 2013 528i - stock Gone:Porsche Cayenne S 2008, 957, 4.8i , Meteor Grey |
01-18-2017, 10:46 AM | #30 |
Rep 2
59,000 Miles-Timing Chain Issue
If you are already thinking this ended how a lot of peoples has you would be correct. Catastrophic damage.
Pt.1: It all started 26 miles after leaving the dealer from a brake fluid service. While at the dealer getting my car serviced i expressed my concern to my SA about the CCP on the car and if it had been performed, he told me that it had been done at 40,xxx. We stayed on the topic for a while and i told him that my only fear of owning the car was the injector/timing chain issues... Just so happens that after i pick up my car and 26 miles later that exact issue occurs. Go figure, right? Background on the car: The chain had to of stretched between 46,xxx and 59,xxx. How do i know this? A CPO inspection was done to issue a CPO warranty on the car at 46,xxx to the previous owner and it was issued. (Either they didn't inspect much and the chain was already stretched at 46,xxx or it actually did stretch within those 13,xxx miles). I purchased the car at 55,xxx with warranty. Pt.2:The initial diagnostic was that the chain had stretched and caused a tensioner to fail. New chain & tensioners = $8K repair 3 weeks later... Upon further inspection they found that a piece of the plastic tensioner had ended up dislodging an oil spraying nozzle on the bottom end of the motor from its threads and the engine is a total loss. (Makes no sense, how does a piece of plastic rip a metal nozzle of out its threads within seconds of driving) At this point i'm furious that it took them 3 weeks to "free" and engine stand and tell me i need a new long block. New long block = $14k repair. CNA decides to be cheap and only wants to pay for a used long block from a 2013 with 35,xxx miles which put the repair bill at $13k. They gave me the option to pay the difference, i declined. (If they want to be cheap and risk this happening again thats their fault) Pt.3: The dealer has dragged their feet throughout this process and after 2 weeks of them receiving the used motor and constant delays the day finally comes that its suppose to be ready. (A week after the original day it was suppose to be ready) I arrive at the dealer and they tell me: "the car is ready but we haven't had a chance to do an "extensive" driving test of 50+ miles and that its protocol after a large repair". (So its not ready... but ok...) I leave it over night and the next day i pick it up and as i get in the car i notice the trip had started 38 mins prior to me picking it up and was only driven 20 miles. (completely lied to my face). At this point i dont care and i'm happy to have my car. Guess what? At exactly 52 miles i get a drivetrain malfunction and reduced engine power... (I'm livid at this point and could've ran through a wall.) I finally get the director of all the "superior automotive" service centers involved and explain the lies and delays by his BMW service center. He ends up giving me $100 gift card and full detail inside/outside. The new issue was a camshaft sensor that was bad on the used motor but was not billed to me or CNA due to the fact that the service center blatantly lied about the extensive driving test they did not do. I attached 2 pictures, one is of the new long block and the other is "the old one". The oil nozzle that failed sits directly below the crankshaft from that picture angle. Essentially it is the heart... No oil spray/circulation, bye bye engine. After about 3 months i was finally back on the road. To date i'm at 1500 miles without any issues. CNA paid for repairs and i paid my $200 deductible. I cant stress enough, if you buy this car buy a warranty. ($4400, 3 years/36,000 miles, it already paid for itself) As far as my dealer, i trust them as far as i can throw them. |
01-21-2017, 02:22 PM | #31 | |
Rep 1,254
I am in process of getting warranty on my 550 I was quoted $3400 and 50k miles $200 deductible I wonder why is warranty on your 550 so much more also I was told bumper to bumper
01-25-2017, 12:09 AM | #32 |
Rep 2
Remember when I said I trust my dealer as far as I can throw them? I'm assuming they tacked on a little profit for themselves... Which they are allowed to do. I wasn't aware that they could when I purchased it. Either way, BUY IT.
EL Jeffe 5612.50 |
01-25-2017, 11:47 AM | #33 |
Rep 30
2011 550xi 68k only issue was a ruff idle & dt on cold starts. Fixed with cps sensor replacements.
01-25-2017, 05:52 PM | #34 |
Rep 150
2011 550i 75k miles, CCP done long ago...
Fun to drive, looks great, lots of power, and a P-O-Ssss. My engine was leaking oil from just everywhere that has oil and a gasket, valve covers and everywhere else. My garage floor looks like an oil slick. How hard is to make a gasket that lasts more than 5 years? Just found out my valve stem seals are bad and need to be replaced....valve stem seals for facks sake?!?!? I've had some shet cars in past, like really shet cars like several 80's high-mileage Chrysler/Dodge products, but never had soooo much facking break on a car, especially with moderate miles. Lucky it's under CPO otherwise I'd be out over $15k in repair bills just the past year. |
06-13-2017, 01:09 PM | #35 | ||
Rep 81
Honestly I have had several issues as soon as my car hit 40,000 miles. I have had 4 engine malfunctions in 6 months. Every time it was for a different issue. Basically everything has been replaced under the factory morning, timing box, fuel pump, fuel injectors, spark plugs, oil leaks, air intake, gaskets, and so much more I can't even remember. I would have to pull up my service reports. My advice would be no question make sure you have a warranty on the car!! When the car is fixed and riding great I have never driven a better more powerful car. I would buy another one - that is how much I love the car! Just need a warranty
Jayson Brown
06-14-2017, 04:12 PM | #36 | |
Rep 233
Drives: my neighbors crazy!
Maybe next time I'll get lucky and get to take a G30 out for a few days haha
Current: 2009 Nissan GT-R | 2012 Converted | Cobb Tuned | AMS Downpipes | Armytrix Exhaust | AFE Intakes
| Forgestar F14 + Pirelli P Zero 295/305 -- Past: 2011 550i ///M Sport | 2010 M6 Coupe | 2004 BMW M3 Convertible | 2003 BMW 330i |
06-14-2017, 04:31 PM | #37 |
Rep 150
Last week I took my 550i in for a final inspection by the dealer on the last day of the CPO...of course there are multiple oil leaks from various gaskets that would have cost thousands in labor and parts. Now around $20k in warranty work in just the past year.
06-14-2017, 07:40 PM | #38 |
Rep 795
BMW must have been losing money overall on cars with the N63 engines. I'm surprised they still use this engine (still seems to have issues even after the updates).
In my view, BMW V8 = lease only. The recent I6 engines seem to be ok to buy. |
09-28-2017, 12:31 PM | #39 |
Rep 15
similar experience
Owner since new of a 2011 f10 550xi. Yes I applied the Dinan Stg2 upgrade but the car has been serviced and properly cared for...
...yet the engine has marred my experience. 78k miles later it has had: 1. all 8 coils, injectors and plugs replaced at least 3 times over 2. both vanos units replaced 3. timing belt replaced - engine out twice 4. water pumps replaced twice 5. oil pump replaced 6. low and both hi pressure fuel pumps replaced 7. CCP package applied 8. turbo coolant leaks fixed 9. oil leaks fixed 10. engine replaced not to mentioned the engine was out twice before they replaced it. Are the engines so bad? I was thinking of getting the new g30 550 or M5 next year but now I'm not so sure. I try to keep my cars 7-8yrs, but its seems those days are gone. Maybe since leasing has become so popular the cars are built for shorter term reliability??? Now I'm stuck whether to take the plunge on the new car or go elsewhere. Thoughts? |
09-28-2017, 01:18 PM | #41 | |
Rep 5,409
ChiltiCoatl891779.50 |
01-19-2024, 08:07 PM | #42 |
Rep 56
I got a new engine last year today the engine didn’t start we changed the battery nothing changed I think that is the reason why it won’t crank or start it’s an engine issue my dad will take it to a repair shop in Staten Island I hope he can find the problem for why it won’t start or crank.
01-19-2024, 09:55 PM | #43 | |
Rep 441
Drives: 2016 F10 BMW 535i M Sport
