2010 2011 BMW 5 Series Forum F10 Auto lights - always on? |
10-17-2010, 12:11 PM | #23 |
Rep 80
I had an X5 behind me witch seemed to have same system. And I did also check this out. To me it seemed to work quite well. Main headlights turned on under bridges, in tunnels and in low sun. In the low sun the visibility in my rearview mirror was real poor so to me it seemed right that the headlights was on. When driving in longer period with shadow, a valley the low sun didn't get down to, the lights went back to DRL.
I don’t know where the sensor is but most of this type of sensors is in front of the rearview mirror. |
10-18-2010, 07:03 AM | #24 |
Rep 74
+1 for the same problem.
I have DLR on all the time but have noticed that the auto headlamps option, seems to operate when in complete, normal daylight.. it is quite random. This leads me to believe that there is a glitch in the sensor software. |
10-18-2010, 01:00 PM | #25 |
Occasionally frequent poster
3012
Rep 2,746
Ditto. Noticed this on a long road trip Saturday, bright sunshine, clear skies, headlights stayed on well after 9:30 (sunrise around 7:30) until I just turned the damn switch off.
Current inventory:
F22 & G05 Cadillac CT5-V Blackwing w/3 pedals Past: E24,E28(3),E34,E36,E37,E38(2),E39(4),E46,E89,E92 (obviously),F01,F06,F10,F30,F87,G12,G30(2),G82(2) |
10-18-2010, 01:12 PM | #26 |
3012
Rep 2,746
According to the manual, the sensors on the mirror are only for the operation of the mirror. This has been my experience as well on my E92, because I blocked the front sensor to make it think that it was darker than it really was (to darken the mirror) and that didn't have any affect on the auto headlights.
Current inventory:
10-18-2010, 02:26 PM | #27 |
Rep 80
The sensors for the mirror are on the front and back of mirror itself. Camera for high beam assistant and lane departure warning are in the area where the mirror is attached to the screen, and this I think would imo be the logical place for this sensor too.
So to tests this you should cover up this part of the windscreen. I cannot test, desperately waiting arrival of mine next week :-) |
10-24-2010, 11:01 AM | #28 |
Rep 186
I did test the sensor for the lights. It is the larger circular area on the rear view mount. I had the DRL on in the iDrive.
1. Set DRL to off (un-tick) in iDrive 2. Set the lights switch to "A" 3. Cover the larger sensor area and see the head lights come on Now it works for me !
2013 - x30d E70 M Sport
2010 - 520d F10 SE |
10-24-2010, 05:43 PM | #29 |
Rep 1,008
Maybe its off topic, but does your navigation also go on night mode when your headlights are on? I notice if I go through a tunnel during daytime, the sky on the navi gets dark. Just wondered if your head-ligths where on but the sky on your nav us blue, then its not your sensor which is wrong, but how its programmed.
10-24-2010, 06:22 PM | #30 |
Rep 171
Normally, there are two sensors: one for light and one for rain. However, I was told some car makers will combine both functions in forward-looking camera. Maybe that is the reason why camera is not so sensitive as sensor.
12-25-2010, 12:29 AM | #33 | |
Rep 57
I spoke to a senior tech and he did mentioned that the sensitivity can be adjusted by programming. He hook up my ride to check mine and confirmed that it is already set to high sensitivity! He did also mentioned something about ultra-violet rays .... and blah blah..
2011 F10 535i . Xirallic Sophisto Gray . Oyster . Black Dakota Leather. Delivered on 22 Dec 2010
2004 - E60 530i Olivin Green :: 1996 - E39 523i Titanium Silver :: 1992 - E36 318i Vulcangrau :: 1990 - E30 316i Alpine White |
12-29-2010, 12:10 AM | #35 |
Rep 3
My 535i has the similar problem. Knowing where the sensor is located doesn't help anything. The sensor's sensitivity adjustment may need special equipment. But I just like to know if this is just purposely designed this way or just a false adjustment. Since many owners reported such an issue, it might just designed that way.
2011 535i Dark Graphite, Grey leather, Sports Tran with Paddles, Premium 1, Premium 2, Sport Package, Top View Cam, Smartphone
12-29-2010, 05:34 AM | #36 | |
Rep 57
12-29-2010, 05:28 PM | #37 | |
Canada EH!
287
Rep 338
On my 08 335i, the DRLs are the center set of lights being on about 20% of their full power (these are halogen and are also used for High Beam flash to pass) and has nothing to do with the external set of lights which are the Xenons which work as the Headlights as well as the regular High Beams (aka Bi-Xenon). I believe from 09 on, the BMW DRLs are the rings, and the center set of lights are for flash to pass High Beams using halogen lights (Xenons are too slow to heat up to be used for flash to pass). The outside set of lights can be Halogen Headlights or Xenon Headlights/High Beams (aka Bi-Xenon) depending on the model and option selected. Last edited by Stephen5242; 12-29-2010 at 05:40 PM.. |
01-01-2011, 04:42 AM | #38 |
Rep 1,134
Always keep them on myself for safety reasons, I want people to see me from far back during the day as well. I do hope your able to get it set the way you like it. Does it bother you that they are running, you cant even see them.
2014 550i M-sport
01-01-2011, 07:46 AM | #40 |
Rep 1,134
They should be mandatory for highway driving. I have a sled I drive, old Mercedes wagon I beat up on cause I hate Mercedes, anyway, it has to work hard to get to 130kmh, but when I pass trucks running at 100 or 110, I NEED those DRL's to be on!
2014 550i M-sport
01-01-2011, 10:17 AM | #41 |
Rep 150
I have also noticed that my lights stay on during bright sunshine, but it seems only when the car has been left in bright light? To get over this I turn off the auto light when I leave the car and turn on again when i drive, this eems to get over the problem....maybe by leaving off the auot light for a while, the system resets???
01-01-2011, 12:15 PM | #42 |
Rep 3
I have the same issue, the lights are always on with the headlight switch at "A" and the selection within the i-Drive is definately set to automatic not "always on". Alas I don't have the solution, just the same problem.
01-01-2011, 12:59 PM | #43 | |
Rep 308
You and raleedy are wasting airtime with your crap comments. Since raleedy's two posts are completely unhelpful "Soon we'll be getting questions about the low temp warning" and "they'll go off sometime in April", why not point the finger at the fanboy 3-series owner, not me. "9 year old"? F off. |
01-01-2011, 03:36 PM | #44 | |
Rep 57
This is obviously totally off topic but my point is that in order to foster an environment where people are comfortable airing their opinions, it's important that we are all courteous in our posts. Last edited by finbrad; 01-01-2011 at 03:48 PM.. |
