2010 2011 BMW 5 Series Forum F10 Thrust Arm Bushing Upgrade |
11-13-2020, 12:51 AM | #45 | ||
Rep 529
https://www.fcpeuro.com/products/bmw...s3-31306795151
BPM Tuned, Advanced Fuel Dynamics, Paddoq Valved Exhaust, Paddoq Magnetic Paddles, EDC dampers, Dinan Springs, H&R Sway. DCT all day long.
https://www.youtube.com/channel/UCFu...fWjCtOz49FDMlg |
11-13-2020, 07:38 AM | #46 | |
Rep 1,445
Drives: F10 S55, E93 M3, E89 N54
So if the clunking noise is now gone does that mean you can tell us how you like the monoballs? |
11-13-2020, 09:45 AM | #47 | ||
Rep 529
11-13-2020, 11:20 AM | #48 | |
Rep 965
11-13-2020, 12:18 PM | #49 |
Rep 1,445
Good review so far, seems like it's a legit upgrade. At about 100 mph braking I get a shake, pretty sure it's my bushings. I need to do this.
11-13-2020, 01:23 PM | #50 | ||
Rep 529
11-13-2020, 01:25 PM | #51 |
Rep 529
Your vibrating can be warped tires, rims, bad bushings. Likely a bad thrust arm as that seems to be the most common on our cars beside rotors and brakes. Can't wait to replace my brake fluid with RB660 I already did the rotors and brakes since I was under there. Once that's done ill report back with braking improvments and then again when I update my tires. Then back to the track Dec 5th Fontana Speedway. Who's in?
11-13-2020, 05:18 PM | #52 | |
Rep 965
11-14-2020, 09:46 AM | #53 | ||
Rep 529
11-14-2020, 10:00 AM | #54 |
Rep 529
Ok took the car on a 50 mile road trip. Going freeway speeds and faster across some known choppy sections of the freeway with cornering, and now I can give my honest opinion.
The monoball thrust arms do not get easily upset. They kept my car composed over rough and bumpy sections at high speeds and held very straight lines in the cornering. Even with my suspension at full tight the car has never felt so solid. Like I mentioned, it doesn't get upset easily. I did take it to a speed where I began to feel the limits of the car but it's way up there. I have never drove an M5 but I'm guessing that's how my car now handles potentially better given my numerous other suspension upgrades. My steering is super responsive, braking has 0 nose dive, rough patches in a straight line or cornering don't throw the car off its line, and it feels like a different/better handling car almost like a new car. 1000 percent worth the upgrade. It's could even be the number 1 upgrade to your car. The handling is next level when pushed or cruising.
burro_blasta132.50 95blkmax216.50 |
11-15-2020, 08:05 AM | #55 | |
Rep 1,230
N55 GENERAL
David Shoup Tuned Fully Built By Miami Engines/Project Motorworks Precision 6266 On Steroids |
Bmwdoubles_194.00 |
11-15-2020, 10:17 AM | #56 | ||
Rep 529
11-15-2020, 02:51 PM | #57 | |
Rep 5,409
They do do a visual inspection... |
11-15-2020, 05:52 PM | #58 |
Rep 1,230
im liking the bars!!!
N55 GENERAL
11-15-2020, 06:03 PM | #59 | ||
Rep 529
11-15-2020, 06:04 PM | #60 | |
Rep 529
11-15-2020, 11:24 PM | #61 | ||
Rep 441
2013 535xi M Sport (PWG) // PS2 // Spool fx150 // MHD // xHP // FTP Inlet // FBO: AR HF DP, Wagner IC, BMS Intake, VRSF CP
11-16-2020, 09:44 AM | #62 |
Rep 305
I guess its just you and me with this upgrade at the moment in this forum. Isn't it crazy how just upgraded front bushing changes everything and reduce all the slop in the front. Would love to test the difference since you got mono and I have poly. It's definitely one of the top upgrade you must do on a F10. Thanks for the review.
Bmwdoubles_194.00 |
11-16-2020, 02:10 PM | #63 | |||
Rep 529
11-16-2020, 10:11 PM | #64 |
Rep 2,595
You could drill a hole through the strut bar mount and have a knob extender stick through. It's what I'm looking to do.
2015 BMW 535xi
Bmwdoubles_194.00 |
11-17-2020, 12:27 AM | #65 |
Rep 529
Good idea
11-17-2020, 10:22 AM | #66 | |
Rep 1,876
