2010 2011 BMW 5 Series Forum F10 Nickco43's Cheap Used Car 2011 535XI Build Log |
06-29-2020, 07:52 PM | #67 |
Rep 2,595
Nickco, how did you get the original mickey mouse flange out? I couldn't get it out for the life of me to do the metal flange upgrade.
2015 BMW 535xi
06-29-2020, 07:55 PM | #68 |
Rep 63
Drives: 2012 BMW 535xi
06-29-2020, 08:26 PM | #69 | ||
Rep 1,917
06-29-2020, 08:45 PM | #70 |
Rep 2,595
Did you squeeze on the metal band area, or on the O-ring part?
2015 BMW 535xi
06-29-2020, 11:04 PM | #72 |
Rep 868
Hey Nickco43,
When you get your rear sun shade installed, and run your white and green wires to your Junction Box (pin 3 and 30?) can you post what values you changed in the JBE VO? I have swapped my Junction Box with an M5 version that had the rear sunshade, but my VO changes did nothing....and would love to get this activated. Thanks! |
06-30-2020, 10:24 PM | #73 | |
Rep 1,917
https://parts.bmwofsouthatlanta.com/...or-51461388215 Last edited by Nickco43; 06-30-2020 at 11:41 PM.. |
07-01-2020, 08:44 AM | #74 |
Rep 2,595
Maybe try too get a motor from a salvage car? I believe 6 and 7 series shared a ton of parts with the 5, so there should be a good selection
2015 BMW 535xi
07-01-2020, 10:13 AM | #75 |
Rep 1,917
I could only find the entire assembly for about $200. I would rather have a brand new motor for that price. I went ahead and ordered the E31 motor. I don't feel like putting my interior back in so I will drive my e90 around for a bit while I wait on the part.
07-01-2020, 03:16 PM | #76 |
Rep 1,917
ezaircon4jc4574.00 |
07-01-2020, 03:21 PM | #77 | |
Rep 63
07-01-2020, 03:39 PM | #78 |
Rep 1,917
07-01-2020, 04:24 PM | #80 | |
Rep 1,917
https://www.ebay.com/itm/Intercooler...53.m1438.l2649 I don't really care if the knock off flows worse than the real one or not as I am only going to go stage one. I might even just get a OE Nissans one from rock auto for $150. |
07-01-2020, 08:22 PM | #81 | |
Rep 2,595
Edit: That's the radiator (edit: jk it's the ac condenser), you can see the stock intercooler behind it in your picture. Stock intercooler has those thick ass bars between the plates. Edit 2: The M sport retrofit they sell from ebay isn't quite complete. It's missing the foam absorber, p/n 51117903993. Base one is a bit thicker and might cause a large bumper-to-hood panel gap. Edit: Probably the AC condenser based on what others have said.
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial Last edited by Unspec; 07-02-2020 at 09:09 AM.. |
07-01-2020, 11:27 PM | #83 | |
Rep 1,917
My AC still blows 100% ice cold so I will hold off on replacing the condenser. I am going to be honest I am getting tired of dumping money into this thing. The check engine light came back on today. I still have the bad cat code and now I have a evap leak. With the body shop bill I am going to be past 13k into the car. |
07-02-2020, 08:15 AM | #84 | |
Rep 2,595
2015 BMW 535xi
07-02-2020, 09:01 AM | #85 | ||
Rep 63
07-02-2020, 09:07 AM | #86 | |
Rep 2,595
2015 BMW 535xi
07-02-2020, 08:17 PM | #87 |
Rep 1,917
The bumper foam was $84 from the dealer shipped. The car is at the body shop and should be done Monday. I went ahead and bought a charge pipe and a MHD flasher thing from BMS. Apparently MHD has a better tune for my 11 N55 which is more like a E90 N55 then anything else.
