2010 2011 BMW 5 Series Forum F10 U0079 error code. Plz help! |
03-20-2015, 12:16 PM | #1 |
Rep 767
Hey guys. So I recently got an audio system installed. It's been in there for about two weeks everything has been fine. Yesterday I decided to tweak the settings a bit on the audiocontrol lvq-1 unit. System started sounding a little better and SLIGHTLY louder. When I went to my car this morning I got a message saying electronics were shut off because battery was discharging?? I'm guessing it has to do with the system somehow and something that I touched, which is weird because all I did was play with the equalizer settings. Then I come out the gym two hours later and see a check engine light come on. I go to autozone and they pull this code:
U0079 Control module Communication Bus "G" off Can anyone help me?? I tried looking up that code on Google but want successful. What could this be? |
03-20-2015, 09:19 PM | #2 |
Rep 1,698
Can't help you on the code - but I'd probably suggest having the audio installer look at it, or BMW preferably. There's a chance the audio system was installed incorrectly, draining the battery.
2017 BMW 650xi Gran Coupe | MSport | Exec Package | Driver Assist Plus | ACC Stop & Go | Adaptive Drive | B&O | Night Vision | Cold Weather | Active Seats
2015 Audi R8 V10 | Brilliant Red on Black | S-Tronic | Carbon Sideblades | Carbon Trim | Full Leather | Sport Exhaust | Illuminated Doorsills | I-Pod | Contrast Stitching Previous: '14 550xi, '07 335i, '01 325i |
03-24-2015, 07:46 PM | #3 |
Rep 767
UPDATE: Okay so things have gotten worse. Still getting increased battery discharge message upon every startup after not turning the car on for a few hours. Took the car back to installer who installed a cut off switch because according to him this car has no ignition. The cutoff switch he put under the dash had to manually be shut off everytime I exited the car, which I didn't like. Took it to another installer who was able to eliminate the cut off switch and "find" the ignition so it seems as if everything shuts off. However I still am getting the battery message, along with check engine light, and passenger restraint malfunction message!! I am going insane here I don't know what else to do. Also noticed my headlights won't automatically turn on anymore when in auto and I have to manually switch it off. Don't think my car shuts off at red lights neither. I think this has to do with some type of voltage issue. Please anyone have any insight as to what it can be or what I can do? I'm stuck here I can't bring it to BMW neither as it would void warranty
03-24-2015, 08:53 PM | #4 |
Rep 494
Nothing you did to the equalizer settings caused this problem. The installation caused the problem.
Take the car to an independent BMW specialist to have it checked out. Since the problem is getting worse, you need to get this resolved soon before something more serious happens. |
03-24-2015, 08:58 PM | #5 |
Rep 767
yeah I agree, tomorrow I am going to do exactly that. I just noticed as well that my automatic headlights wont go on in the auto position at night when the car first starts, and after manually putting them on and going back into auto mode they will turn back off. however, after about 20 minutes and switching the lights back to auto mode, they will stay on. Sort of like the battery needed to charge up or electronics needed to warm up or something.?
03-24-2015, 09:14 PM | #6 |
Rep 494
Yeah, if the battery is seriously discharged you can loose certain functionality and settings. You should have the battery checked out as well to make sure it's not dying.
03-25-2015, 11:04 AM | #7 |
Rep 10,185
Whats the voltage on your battery ?
Sounds like its very low Auto stop start wont operate if your battery is low and you will get the discharge warning.
BMW if you are reading, I need a job, Please. |
03-25-2015, 03:10 PM | #9 |
Rep 250
honeslty i would have the cutoff switch installed, that would eliminate your battery drain issues. My E60 went through the same thing your going through. High battery drain message everytime i got in the car. So i finally went to auto zone and had them fully charge my battery and installed it back in the car after adding in a cutoff switch, no battery drain after that point on. Keep in mind i had a JL W7 with a 1000w amp, tore my e60 to hell. now it rattles over every bump --____--
03-25-2015, 08:39 PM | #10 |
Rep 767
So in the morning I checked the battery at Autozone. They said the battery was 40% charged and couldn't charge it for me because they don't charge BMW batteries anymore being that they don't have a certain device that would save the memory that the battery stores. Drove more and a couple hours later checked at another autozone, battery was reading 85% charged and they also said the same thing about not being able to charge the battery (although I did see him enter 800cc instead of 850cc). After this i decided to go to the BMW indy mechanic, he basically said Autozone guys have no idea what they're talking about because the car would charge the battery on its own, and ran a diagnostic for me. I seen tons of codes come up which he said I can go to the dealership to get fixed such as the passenger restraint system and check engine light. He also said that it showed something was waking the system up when it's parked over night. I told him about my new audio system in the trunk and he said these cars are very sensitive electronically and come with tons of electronics that use the battery, and advised me if I wanted to keep the system I would have to install another battery or capacitor in the trunk. He then went on to say when I take it to BMW I don't have to uninstall anything in the trunk and just bring it in like that and not mention anything about a battery, just call BMW and tell them my passenger restraint malfunction light is on along with check engine light and have them find the problems on their own and fix them. Keep in mind, this mechanic used to work as a service tech at a BMW dealership for ten years before opening up his own place. what scares me is that some of the problems are directly related to the extra load on the electrical system, wouldn't BMW open my trunk when they decide to check out the battery and see the audio equipment?? therefore using that as an excuse not to cover anything? The airbag warning is probably just a coincidence but not related to the electrical stuff going on. Anybody with an audio system installed have a problem with BMW dealerships not fulfilling the warranty?? My car is a 2012 that just passed the 50k mark but I bought it as a CPO so it's got warranty until 100k miles.
03-25-2015, 08:41 PM | #11 | |
Rep 767
03-26-2015, 08:58 AM | #12 | |
Rep 250
03-26-2015, 10:04 AM | #13 | ||
Rep 767
03-27-2015, 11:19 AM | #14 | |
Rep 250
I have personally bought his harness in the pass and its truely a plug & play device. I installed my whole system in 15 mins! Awesome product here is Technic's direct link, this should solve your problems http://f10.5post.com/forums/member.php?u=1065 |
03-28-2015, 08:40 PM | #15 | ||
Rep 767
02-18-2019, 08:21 PM | #17 |
Rep 1
Hey, do you mind telling me what it ended been? I am having the same check engine light, as you . I also got an audio system installed, but i started removing everything so see if i can find the source, but still nothing. I used carly am getting
U0079 Control module Communication Bus "G" off I didn't have any battery drainage though, just a check engine light, when ever I clear it, it comes right back on again after I restart the car. My car is due for state emissions inspections, so I need to get this fix fast, I NEED HELP |
10-17-2023, 04:24 PM | #18 |
Rep 11
Drives: BMW 335xi 2013 sedan msport
did anyone ever find a fix to this code?
10-19-2023, 08:51 PM | #19 |
Rep 767
It’s been so long since I posted this so it’s hard to remember exactly, but I took the car to an audio guy that specialized in bmws and he redid my entire system using the bimmertech amp. I didn’t install any other amps or subs. Fixed all problems. Huge difference in sound quality just with the bimmertech amp and all stock speakers. Got a boost in overall volume as well.
