2010 2011 BMW 5 Series Forum F10 Flat tire on non run flats in the desert |
06-19-2017, 06:18 PM | #1 |
Dream crusher
984
Rep 2,421
Coming back from Tahoe to LA and half way through realized I had a nail in the tire almost near the sidewall. Knowing that I'm always running a risk on a road trip with non run flats I came prepared.
- tire plug kit / razor to cut excess - air compressor - tire gauge - fix a flat - grease marker Moving at high speeds (undisclosed) while keeping my "vehicle status" screen up that contains tire temp and PSI, I heard a clunk in the fender well followed by the infamous BMW bong warning sound. The nail had flown out and PSI dropped dramatically to 10 PSI. Pulled over to a safe area, turned on hazards and wished I had a triangle hazard. Located the hole, marked it with a grease pencil rolled the tire so the mark/hole was exposed out and accessible. Put cement glue and probed the hole 3 times, pushed in the plug 3/4 of the way, trimmed down to 1/8", compressor up to 25psi and filled the rest with fix a flat. Did that in about 15minutes and was back and running. Some take aways: Don't use fix a flat if you don't have to. I did because it was near the sidewall and the tire is done at that point. Also it causes crazy vibration from the liquid until it dries. The compressor I got was shitty and I could of been done in less then 5 minutes had it filled faster. Run flats would of only taking me 50 miles and the nearest tire shop was over a 100 away. Get the BMW hazard triangle The plug and fix a flat took me 300 miles without issue.
IG: @bmwdoubles |
06-19-2017, 09:35 PM | #2 |
Rep 231
Got me confident on running non-RFT on my next set of tires.
2011 535i xDrive Black/Black, Michelin PS AS 4
2014 435i RWD Convertible Service Manual: www.newtis.info Part: http://www.realoem.com |
06-20-2017, 05:34 AM | #3 |
Rep 266
06-20-2017, 08:59 AM | #4 | |
Rep 42
The compressor I got was shitty and I could of been done in less then 5 minutes had it filled faster. What compressor do you have? Would like to avoid it!
Larry
06-20-2017, 09:00 AM | #5 | |
Rep 42
Larry
06-20-2017, 10:04 AM | #7 | ||
Rep 1,472
While I still had runFlats I've gone a bit more than that, had car parked for two days until my TireRack order arrived then took it to the dealer (all at fairly low speeds and not busy streets), and had no issues. You are risking major damage to the rim of course, but I took a chance since dealer isn't that far and just didn't want to have the car towed at the time. Quote:
06-20-2017, 11:41 AM | #8 |
Rep 937
I have a similar "kit" in my trunk as well. I don't have the grease pencil, but might help. I can always reference a spot on the tire sidewall as a reference I guess.
06-20-2017, 03:31 PM | #10 | ||
Dream crusher
984
Rep 2,421
IG: @bmwdoubles |
06-20-2017, 06:26 PM | #11 |
Rep 194
I'm happy with this one:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 And it is extremely accurate. |
Bmw doubles983.50 |
06-24-2017, 09:46 AM | #12 |
Rep 80
I opted to get this, plus a BMW jack off Ebay for 35$
http://www.bimmerzone.com/BMW_Perfor...T-F10-KIT.html Smaller than the reg tire so its easy to pull in-n-out when needing the space
2001 530i
2004 330i 2006 X5 4.4 the beast 2014 328i 2012 535i |
06-24-2017, 12:54 PM | #13 | ||
Dream crusher
984
Rep 2,421
IG: @bmwdoubles |
