2010 2011 BMW 5 Series Forum F10 Fitting a (F85/F86) Cluster into a F10 |
09-17-2023, 01:55 PM | #1 |
Rep 51
Drives: 2015 535i xDrive
Hi all, for quite some time I have been wanting to put an F10 M5 cluster onto my F10 535i. I’ve seen threads that it is possible but requires a lot of coding and emulation (iirc. issues because the gear positioning is different on M vs. non-M)
But, I am wondering if it is possible/an easier retrofit to put in a X5 or X6 M cluster. I think it would be easier because both of these cars (535i & X5/6M) have the ZF-8 speed, same as 535i, instead of DCT. So in theory, would it be possible and easier than retrofitting a M5 cluster? And if so, I would love get help on how I would go about this. |
09-18-2023, 01:23 AM | #2 |
Rep 1,363
Problem is not the transmission. It’s the gear shift selector. You will need to install the M5 gear selector in order for the M5 instrument cluster to work properly. No need for emulator, just a few extra wires for gear selector and coding.
coasts38.00 |
09-18-2023, 01:01 PM | #3 |
Rep 167
How about for the x5m cluster?
09-19-2023, 10:40 PM | #6 |
Rep 7
Speedometer M5/6 will not work normally at 528/535/550/640/650 and so on. Even if it is coded and programmed correctly. I tried making the speedometer virgin, removing the mileage and Vin from the eeprom. The main problem is that every time you turn on the ignition, your mileage will increase by 10-15 miles.
09-19-2023, 10:46 PM | #7 | |
Rep 51
12-29-2023, 09:54 AM | #9 |
Rep 240
I have done this on mine, and the mileage will go up by 8 miles each time unless you solder your OEM chips onto the M5/M6 cluster. There is no other way.
I have mine coded and all, it works absolutely 100% perfect even show efficient dynamics (while a useless gauge) it's not blank at least. It does have comfort-sport-sport plus as well that you can turn on in the navigation display unit. |
GabiSibiu0.00 |
04-12-2024, 02:15 PM | #11 |
Rep 240
I had mine working 100%, even those zones work and you can also display efficient dynamics there if you want. You would just turn it off in the nav screen, which requires coding the cluster and Navigation unit.
You have to take the two EPROM chips from your cluster and move them to M5, that's step one. Then all else is coding, it can be done for sure. |
