2010 2011 BMW 5 Series Forum F10 Wheel and tire fitment question for '15 535I |
03-06-2024, 03:08 PM | #1 |
Rep 64
Hello,
I am looking at the following wheels and tires for my 2015 535i RWD. Will these fit and not cause rubbing issues? Wheel Size: BBS CI-R Front: 20x9 ET+25 5x120 Rear: 20x10.5 ET+35 5x120 Tire Size: Michelin Pilot Sport 4S (PS4S) Front: 265/35/20 Rear: 295/30/20 Thanks! Last edited by Duck70; 04-09-2024 at 07:13 PM.. |
03-07-2024, 12:01 PM | #2 |
Rep 29,203
Those are some wide tires. I wouldn’t go bigger than 255/35/20 in the front and 285/30/20 in the rear.
Duck708.00 |
03-07-2024, 01:01 PM | #3 | |
Rep 64
You think that the 295 with that offset would rub? Basically I have my eyes on very lightly used set of BBS CI-R with tires. The only way I could justify it is if I don't need to purchase new tires (tires only have like 3k miles on them currently) |
03-07-2024, 03:00 PM | #4 | |
Rep 29,203
Duck708.00 |
03-08-2024, 02:57 AM | #5 |
Rep 2,352
My front wheels are 20mm offset with a 245mm wide tyre and they fit quite aggressively in the arch, so I think a 275mm wide tyre will be too wide with a 25mm offset. I'd say 255mm at the front would be better.
For the rear, I've seen reports of 295mm tyres on 34mm offset wheels rubbing so I'd expect your 35mm offset wheels would also create rubbing as Remmib said. So again drop down to a 285mm and you'll be fine.
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
Duck708.00 |
03-19-2024, 12:04 AM | #7 |
Rep 2,595
Your front tires will be rubbing on the front wheel carriers. Will not fit.
2015 BMW 535xi
03-19-2024, 08:14 AM | #8 |
Rep 113
My 255's on my 9" wide are perfectly square to the rim. 275 would bulge out a bit I would think. I really wish i would have gone a bit narrower in the front but trying to maintain the same tire height was more important for my setup. I do love the 295's in the rear!!
03-19-2024, 02:27 PM | #9 |
Rep 64
Yeah that is my concern. Do you think I could just put some 255's on those front 9" wheels and that would work?
03-19-2024, 02:30 PM | #10 |
Rep 64
03-19-2024, 07:54 PM | #11 |
Rep 74
Duck70….. did you put your BBS 295mm ET35 10.5” wheels on the rear yet, would be curious about your experience.
I have just bought a set of Vorsteiner 102s that are 10.5” ET34 in the rear but have not yet fitted them. I’d like to go 295mm if possible. Anyone know if 285s would look stretch on these rims? Or whether the 295s will fit ok? |
03-21-2024, 06:50 AM | #12 | |
Rep 113
03-22-2024, 04:40 PM | #13 |
Rep 64
03-25-2024, 10:16 PM | #15 |
Rep 64
DementedF10162.00 |
