2010 2011 BMW 5 Series Forum F10 BMW F10 strange whistling noise while speeding up. |
04-04-2024, 05:53 AM | #1 |
Rep 6
Model: BMW F10 535I
Problem: while speeding up from stationary strange whistling can be heard, outside of car too. Could this be a problem or just a turbo noise that's normal? Adding YouTube video of the sound: https://youtube.com/shorts/ChJX7I7i9l0?feature=shared |
04-04-2024, 06:44 AM | #3 |
Rep 6
04-04-2024, 08:09 AM | #5 |
Rep 6
04-04-2024, 09:38 PM | #7 |
Rep 132
I searched what you described and others have had this problem but unfortunately there are no conclusive findings. Some suggested to turn off the AC/ fan off, other one to switch center register between warm and cold settings. Last one is if you oil fill cap off. do you hear it.
https://www.google.com/search?q=BMW+...t=gws-wiz-serp |
04-05-2024, 02:23 AM | #8 | |
Rep 6
04-05-2024, 06:24 AM | #9 |
Rep 88
Open the hood, remove the engine cover, start the engine, and see if you can hear it even faintly coming from the pcv in the valve cover. I had a b58 that sounded like this, wound up being a bad pcv diaphragm. Sadly if it’s bad on yours you’ll need to replace the entire valve cover. The b58 also had white smoke from the exhaust at idle with it.
04-05-2024, 08:17 AM | #10 |
DIY Mechanic
78
Rep 130
Drives: 2012 BMW 535i xDrive
Any type of whistling might be coming from the PCV. You could do the flame test or you could also test to see how much vacuum it has and see if it holds.
You can live in a car but you can’t race a house.
04-05-2024, 10:29 AM | #11 |
Rep 52
Drives: '15 535i xDrive M-Sport, E30
Do you still hear this noise if revving the engine while stationary in Park or Neutral?
04-05-2024, 02:33 PM | #12 |
Rep 6
