03-23-2012, 11:41 AM | #1 |
![]() ![]() 1153
Rep 3,815
BMS Jack Pad Adapter - Review
I just received my BMS Jack Pad Adapter. Their website doesn't list the F10 fitment, but the BMS guys said it should fit. The width and length are 1/4" and 1/8" smaller than the F10's jack pad cavity. However, the height is perfect and the circular base doesn't touch the edge of the plastic jack pad (which is good, so you can't tear up the jack pad while jacking the car up). Just wrap the adapter with 1/8" worth of electrical tape if you want a tight fit, otherwise it should work just fine out of the box. BMS says it should be a loose fit anyways.
I used this on my 535i and E70 without any modification (electrical tape mod). It worked perfectly. This is a made from solid anodized black biillet aluminum and made in the U.S. of A. I highly recommend this product for our F10s, especially with the 3T jack from Harbor Freight tools. ![]() Last edited by JNoSol; 05-06-2012 at 10:26 PM. |
03-23-2012, 04:32 PM | #2 |
![]() ![]() 80
Rep 1,347
Drives: 2011 E92 335 M-Sport
How much is this?
03-23-2012, 05:33 PM | #4 |
![]() ![]() 1153
Rep 3,815
$19 + $7 shipping.
http://burgertuning.com/BMW_jack_pad_adapter.html |
03-23-2012, 05:34 PM | #5 |
![]() ![]() 1153
Rep 3,815
03-23-2012, 05:41 PM | #6 |
![]() ![]() 80
Rep 1,347
I've just been using this. Seems to work but obviously this is a better fit.
03-23-2012, 05:47 PM | #7 |
![]() ![]() 1153
Rep 3,815
Nice setup. I've seen guys making these with a hockey puck.
![]() With the BMS Jack Pad Adapter, the circular base will not touch the plastic jack pad (about 1/16" gap). This will relieve stress off the edge of the plastic jack pad, which cracked on me w/o this solution. |
03-23-2012, 05:48 PM | #8 | |
![]() ![]() 80
Rep 1,347
03-23-2012, 06:30 PM | #9 |
![]() ![]() 1153
Rep 3,815
You don't have to modify it, I just like it snugged. BMS says it's meant to have a little play in fitment. Reverse Logic's seems to be a 2 piece, while BMS is a single block of Billet Aluminum. They both will work just fine.
03-23-2012, 06:45 PM | #10 |
![]() ![]() 80
Rep 1,347
The color threw me off. I thought the BMS was rubber, didn't realize it was anodized aluminum. Definitely need to get two of these, as I have 2 floor jacks and 2 Bimmers.
03-23-2012, 08:42 PM | #11 |
![]() 112
Rep 2,050
03-24-2012, 09:02 AM | #12 |
![]() ![]() 1153
Rep 3,815
05-06-2012, 10:25 PM | #13 |
![]() ![]() 1153
Rep 3,815
By the way, I used this on my 535i and E70 for oil changes without any modification (electrical tape mod, as originally thought). It worked perfectly.
04-26-2015, 06:07 PM | #15 |
![]() 1
Rep 28
Drives: 2014 F10 LCI 535i M-Sport 6MT
These jack pad adapters are great for initially lifting the car with a floor jack, but where exactly do you place the jack stands? Do you put them just fore and aft of the jack pads where the plastic underbody fairing is flat against the underside of the rocker panel, or is there another place? I've checked here and on YouTube and can't find any how-to's for the proper lifting points on an F10/F11. All I find is how to lift the car with a floor jack using the jack pads. Thanks to anyone who knows.
Current stable:
2002 Nissan Pathfinder SE 4WD 5MT 2004 Mazda 6S Wagon 5MT 2014 BMW 535i M-Sport 6MT Former: 2011 BMW 535i 6MT / 2012 BMW 550i Sport 6MT |
04-26-2015, 10:44 PM | #16 | |
![]() ![]() 1153
Rep 3,815
Daily: G12 750 MSPORT / F30 340 MSPORT On Order: 991.2 GT3
Tags |
adapter, bms, jack pad |
