2010 2011 BMW 5 Series Forum F10 BIMMERPOST Universal Forums Off-Topic Discussions Board Photography/Videography The Night Photography Thread
Reply
      05-02-2012, 09:48 AM   #1101
The1
Drives: white 135
that's good though, since you're in the night photography thread and have big skies where you are, you can get lightning shots
The1 is offline   Canada
      05-03-2012, 10:02 PM   #1102
The1
Drives: white 135
some interesting skies tonight.
hope you like, its sort of my first time shooting lightning, so any advice is more then welcome. (when I say sort of, I once tryed and quickly gave up because i didn't have patients)
      05-03-2012, 10:23 PM   #1103
TL
TL's Avatar
Drives: Happy on H&R coil overs
2008 335xi  [0.50]
cools shots, can't say i have ever been able to capture lightning....one of these days i'll take the time
TL is offline   United_States
      05-03-2012, 10:26 PM   #1104
Weebl
Weebl wobbles but eats Pie
Drives: 2008 335i, 2000 740i
Excellent. I rarely get to see lightning and it is hard to get also.
Kevin
Kevingoto.smugmug.com
2000 740i-Annalisa and 2008 335i-Weebl. Weebl may wobble but has DTC
mods HPFP,4 new injectors,1 transfer pump assembly,front wheel bearings A few E9X Nerd points
Weebl is offline   Reply With Quote
      05-03-2012, 10:33 PM   #1105
The1
Drives: white 135
it was a nice change tonight, the storms were over top and south of me, which is a little different then normal, it meant I actually got a chance to watch it from my building. Usually the neighbouring building is nicely in the way
hopefully I'll get some more chances, and next time, I'll use my 5D instead so I can get a wider shot. Not sure why I picked up the 7D, but I did, and I was stuck shooting at it's extreme when I could have gotten a lot wider otherwise. Live and learn...
      05-04-2012, 08:26 AM   #1106
dcstep
Drives: '09 Cpe Silverstone FR 6MT
2009 M3  [4.00]
There's the little matter of the 5D3 costing twice as much. Also, for most of those shots, I would have actually cropped to focus more on the lightning. The first is really great.
Still, I understand the need for a wider lens. I really like an effective 24mm. In the daytime, if you need to go wider, you can handhold multiple shots and stitch them together.
Dramatic shots. Good luck tonight.
Dave
dcstep is offline   United_States
      05-04-2012, 08:32 AM   #1107
The1
Drives: white 135
Dave
unfortunatly the hand holding for lightning is near imposible, most of those shots were between 10-15 seconds just to try and catch the lightning.
wider angle would be more just to be able to catch lightning in the sky as it's so all over the place. And then crop after.
I debated cropping more on a few of them, I may play around with a few of them some more still.
What I really should have done is just set my remote trigger and timer to just keep firing shot after shot for the entire storm and then stack any flashes I catch to get multiple flashes in one shot. Next time I guess.
      05-04-2012, 09:28 AM   #1108
dcstep
2009 M3  [4.00]
Stacking lightning shots can be very effective.
      05-04-2012, 10:34 AM   #1109
M_Six's Avatar
Drives: 2005 X5 3.0 & 2006 Z4 3.0si
2005 X5 3.0  [0.00]
2006 Z4 3.0si  [0.00]
I wonder how well it would work to use a 3 or 6-stop ND filter for shooting lightning. You could go with long shutter times without the normal surrounding lights flaring up and the lightning would still be bright enough to show up in the image.
Mark - Randomography
"The $0.99 menu was put on this Earth for a good damn reason." -Weebl
M_Six is offline   United_States
      05-04-2012, 10:38 AM   #1110
The1
Drives: white 135
I found that when I got much over about 13 seconds, the lightning started to become more faint. And if I made it to about 30 seconds, it was almost non existent. and the sky would just be lighter from all the lightning around.
seems like that 8-15 second window seems to work. Thats just my experience so far, more practice is needed, perhaps using a graduated filter upside down to dim the lights would help a bit.
I desaturated yellow to turn the heat down from some of the lights in the area which helped, and I didn't notice it change the sky at all.
      05-05-2012, 08:29 PM   #1111
WDBi
WDBi's Avatar
Drives: a car
Went to a pretty popular spot last night with a couple cars we didnt bring a tripod but i think they turned out quite well
WDBi is offline   United_States
      05-06-2012, 09:20 PM   #1112
HoustonBMWClub
^Nice pics. Do you have a tripod by any chance? Turn the exposure up and turn the iso down, will help reduce the grain....unless you're going for that kinda look
From houston? You should be on here then!
www.houstonbmwclub.com/forums
HoustonBMWClub is offline   Reply With Quote
      05-07-2012, 08:08 AM   #1113
SS32
SS32's Avatar
Drives: 2008 M3
Storms at Sand Piper by SS332, on Flickr
Mercer's Pier by SS332, on Flickr
venus rising by SS332, on Flickr
SS32 is offline   Reply With Quote
      05-07-2012, 08:29 AM   #1114
Chewy734
Drives: 2006 BMW 330i ZPP, ZSP
Send a message via AIM to Chewy734
very cool shots!
Currently for sale: N/A
Chewy734 is offline   United_States
      05-07-2012, 12:23 PM   #1115
WDBi
WDBi's Avatar
Drives: a car
i didnt have a tripod that night so they were all hand held
      05-07-2012, 10:16 PM   #1116
sourphish
Drives: '07 335i E92
Taken 2 days ago. Saw on the news the day before that it would be lunar perigee so I went out with a friend and we took some pics. Here's a few of mine. A bit soft though.
1)
2) Crazy how fast dusk fades to night from the previous picture.
3)
4) This was as sharp as I could get it...forgot to bring things to weigh down the tripod against the wind.
2007 E92 335i, 6MT, Sparking Graphite, ZPP, ZSP, Nav, Logic7
sourphish is offline   United_States
      05-07-2012, 10:31 PM   #1117
Seminole
Seminole's Avatar
Drives: Red Flyer
2008 E90 328i  [3.50]
Taken from my balcony in the Keys. Wish I knew how to make the moon stay sharp and not washed out while taking this shot. I think that would have made it 100 times better.
Florida Keys Super Moon Harbor by Seminolez, on Flickr
Seminole is offline   United_States
      05-07-2012, 10:45 PM   #1118
Weebl
GND
Kevin
      05-07-2012, 11:02 PM   #1119
sourphish
Originally Posted by Weebl View Post
GND
Yeup. I just got one...albeit a cheap Cokin one to play with
      05-31-2012, 12:00 AM   #1120
fluidkaos
It's like Chaos, only smoother.
fluidkaos's Avatar
Drives: like a madman.
2010 E92 335i  [4.87]
Work and school had me a little delayed on processing pictures, but here is a set I did on the Bars and Pubs of Dublin's Temple Bar on St. Patrick's Day.
The Oliver St. John Gogarty
DSC_2795 by FluidKaos, on Flickr
The Auld Dubliner
DSC_2787 by FluidKaos, on Flickr
The Quays Bar
DSC_2776-9 by FluidKaos, on Flickr
The Temple Bar
DSC_2757-68 by FluidKaos, on Flickr
Farrington's
DSC_2748-56 by FluidKaos, on Flickr
The Porterhouse Brewing Company
DSC_2739-44 by FluidKaos, on Flickr
And one of the Supreme Court House, just because night-time
DSC_2730 by FluidKaos, on Flickr
fluidkaos is online now   No_Country
      06-01-2012, 02:56 PM   #1121
Chewy734
nice pics!
      06-01-2012, 10:54 PM   #1122
The1
Drives: white 135
Originally Posted by Chewy734 View Post
nice pics!
Reply
Forum Jump
