2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes OEM 351 M sport wheels?
      08-19-2012, 08:10 PM   #1
bmellion
bmellion's Avatar
Drives: 2014 M5 Comp Pack, Dinantronic
Hi all..I just purchased a new 2012 550i M sport X drive sedan. It has 245/40 R 19's in front and back. Can I put the 275/35 R 19's in the rear on those rims. They are just skinny looking as they sit? Please advise! Will it effect the x drive system? Thanks for the help!!!
2014 BMW ///M5 Competition Pack, Dinan Stage 2, Full Eisenmann Race, MSR Intake and lots of carbon fiber...
2013 BMW X5 ///M, Dinan Exhaust, Dinan Stage 1, Dinan Suspension (gone)
2013 BMW ///M6, Eisenmann Race
2013 BMW ///M5 (gone)
      08-19-2012, 08:15 PM   #2
bobblehead
bobblehead's Avatar
Drives: warp speed
No. better check what's the width of the rear rim comes in at.
You need 9 (width) to fit 275
      08-19-2012, 10:58 PM   #3
gatoman39
gatoman39's Avatar
Drives: 2011 E92 335 M-Sport
Correct. The OP's width is 8.5. The 275/35/19 tire may fit, but it will look odd on the rim. Not to mention it's not needed. It won't affect the X-Drive system, but it will negatively affect, your wallet. You'll get worse gas mileage and the car will likely be slight slower and the speedo will be off.
      08-20-2012, 12:57 AM   #4
bmellion
bmellion's Avatar
Thanks all..guess that puts an end end to that!!
      08-20-2012, 01:22 AM   #5
Amleto63
Commander
Amleto63's Avatar
Italy
Drives: F10 520d Sedan
Send a message via Skype™ to Amleto63
I think so. The staggered option is allowed for sedan only.
Stay Ahead!
E46(00-03) - E46 Touring (03-06) - E90(06-10)
      08-20-2012, 01:23 AM   #6
Amleto63
Commander
Amleto63's Avatar
Italy
I mean RWD sedan
Stay Ahead!
      08-20-2012, 07:00 AM   #7
Boss330
Boss330's Avatar
Norway
855
M550d (X-drive) has staggered wheels (245/40R19 - 275/35R19).
Not sure if that goes for the other X-drive cars, but the 245/40 and 275/35 should have the same rolling circumference and should not upset the X-drive.
      08-20-2012, 07:36 AM   #8
bobblehead
bobblehead's Avatar
Drives: warp speed
x-drive for N.A. cars come with square setup (at least that's for MY2011 + 2012 ... not sure for MY2013)
      08-20-2012, 12:13 PM   #9
guelphman73
Drives: 2013 528 xDrive
MY 2013 come with square setup as well
      08-20-2012, 12:27 PM   #10
remmib
remmib's Avatar
Norway
1154
Drives: 2013 F10 520d M-Sport
Since you've got the 19x8.5 rear wheels, I wouldn't put 275/35/19 on those.
      08-20-2012, 09:38 PM   #11
bmellion
bmellion's Avatar
Do I have any options with these wheels? Or do I need to get different wheels if I want larger rear tires?
      08-21-2012, 06:47 AM   #12
bobblehead
bobblehead's Avatar
Drives: warp speed
No other option. You want wider tires, then need wider width rim (for the rear). Do remember the correct tire size too when you are changing from stock size.
      08-21-2012, 08:22 AM   #13
bmellion
bmellion's Avatar
Thank you!!
      09-06-2012, 04:25 PM   #14
GABMAN
Drives: 2016 F10 535XI Med. Blue
Would style 351 wheels that are on a 550XI fit on a 535XI? The 535XI have 8.5 x19 ET 35 , I believe the 550XI has an ET of 30 , they should also be 8.5 x19 as I am told they are a square set up. Thanks
2016 535XI Med Blue/Black Nappa, Tints, Vent Seats,
MSport Pkg,M Perf Pkg ,Prem Pkg Enhanced.
2015 535XI Carb.Black/Black RECALLED BY BMW
2012 535XI White/Black, MSport, RETIRED
2011 535I, GraphGrey/Oyster, RETIRED
      09-06-2012, 05:38 PM   #15
bobblehead
bobblehead's Avatar
Drives: warp speed
both 535xi & 550xi have the same wheels (front & rear) and thus same offset.
the 30 offset you are referring to on the 550xi is on a 18 * 8 wheel.
      09-07-2012, 07:34 AM   #16
remmib
remmib's Avatar
Norway
1154
OEM F10 wheels are ET30 for the 17x8 and 18x8, and ET33 for the 19x8.5 and 20x8.5.
      09-07-2012, 02:33 PM   #17
GABMAN
Thanks for the replies, the offsets I quoted were given to me by the parts dept at my dealer, figures that they were wrong.
