FORUMS
- 5
Anyone successfully coded F10 in the UK?
| 09-13-2012, 10:35 AM | #45 | |
Right Responsible
Drives: Sop. Grey 535d M Sport Join Date: Mar 2007
I have already got them downloaded and got my FSC code. The car is loading up USB1 as I write this ![]() Just PM me if you want my address.
Last: 330cd Sport - Silver Grey, 335d M Sport Coupe.
Current: 535d M Sport, Sophisto Grey, Oyster/Black leather, Pro Nav, Vis, and other bits. Current: X5 XDrive 35d M Sport - Black Sapphire, lots of toys. ![]() |
| 09-14-2012, 11:27 AM | #46 |
| 09-14-2012, 03:28 PM | #47 | |
PM me and we can setup some date.
~~~ 2014 535D Luxury on order, 2012 520D Saloon F10, 2009 330D Coupe E92 ~~~
| 09-18-2012, 11:28 AM | #50 |
| 09-18-2012, 04:14 PM | #51 | |
The system also detects when the car drifts over a lane.... but since my car does not have the steering wheel motor, it does not vibrate. I have found the part for the steering wheel motor and it is about £90. I am now finding a local garage/ mechanic who would fit this. The coding part is all done; all it now needs is the physical motor fitting and it should all work. So fairly close to completing ...
| 09-19-2012, 03:22 AM | #52 | |
![]() You may find the vibrating steering wheel a pain, unless you always use your indicators, guessing you won't have the switch to disable it. |
| 09-19-2012, 04:43 AM | #53 | |
My biggest problem is getting the time to do it all and tying up with a mechanic to open the steering wheel and place the motor. Will get it done eventually...
| 09-19-2012, 05:25 AM | #54 | |
Also, is it possible to retrofit heated steering wheel, without having to replace the whole steering wheel? |
| 09-19-2012, 05:53 AM | #55 | |
| 09-19-2012, 09:01 AM | #56 | |
Answers inline...
| 09-20-2012, 02:53 AM | #57 |
| 09-20-2012, 08:13 AM | #58 | |
If you have 'Speed Limit Info' or 'Active Cruise Control' then you should already have the camera. If so, the LDW can be retrofitted just by the steering wheel motor and coding. The basic requirement is the camera sensor. My car has the Speed Limit Info, but I did not choose LDW - hence this project of getting LDW working. In reality, LDW is working on my car with just coding it (even without the steering motor) - the car detects the lanes and everything ; the issue is there is no driver feedback - that happens through the steering vibrating motor.
| 09-20-2012, 08:25 AM | #59 | |
| 09-20-2012, 08:44 AM | #60 | |
| 09-20-2012, 02:08 PM | #61 |
Most likely yes, but would need testing for confirmation...
| 09-20-2012, 02:19 PM | #62 |
| 09-20-2012, 02:33 PM | #63 | |
KOMBI: 3003, TLC_VERBAUT, aktiv 3004, ST_TLC_TIMEOUT, aktiv 3004, ST_TLC_ALIVE, aktiv 3004, ST_TLC_APPL, aktiv KAFAS: 3000, TLC_START_VERSION, default_on 3000, TLC_ON_OFF, aktiv 3000, SEND_MESSAGE_327, aktiv 3000, SEND_MESSAGE_345, aktiv 3006, ACTUATOR_ON_OFF, aktiv HU_CIC: 3001, LANE_DEPARTURE_WARNING, aktiv SZL_LWS: 3000, Lenkrad_Vibration, aktiv ... let us know how it goes. If you get LDW working; then also try with SZL_LWS: 3000, Lenkrad_Vibration, nicht_aktiv .... and let us know the result. Does your car have Blind Spot Monitoring (Lane Change Warning system Option 5AG), because then you would already have the Steering wheel vibration motor?
| 10-21-2012, 06:06 AM | #64 |
Does anyone know whether it is possible to enable Active Cruise Control for the F10?
I have a highly specced car with the Auto High Beam camera/sensor and chose not to have Active Cruise Control as it seemed a pain on the motorway... but after I closed my spec someone explained that in traffic jams it is great as it drives for you if you have an auto - making the journey so much simpler. Is there an option to code? GSPANNU I am just outside Andover and have ordered an ENET cable and have ESYS and PszData 47.5 - would you like a beer(s) to show me how to code the TV, Radio and Telephone in HUD, SLI, etc I have just bought my wife an F10 which arrives October 24th and in a couple of weeks I would love to be able to mod it a little. All the best, Sam |
| 10-21-2012, 05:14 PM | #65 | |
Xenon: Could you tell me when the 2013 Maps were released? I'm having a debate with my dealer at the moment about their availability. If you could pm me with a safe source for the maps I would be grateful. Many thanks |
| 10-21-2012, 05:26 PM | #66 | |
As an aside, the LCA works well when the car is approaching in your blind spot on the drivers side, but is a pain when you overtake someone as you need to have a very large gap before you can pull in or risk loosing the feeling in your fingertips. |
| Bookmarks |
