2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Installed BMS Stage 1
      10-01-2012, 09:52 AM   #1
RambleJ
RambleJ's Avatar
Drives: F10 535i M-sport
I finally got around to installing my BMS stage 1 tune. Prior tothe install I used the USB cable and bumped the boost from +3.5 to +4.5.
Install:
Getting to 3 of the 4 plugs was rather simple, but that 2nd plug is a pain in the ass, I suggest removing the airbox and you will save a tremendous amount of time, stress and skin from the top of your hand. Aside from that the install went smoothly. Fired the car up, no codes or issues what so ever.
Diving impression:
I was only able to make a couple hard pulls but there is a very noticable difference in power. I am going to give the tune a couple days to adapt and report back. But so far this tune is definitely worth the $380
Since I have the USB cable, I plan on doing some logs later down the road to see how the car is reacting to the tune.
*I always drive in either sport or sport+
      10-01-2012, 10:08 AM   #2
dr.mba
dr.mba's Avatar
Drives: 2017 F. Grey M3 ZCP
Hey RambleJ,
I too just installed mine about a month ago. How hard is it to change the boost settings? I have been thinking about it for a few weeks now but I didnt get the USB cable. Whats the default boost? Is it 2.75 or 3.5?
MBA
      10-01-2012, 10:34 AM   #3
RambleJ
RambleJ's Avatar
Originally Posted by dr.mba View Post
Hey RambleJ,
MBA
The USB cable is definitely worth it, not only does it allow you to change some of the settings on the tune but you also have access to do some datalogging to make sure you car is running effeciently.
The stock setting on the tune I received showed 3.5 on the BMS software.
      10-01-2012, 11:09 AM   #4
iamkit
Drives: 535xi
^ question, right now I already have it installed. can i just take out the little box bring it home and update it from my computer? and then re plug the box?
      10-01-2012, 11:14 AM   #5
RambleJ
RambleJ's Avatar
I am not too sure, if I do any other updates I will just bring my laptop out to my car and make the adjustments there.
      10-02-2012, 06:58 AM   #6
Kalem
Drives: 2012 BMW 520i
http://www.n54tech.com/forums/showthread.php?t=15536
Default boost over stock should be 3.0psi, you received a unit with default 3.5psi?
2012 F10 520i
2005 E90 330i
2001 E46 328ci
      10-02-2012, 06:58 AM   #7
Kalem
2012 F10 520i
2005 E90 330i
2001 E46 328ci
      10-02-2012, 06:59 AM   #8
Kalem
2012 F10 520i
2005 E90 330i
2001 E46 328ci
      10-02-2012, 09:34 AM   #9
RambleJ
RambleJ's Avatar
The link you provided is for the N20 tune (328/528). Which is why you are seeing 3.0 over stock.
      10-02-2012, 12:14 PM   #10
iamkit
Drives: 535xi
^ is there a big difference from 3.0 to 4.5?
      10-02-2012, 12:31 PM   #11
RambleJ
RambleJ's Avatar
I honestly couldn't tell you since I jumped directly into 4.5.
      10-05-2012, 02:28 PM   #12
Alan l.
Alan l.'s Avatar
1649
Drives: 2016 F85M
Debating if i should just start out at 4.5psi right off the bat as well.... How has the car been so far?
Alan
      10-05-2012, 05:09 PM   #13
RambleJ
RambleJ's Avatar
Alan
It has been great! No complaints about it at all.
      12-05-2012, 05:25 PM   #14
Rbembas_M3
Rbembas_M3's Avatar
Drives: BMW 2011 M3
2011 BMW M3  [0.00]
I just installed the stage 1 and took it around the block, let the car warm up and jumped on it, very noticeable. I have a 6MT in sport mode, I did notice in second around 4000 rpm It seemed to starve for fuel, it feels like hitting the rev limiter. Has anyone else felt this in second gear?
      12-05-2012, 06:07 PM   #15
RambleJ
RambleJ's Avatar
Haven't experienced this. Could be because your car is still adapting to the tune.
      12-11-2012, 12:06 PM   #16
Rbembas_M3
Rbembas_M3's Avatar
Drives: BMW 2011 M3
2011 BMW M3  [0.00]
Install:
Diving impression:
Hello RambleJ,
I just received my USB and been reading up on it, have you run any logs yet? Currently I'm running stage 1 stock settings, so running boost 4.5 is running well for you? Do you have a manual 6 speed or auto? Did you change any other settings? thanks....
      12-11-2012, 12:13 PM   #17
RambleJ
RambleJ's Avatar
Hello RambleJ,
I have not ran any logs yet. I was thinking about it not too long ago, but haven't gotten around to it.
I only modified the boost amount and left everything else as is. And I have SAT
      12-11-2012, 12:27 PM   #18
Rbembas_M3
Rbembas_M3's Avatar
Drives: BMW 2011 M3
2011 BMW M3  [0.00]
I was reading that there is a bogfix setting for auto or manual. most likely defaults to Auto.
I will play this evening, it seems pretty straight forward loading the firmware and interfacing. So honestly how much hp do you think you have gained?
      12-11-2012, 12:57 PM   #19
RambleJ
RambleJ's Avatar
Id say about 30hp/45-50tq
      12-11-2012, 01:07 PM   #20
Rbembas_M3
Rbembas_M3's Avatar
Drives: BMW 2011 M3
2011 BMW M3  [0.00]
Yeah i was thinking that too, thanks for your help.
      12-11-2012, 11:45 PM   #21
bulldog x6
bulldog x6's Avatar
45
Drives: '16 MB GLE
are you running 91 octane or higher?
      12-12-2012, 07:31 AM   #22
Rbembas_M3
Rbembas_M3's Avatar
Drives: BMW 2011 M3
2011 BMW M3  [0.00]
Yes I'm running 91 and just changed my boost to 4.5
