10-01-2012, 09:52 AM | #1 |
![]() ![]() -79
Rep 2,014
Installed BMS Stage 1
I finally got around to installing my BMS stage 1 tune. Prior tothe install I used the USB cable and bumped the boost from +3.5 to +4.5.
Install: Getting to 3 of the 4 plugs was rather simple, but that 2nd plug is a pain in the ass, I suggest removing the airbox and you will save a tremendous amount of time, stress and skin from the top of your hand. Aside from that the install went smoothly. Fired the car up, no codes or issues what so ever. Diving impression: I was only able to make a couple hard pulls but there is a very noticable difference in power. I am going to give the tune a couple days to adapt and report back. But so far this tune is definitely worth the $380 Since I have the USB cable, I plan on doing some logs later down the road to see how the car is reacting to the tune. *I always drive in either sport or sport+ |
10-01-2012, 10:08 AM | #2 |
![]() ![]() ![]() ![]() ![]() 261
Rep 719
Hey RambleJ,
I too just installed mine about a month ago. How hard is it to change the boost settings? I have been thinking about it for a few weeks now but I didnt get the USB cable. Whats the default boost? Is it 2.75 or 3.5? MBA |
10-01-2012, 10:34 AM | #3 | |
![]() ![]() -79
Rep 2,014
The stock setting on the tune I received showed 3.5 on the BMS software. |
10-01-2012, 11:14 AM | #5 |
![]() ![]() -79
Rep 2,014
I am not too sure, if I do any other updates I will just bring my laptop out to my car and make the adjustments there.
10-02-2012, 06:58 AM | #6 |
![]() 3
Rep 37
http://www.n54tech.com/forums/showthread.php?t=15536
Default boost over stock should be 3.0psi, you received a unit with default 3.5psi?
2012 F10 520i
2005 E90 330i 2001 E46 328ci |
10-02-2012, 06:58 AM | #7 |
![]() 3
Rep 37
2012 F10 520i
10-02-2012, 06:59 AM | #8 |
![]() 3
Rep 37
2012 F10 520i
10-02-2012, 09:34 AM | #9 |
![]() ![]() -79
Rep 2,014
10-05-2012, 05:09 PM | #13 |
![]() ![]() -79
Rep 2,014
12-05-2012, 05:25 PM | #14 |
![]() ![]() ![]() ![]() 34
Rep 493
Drives: BMW 2011 M3
I just installed the stage 1 and took it around the block, let the car warm up and jumped on it, very noticeable. I have a 6MT in sport mode, I did notice in second around 4000 rpm It seemed to starve for fuel, it feels like hitting the rev limiter. Has anyone else felt this in second gear?
12-05-2012, 06:07 PM | #15 | |
![]() ![]() -79
Rep 2,014
12-11-2012, 12:06 PM | #16 | |
Rep 493
Drives: BMW 2011 M3
I just received my USB and been reading up on it, have you run any logs yet? Currently I'm running stage 1 stock settings, so running boost 4.5 is running well for you? Do you have a manual 6 speed or auto? Did you change any other settings? thanks.... |
12-11-2012, 12:13 PM | #17 | |
![]() ![]() -79
Rep 2,014
I only modified the boost amount and left everything else as is. And I have SAT |
12-11-2012, 12:27 PM | #18 | |
Rep 493
Drives: BMW 2011 M3
I will play this evening, it seems pretty straight forward loading the firmware and interfacing. So honestly how much hp do you think you have gained? |
12-11-2012, 12:57 PM | #19 |
![]() ![]() -79
Rep 2,014
Id say about 30hp/45-50tq
12-11-2012, 01:07 PM | #20 |
Rep 493
Drives: BMW 2011 M3
12-12-2012, 07:31 AM | #22 |
Rep 493
Drives: BMW 2011 M3
Yes I'm running 91 and just changed my boost to 4.5
