2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Wheel Help!!
      11-01-2012, 07:46 PM   #1
aman27
Drives: 2016 F15 x35i MSport
Will these configuration wheels fit my 2012 535 xdrive M sport??
BMW F10 5-Series Genuine Style 332 W Spoke Gloss-Turned Wheel Set and tires
The tires are michelin primacy hp run flats. the fronts are 245/40/19 and rears are 275/35/19.
Front Wheels - 8.5JX19 ET:33
Rear Wheels - 9JX19 ET:44
      11-01-2012, 09:03 PM   #2
wdimagineer
wdimagineer's Avatar
Drives: 2015 X5 M
Should fit perfectly.
Current: 2015 X5 M - Donington Grey/Mugello Red - DINANTRONICS Stage 2 + Free Flow Exhaust - Bimmerpost Featured!
Past: Bimmerpost Featured 2014 X5 xDrive50i 2014 Jeep SRT 2013 Tesla Model S P85+ Bimmerpost Featured 2013 F10 M5 2012 550 xDrive 2011 M3 ZCP
      11-01-2012, 09:05 PM   #3
zms
Drives: F10-550ix-2011-Carbon Black
What are the original (factory) wheels/tires specs that came with your car?
Basically, your new set "rolling diameter" needs to stay within <=3% (preferablly <1%) of the original set, moreover-especially with xDrive-the difference between the rolling diameter of the new Front set compared to the new rear set should optimally stay below 1%.
Here is a good tire size calculator that I have been using for that purpose:
http://tires.about.com/gi/o.htm?zi=1.../tirecalc.html
      11-02-2012, 12:06 AM   #4
aman27
Basically, your new set "rolling diameter" needs to stay within &lt;=3% (preferablly &lt;1%) of the original set, moreover-especially with xDrive-the difference between the rolling diameter of the new Front set compared to the new rear set should optimally stay below 1%.
My stock sizes are 245 40 19 i believe the rims are 19x8 or 8.5non staggered setup due to the xdrive. Historically, on the e60s the staggered 19x8.5 (front) 19x9(rear) setup would not fit or was not rec due to rubbing or what not but i am not sure about the F10s.
      11-02-2012, 01:52 AM   #5
zms
Specs for your new tires will fit. For the rim size, refer to this thread: http://f10.5post.com/forums/showthread.php?t=762275
He has like your car with similar rim specs, you might want to confirm with him.
      11-02-2012, 09:46 AM   #6
nolfM6
Drives: 2009 E63 M6
Should fit perfect and that's a really good deal. Figuring from BMW they'll be around $4k without tires and sensors.
      11-02-2012, 06:39 PM   #7
aman27
Seems like he has 19x8.5 and 19x9.5 as opposed to my set which for rears has 19x9
      11-03-2012, 02:03 AM   #8
zms
This means if he was able to fit a wider rim than yours in his car then your configuration will fit perfectly!
Enjoy!
      11-03-2012, 02:34 PM   #9
remmib
remmib's Avatar
Norway
1154
Drives: 2013 F10 520d M-Sport
The F10 xdrive has the same fitment as F10 rwd, unlike the e60.
So those 332 will fit your car, no problem.
      11-04-2012, 11:56 AM   #10
aman27
Thanks thats the answer i was looking for. So why dont they give you a staggered setup on an M-Sport car ?
      11-04-2012, 12:03 PM   #11
remmib
remmib's Avatar
Norway
1154
Here in Norway, and the rest of Europe I guess, you get staggered wheels on m-sport F10 xdrive.
