2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Installed BMS Stage 1
      12-12-2012, 10:55 AM   #23
RambleJ
RambleJ's Avatar
Drives: F10 535i M-sport
Originally Posted by bulldog x6 View Post
are you running 91 octane or higher?
I am running 93.
Rbembas, if you are running 91 I would highly suggest running some logs shortly after the tune adapts to make sure that the level of boost is running fine on 91octane.
      12-12-2012, 02:29 PM   #24
Rbembas_M3
Rbembas_M3's Avatar
Drives: BMW 2011 M3
2011 BMW M3  [0.00]
Originally Posted by RambleJ View Post
I am running 93.
I made a mistake I'm running 93 mostly Shell , but still I'll run some logs this
weekend. I did change the boost to 4.5 this morning, ran great just too much traffic here in Atlanta this monrinig to run it.
      12-20-2012, 08:24 AM   #25
Rbembas_M3
Rbembas_M3's Avatar
Drives: BMW 2011 M3
2011 BMW M3  [0.00]
Been running stage 1 for a couple of weeks now anyone getting drive train malfunction CEL?
      12-20-2012, 09:43 AM   #26
RambleJ
RambleJ's Avatar
Nope, you might want to check the connections to make sure something isn't loose. To stash the piggy box where the site shows is quite a tight pull to get it overthere. I usually go in and squeeze the plugs every couple weeks to make sure nothing is coming loose.
      12-20-2012, 10:25 AM   #27
Rbembas_M3
Rbembas_M3's Avatar
Drives: BMW 2011 M3
2011 BMW M3  [0.00]
Thanks I check them out and yes it tight.
      12-20-2012, 10:26 AM   #28
Alan l.
Alan l.'s Avatar
1651
Drives: 2016 F85M
Running 93octane exclusively and the car has been CEL free for over 1200 miles with plenty of full throttle/redline shifts.
Alan
      12-20-2012, 11:59 AM   #29
RambleJ
RambleJ's Avatar
Is the malfunction consistent or did it just happen once?
      12-20-2012, 01:35 PM   #30
Rbembas_M3
Rbembas_M3's Avatar
Drives: BMW 2011 M3
2011 BMW M3  [0.00]
It's happened a couple of times now the first time was when I had stage two running. Now. I'm running stage one now and have had drive train malfunction pops up a few times now.
      12-20-2012, 02:19 PM   #31
omer
Drives: 2016 M
How do you drive on sport plus? There's only sport on 535 msport
      12-20-2012, 03:16 PM   #32
Alan l.
Alan l.'s Avatar
1651
Drives: 2016 F85M
sounds like theres an issue with the car. Could be your fuel pump going etc..
I'd remove the tune and let the dealer fix it.
Alan
      12-20-2012, 04:03 PM   #33
RambleJ
RambleJ's Avatar
Alan
Exactly, remove the tune and see if you can replicate it tuneless. If not, it could be an issue with the tune.
      12-20-2012, 05:51 PM   #34
Rbembas_M3
Rbembas_M3's Avatar
Drives: BMW 2011 M3
2011 BMW M3  [0.00]
Thanks guys will do that this weekend. My service tech did tell me that there are issues with the fuel pump and tested it about three weeks ago when I had my car in for 27000 check up. Everything was okay and they didn't know that I've been running a tune. I did take it off before I took it in, they never mention drive train malfunction that stage two caused.
