2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications M5 Exhaust on a 2012 550i M Sport?
Reply
      12-10-2012, 11:05 PM   #1
SoCalKid
SoCalKid
SoCalKid's Avatar
Drives: 2012 BMW 550i M-Sport
Need some technical insight. Will the exhaust system (cat back) from a 2012 M5 fit on a 2012 550 M Sport? Thanks in advance.
____________________
2012 BMW 550i M-Sport, Carbon Black Metalic, AC Schnitzer springs, 20" M-5 wheels...more upgrades to come.
SoCalKid is offline   United_States
      12-11-2012, 02:23 AM   #2
EV0LVE
EV0LVE's Avatar
Drives: F10 535i SG
It can be done...
http://f10.5post.com/forums/showthread.php?t=752054
EV0LVE is offline   Reply With Quote
      12-11-2012, 02:58 PM   #3
SoCalKid
SoCalKid
SoCalKid's Avatar
Originally Posted by EV0LVE
I appreciate the feedback. I saw this post, but from what I can tell he only installed the M5 mufflers, not the complete cat-back system, which is what I'm contemplating. Local BMW dealer says they can't find the dimensions of '13 M5 exhaust system nor my '12 550i, so they can't say whether it will work or not. Frustrating.
      12-30-2012, 01:11 AM   #4
mdrobc13
mdrobc13's Avatar
Drives: '12 BMW 550i
2012 BMW 550i  [5.00]
Send a message via MSN to mdrobc13 Send a message via Yahoo to mdrobc13
It should fit. Remember that the engine in the F10 550i is basically the same engine as the F10 M5 but detuned so the diameter of the exhaust should be the same pipe wise as both are V8's. Changes are likely due cat back and muffler back on the M5 vs 550i. However since someone has already easily retrofitted the M5 mufflers into their 550i and used the OEM rear valence it should NOT be too easy to do the full system. Check around some more and I am sure you'll find a willing shop/tuner shop. Dealer will likely balk tho as if anything goes wrong they won't want the blame..however it does depend on your relationship with them tho. Good luck and keep us posted.
'12 F10 550i (DGM-II - Dinan Stage 4/Intercoolers & Shockware, H&R Springs, Eisenmann Race Exhaust, Hamman CF rear difuser, Giovanni "Lindo" Graphite 20")
'10 e71 X6 35iDrive SAV (Space Gray) - Gone
'06 e85 Z4 M Roadster (Black Metallic) -Gone
'08 e92 M3 coupe (Sparkling Graphite) -Gone
mdrobc13 is offline   United_States
Reply
Forum Jump
