2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications 535i Stock Exhaust Tip Size
Reply
      01-01-2013, 02:47 AM   #1
hufington
BMW Driver since '89 BMW E30 M3 non-cat (147 kW)
hufington's Avatar
Drives: 2013 535i
Does anyone know the diameter of the stock 535i exhaust tip? Thanks.
2013 BMW F10 535i - 3.0 L 221 kW (300 hp)
2007 BMW E64 630i - 3.0 L 200 kW (272 hp)
2003 BMW E65 745i - 4.4 L V8, 242 kW (325 hp)
1995 BMW E34 540i - 4.0 L V8 210 kW (282 hp)
1989 BMW E30 M3 non-cat version 147 kW (200 hp)
hufington is offline   United_States
      01-01-2013, 01:55 PM   #2
Mr. Grumpy
BMW FREAK
Mr. Grumpy's Avatar
Drives: 2011 535i, 2009 Ninja ZX-14
3"
2011 535i (07/2011 build) Imperial Blue, Oyster/Black Interior, Anthracite Wood Trim, ZPP, ZP2, ZCV, ZSP, 2TB, 6NF, 6NR.
Retired: 2009 328i, Titanium Silver, Black Interior, Dark Wood Trim, ZPP, ZLP, 609, 494.
Mr. Grumpy is offline   United_States
      01-01-2013, 02:29 PM   #3
hufington
hufington's Avatar
Drives: 2013 535i
Thanks. Are they welded or clamped on? My car is still 25 days away but I am trying to figure out what I can do with the tips.
      01-01-2013, 03:39 PM   #4
VWtoBMW
VWtoBMW's Avatar
Drives: 2012 535i xDrive M-Sport
2012 535i xDrive  [5.00]
2009 BMW 328i  [0.00]
They are clamped/screwed on
2012 F10 535i M-Sport
http://www.e90post.com/forums/image.php?type=sigpic&userid=72995&dateline=130825  4452
VWtoBMW is offline   Canada
      01-01-2013, 10:39 PM   #5
Sharbotcom
Sharbotcom's Avatar
Drives: 2011 535xi M Sport
They are 3" with a 2 1/4" inlet. They are welded on not clamped.
2011 535i xDrive, Dark Graphite Metallic, Veneto Beige Dakota Leather, Technology Package, M Sport Package, Executive Package delivered Christmas Eve '10, Mods - quad tips, 20% tint, JB4.
Sharbotcom is offline   Canada
      01-01-2013, 11:03 PM   #6
hufington
hufington's Avatar
Drives: 2013 535i
I will start looking for some larger (4"-5") chrom tips with 2 1/4" inlet that can be welded. I don't want any added noise and will go for cosmetic change only.
      01-01-2013, 11:05 PM   #7
Sharbotcom
Sharbotcom's Avatar
Have you considered going quad tip? A lot of the guys have done that with great results (me included see: http://f10.5post.com/forums/showthread.php?t=685790).
      01-01-2013, 11:13 PM   #8
hufington
hufington's Avatar
Drives: 2013 535i
Quads look awesome, but I don't know any good shops here in NJ, that can install quads and cut the diffuser perfectly.
      01-02-2013, 05:36 PM   #9
Mr. Grumpy
BMW FREAK
Mr. Grumpy's Avatar
Please keep us informed on this mod. I've been thinking of switching to a 4" Crome tips and replacing the center silencer (resonator) for a cross pipe for a better exhaust sound.
      01-02-2013, 05:44 PM   #10
hufington
hufington's Avatar
Drives: 2013 535i
Will do.
      01-03-2013, 01:36 PM   #11
2005x
Drives: 2005 X5
I believe you can get the 550 Diffuser(which has a bigger opening)and you won't need to cut anything(all depending of course on the size of the tips you get). anything over 4" would look ridiculous on a stock 5 series. Also you can get the m5 diffuser but then you will need to modify the mufflers and possibly move them back as the tips will stick out to much. Do keep in mind the length of the tips, as most aftermarket tips are way longer than factory.
2005x is offline   Reply With Quote
      01-03-2013, 01:39 PM   #12
Sharbotcom
Sharbotcom's Avatar
From what I remember the diffuser only works with msport bumpers. So if the OP has msport he is good to go otherwise I think you need to cut or change the bumper. Someone please correct ot verify my statement.
      01-03-2013, 03:46 PM   #13
Mr. Grumpy
BMW FREAK
Mr. Grumpy's Avatar
You are correct, the only way to change the diffuser is if you have the M-sport package. Judging by the op's avatar picture it looks like he doesn't have that option.
      01-03-2013, 04:26 PM   #14
hufington
hufington's Avatar
Drives: 2013 535i
How about the standard 550 non-Msport diffuser? How wide is the opening for the oval standard tips?
      01-03-2013, 04:41 PM   #15
Mr. Grumpy
BMW FREAK
Mr. Grumpy's Avatar
IMHO if you're going to spend money buying the 550 rear bumper might as well buy the M-sport so you can change diffusers when ever you want to. For what I've seen the 550 bumper can accommodate a dual exhaust tips with no problem but I don't know the dimensions for the exhaust opening.
      01-03-2013, 05:02 PM   #16
hufington
hufington's Avatar
Drives: 2013 535i
Logical. As much as I love the front bumper design, I am not a fan of the rear M-Sport bumper though. That's why I am trying to find a way around it.
And i have just seen the eisenmann double 102mm (4") exhaust setup online and the single 4" tips on each side looked too bulky. Maybe because it was a touring.
      04-29-2013, 03:34 AM   #17
shihwei
Drives: F10 520d
Can someone please help me verify whether F10 exhaust tips are clamped/screwed on or welded on? I got confused by the discussion in this thread. (and according to realoem, 535i looks like it has slip on tips.) Also anyone know where I can find inlet diameters to all other F10 models? Thanks in advance.
shihwei is offline   Reply With Quote
      04-29-2013, 10:14 AM   #18
Mr. Grumpy
BMW FREAK
Mr. Grumpy's Avatar
It depends on the model. The 550i are welded, the 535i are slip on. On the 520d it looks like it might be slip on's.
I removed the tips on my 535 by twisting it and the pulling it, they're only secure by 3 pressure clamps.
      04-29-2013, 10:55 AM   #19
hufington
hufington's Avatar
Drives: 2013 535i
Do you know the length of the tips?
      04-29-2013, 06:40 PM   #20
Sharbotcom
Sharbotcom's Avatar
Let's make sure we are talking apples and apples. The exhaust tips (covers) are clipped on to the tail pipes (slides over) on the 535 but the tail pipes are welded on to the muffler. So if you are going to replace the singles with doubles you will need to cut the tail pipes off and weld the dual tips on. If you were swapping the chrome (or black) tips (covers) then they can be twisted on and off.
Reply
Forum Jump
