FORUMS
- 5
| 01-01-2013, 02:47 AM | #1 |
BMW Driver since '89 BMW E30 M3 non-cat (147 kW)
Drives: 2013 535i Join Date: Mar 2010
535i Stock Exhaust Tip Size
Does anyone know the diameter of the stock 535i exhaust tip? Thanks.
2013 BMW F10 535i - 3.0 L 221 kW (300 hp)
2007 BMW E64 630i - 3.0 L 200 kW (272 hp) 2003 BMW E65 745i - 4.4 L V8, 242 kW (325 hp) 1995 BMW E34 540i - 4.0 L V8 210 kW (282 hp) 1989 BMW E30 M3 non-cat version 147 kW (200 hp) |
| 01-01-2013, 01:55 PM | #2 |
BMW FREAK
Drives: 2011 535i, 2009 Ninja ZX-14 Join Date: Mar 2010
3"
![]() 2011 535i (07/2011 build) Imperial Blue, Oyster/Black Interior, Anthracite Wood Trim, ZPP, ZP2, ZCV, ZSP, 2TB, 6NF, 6NR. Retired: 2009 328i, Titanium Silver, Black Interior, Dark Wood Trim, ZPP, ZLP, 609, 494. |
| 01-01-2013, 02:29 PM | #3 |
Thanks. Are they welded or clamped on? My car is still 25 days away but I am trying to figure out what I can do with the tips.
| 01-01-2013, 03:39 PM | #4 |
![]() ![]() ![]() ![]() Drives: 2012 535i xDrive M-Sport Join Date: Aug 2009
They are clamped/screwed on
2012 F10 535i M-Sport
| 01-01-2013, 10:39 PM | #5 |
![]() ![]() Drives: 2011 535xi M Sport Join Date: Oct 2010
They are 3" with a 2 1/4" inlet. They are welded on not clamped.
2011 535i xDrive, Dark Graphite Metallic, Veneto Beige Dakota Leather, Technology Package, M Sport Package, Executive Package delivered Christmas Eve '10, Mods - quad tips, 20% tint, JB4.
| 01-01-2013, 11:03 PM | #6 |
I will start looking for some larger (4"-5") chrom tips with 2 1/4" inlet that can be welded. I don't want any added noise and will go for cosmetic change only.
| 01-01-2013, 11:05 PM | #7 |
Have you considered going quad tip? A lot of the guys have done that with great results (me included see: http://f10.5post.com/forums/showthread.php?t=685790).
| 01-01-2013, 11:13 PM | #8 | |
| 01-02-2013, 05:36 PM | #9 |
BMW FREAK
Please keep us informed on this mod. I've been thinking of switching to a 4" Crome tips and replacing the center silencer (resonator) for a cross pipe for a better exhaust sound.
| 01-02-2013, 05:44 PM | #10 | |
| 01-03-2013, 01:36 PM | #11 |
I believe you can get the 550 Diffuser(which has a bigger opening)and you won't need to cut anything(all depending of course on the size of the tips you get). anything over 4" would look ridiculous on a stock 5 series. Also you can get the m5 diffuser but then you will need to modify the mufflers and possibly move them back as the tips will stick out to much. Do keep in mind the length of the tips, as most aftermarket tips are way longer than factory.
| 01-03-2013, 01:39 PM | #12 | |
| 01-03-2013, 03:46 PM | #13 |
BMW FREAK
You are correct, the only way to change the diffuser is if you have the M-sport package. Judging by the op's avatar picture it looks like he doesn't have that option.
| 01-03-2013, 04:26 PM | #14 | |
| 01-03-2013, 04:41 PM | #15 |
BMW FREAK
IMHO if you're going to spend money buying the 550 rear bumper might as well buy the M-sport so you can change diffusers when ever you want to. For what I've seen the 550 bumper can accommodate a dual exhaust tips with no problem but I don't know the dimensions for the exhaust opening.
| 01-03-2013, 05:02 PM | #16 |
Logical. As much as I love the front bumper design, I am not a fan of the rear M-Sport bumper though. That's why I am trying to find a way around it.
And i have just seen the eisenmann double 102mm (4") exhaust setup online and the single 4" tips on each side looked too bulky. Maybe because it was a touring.
| 04-29-2013, 03:34 AM | #17 |
Can someone please help me verify whether F10 exhaust tips are clamped/screwed on or welded on? I got confused by the discussion in this thread. (and according to realoem, 535i looks like it has slip on tips.) Also anyone know where I can find inlet diameters to all other F10 models? Thanks in advance.
| 04-29-2013, 10:14 AM | #18 |
BMW FREAK
It depends on the model. The 550i are welded, the 535i are slip on. On the 520d it looks like it might be slip on's.
I removed the tips on my 535 by twisting it and the pulling it, they're only secure by 3 pressure clamps.
| 04-29-2013, 10:55 AM | #19 |
Do you know the length of the tips?
| 04-29-2013, 06:40 PM | #20 |
Let's make sure we are talking apples and apples. The exhaust tips (covers) are clipped on to the tail pipes (slides over) on the 535 but the tail pipes are welded on to the muffler. So if you are going to replace the singles with doubles you will need to cut the tail pipes off and weld the dual tips on. If you were swapping the chrome (or black) tips (covers) then they can be twisted on and off.
| Bookmarks |
| Thread Tools | Search this Thread |
