Bimmerpost for iPhone and Android have just been updated with a host of bug fixes. If you've ever had trouble logging into it in the past, give it a try now!
2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications JB4 S2 Wiring - Install on 535
      12-05-2012, 04:10 AM   #1
Apex99
Apex99's Avatar
Drives: 2012 M3
Hoping someone can shed some light on this for me...
In the pic of my wires in my F10 '13 535i xDrive engine, can someone let me know what #'d CAN wires the green and brown wires from the S2 connect to? I must be color blind cuz I can't put my eyes or my finger on this.
Thanks in advance!
"Not everything that counts can be counted, and not everything that can be counted counts."
      12-05-2012, 07:42 AM   #2
Rbembas_M3
Rbembas_M3's Avatar
Drives: BMW 2011 M3
2011 BMW M3  [0.00]
Where is this harness located in your car? I have the stage 2 but don't have the CANBUS located where Terry instructions shows. I was told that I have run stage 1. I was just curious if there is another location?
      12-05-2012, 10:41 AM   #3
Apex99
Apex99's Avatar
Drives: 2012 M3
I'm pretty sure this is the CANBUS on my car...I emailed Terry to ask if this pic looks like it will support S2 and he said yes. It's hard to probably see because of the close up pic, but this is located on the passenger side under the trim panel.
Thanks.
      12-05-2012, 02:21 PM   #4
Rbembas_M3
Rbembas_M3's Avatar
Drives: BMW 2011 M3
2011 BMW M3  [0.00]
Thanks.
Thank you I'll take a look at mine this afternoon when I reinstall.
      12-05-2012, 02:32 PM   #5
obiltagi3
V.I.P.
obiltagi3's Avatar
Drives: F10 (2011 535i)
http://www.n54tech.com/forums/showpo...16&postcount=3
      12-06-2012, 02:33 AM   #6
rjm98119
Drives: 2016 M235i
Thanks in advance!
Man, that's strange... your wiring arrangement there looks totally different than my '13 535i xDrive.
I know this doesn't help much, but by way of contrast, I just installed my JB4 S2 this past weekend and the arrangement of the wires looks exactly like the picture referenced in Terry's link above. In particular, that fat red wire from location #6 in your photo is all the way on the right, and there's a yellow wire right under it. (Uh, I guess I already said it looked exactly like Terry's picture didn't I... :/).
      12-06-2012, 02:13 PM   #7
Apex99
Apex99's Avatar
Drives: 2012 M3
Thanks for the note and for seeing what I'm trying to wrap my head around!! I don't get it...the wiring placements look to be different as well as the colors! If anyone can weigh in, I'd be grateful!
      01-13-2013, 12:24 AM   #8
mikey0120
Philippines
19
Drives: F10 535Xi M-Sport
I have the same harness as you and tried to install the S2 but kept getting drivetrain malfunction. Were you able to figure it out?
Retired: 2013 F10 535Xi M-Sport
Retired: 2010 E90 335i M-Sport
Retired: 2007 E90 335i
Retired: 2001 E46 330i
      01-13-2013, 11:54 PM   #9
Apex99
Apex99's Avatar
Drives: 2012 M3
Nope. Nada. I didn't end up ordering Stage 2 cuz I never got clarity on this. If you find out how it's done, pleeez post it up. A thousand thanks!
      01-15-2013, 11:49 AM   #10
VWtoBMW
VWtoBMW's Avatar
Drives: 2013 750i
I had some questions along the same line when I did mine. I was very skeptical and nervous when I got to that point. I emailed Burger Tuning and they gave me some pointers.
It is basically the wires at the far right. Below is a pic of the first one I tapped in to. It is confusing because there are others of the same color to the left of it.
[IMG][/IMG]
2016 G12 750Li xDrive Singapore Grey on Black with every possible box checked off on the option list ?
      03-16-2013, 08:55 PM   #11
Apex99
Apex99's Avatar
Drives: 2012 M3
Thanks! Do you happen to have a pic of both wires tapped?
[IMG][/IMG]
      06-24-2013, 11:15 PM   #12
PeterC4
Drives: 2012 BMW 535xi
Thanks in advance!
Here is my F10 12 535 xDrive...Looks the same. Notice the twisted wires are the same colours as yours.
2012 BMW 535xi MSport Carbon Black
      06-24-2013, 11:32 PM   #13
PeterC4
In speaking with Terry today, he was not sure what connection might work with this set-up but...if you look a the twisted wires it might be JB4 Brown Wire to Factory Green Wire (twisted) and JB4 Green to Pink Factory (twisted). Anyone try this?
      06-24-2013, 11:39 PM   #14
PeterC4
Another Pic - Zoom Out 2012 535xi CAN wires
Notice the twisted black and yellow wires on the left. They may be the ones that need to be tapped into from the JB4 to get Stage 2 to work.
      06-25-2013, 07:46 PM   #15
Sharbotcom
Sharbotcom's Avatar
Drives: 2011 535xi M Sport
Reversed wiring harnesses
It appears that on some of the 535 F10s the wiring harnesses are reversed. PeterC4 asked me to check my wiring harness against his as sure enough the harness that the JB4 needs to tap into is on the left when facing the car head-on whereas mine is on the right (as depicted in the JB4 instructions).
Sorry about the crappy picture but if you compare the left harness in the attached picture with the right harness in the previous post you will see they are same.
Bill
2011 535i xDrive, Dark Graphite Metallic, Veneto Beige Dakota Leather, Technology Package, M Sport Package, Executive Package delivered Christmas Eve '10, Mods - quad tips, 20% tint, JB4.
      06-25-2013, 09:54 PM   #16
Eki88
BxBadBoyy88
Eki88's Avatar
27
Drives: AW 2015 535 Xdrive
Just ordered my JB4 and this stuff is getting me super nervous for my install lol
2013 AW 535Xi
      06-26-2013, 12:28 AM   #17
DANMACINSD
Drives: 2013 BMW 535i
Let me know how it works. I gotta go out and check out my harness. Until then...
13 535i Msport
      06-26-2013, 08:51 PM   #18
PeterC4
The wires look like they are there for Stage 2 JB4
This is an important thread as the notion that some BMW F10s may not be Stage 2 compatible may be inaccurate. I believe that the wiring harnesses are sometimes reversed and also think that the colour codes are likely consistent within a model platform. I have not had the chance to try this but I do think you should compare the pictures I have posted to your car and to the instruction picture on Terry Burger's web site and hopefully you can identify what I have seen. When I get a chance, I will likely try the upgrade and what we need to do is identify which wires we need to plug into. It may be the ones closest to the red wire in my picture on the left bundle.
Hopefully I will get a chance to take some even better pics on the left bundle connection.
      07-20-2013, 12:46 PM   #19
bb2405
bb2405's Avatar
Drives: F10 535i M-sport
2011 BMW 535i  [4.38]
install is easy guys, ive put the tune on and off multiple times. works great, im also running ethanol and about to install my downpipe
