Bimmerpost for iPhone and Android have just been updated with a host of bug fixes. If you've ever had trouble logging into it in the past, give it a try now!
2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum climate control with mind of its own
      01-23-2013, 07:30 PM   #1
Dom
Ireland
33
Drives: 2013 520d SE space grey
I noticed today that the air blowing out of the centre vent on my side was considerably colder than the air blowing out of the passenger side despite the fact that I had my side set at 26 and the passenger side at 23, Weird or what?
      01-23-2013, 07:45 PM   #2
Awaghorn
Drives: E91 (F10 on order!)
Did you have a passenger in the car? Might be that temperature sensors thought your side was warmer (perhaps due to body heat?) and hence needed to direct air as described to achieve your targeted temperatures?
      01-24-2013, 05:35 AM   #3
Dom
Ireland
33
No, there was no passenger in the car, only me. I reckon you're probably right. Thanks.
      01-24-2013, 06:36 AM   #4
jedpause
jedpause's Avatar
Drives: G30 M Sport
I have seen this behavior as well, not really sure why.
I have also noticed when it is very cold outside, setting temp to 17/18degC is too warm, but if you go to 16 it blows clod air on both sides, so I have to set it to 16.5degC minimum....
Bluestone G30 ///M Sport Auto (Current)
Alpine White F10 M Sport | 8 speed Sport Auto - Gone to Stud
      01-24-2013, 06:55 AM   #5
HighlandPete
Drives: BMW F11 535i Touring
Possibly not weird at all. Would be like that in the E9x models, as it gives the driver a cooler air blend at face level, compared to the passenger. The more extreme you set the CC, the more it appears to be giving wild results.
What settings do you use, fully auto? Air intensity levels, face vent thumbwheel setting will change the working characteristics.
HighlandPete
      01-24-2013, 06:59 AM   #6
HighlandPete
Do you mean from the face level vents? What is the thumbwheel set at, red blob?
No issues here, set at 20C (both zones) and running full auto, low intensity air flow. Face level tuned to suit desired temperature blend.
HighlandPete
      01-24-2013, 09:47 AM   #7
jedpause
jedpause's Avatar
Drives: G30 M Sport
HighlandPete
Yes turned to red blob, centre face vents.... Full auto
18 deg C + it's just too hot...
      01-24-2013, 10:46 AM   #8
Awaghorn
Have you tried turning down from red blob to something more in the middle, or is it the overall temp you find too high?
      01-24-2013, 11:09 AM   #9
jedpause
jedpause's Avatar
Drives: G30 M Sport
Yes have tried that, it does help a little, however tends not to be even temp....
      01-24-2013, 11:31 AM   #10
HighlandPete
Not surprised, you are hot faced.
Also you are not helping the CC to work softly in the background. It is modulating the face flow temperature to try and keep the balance, as you are working towards more extreme settings as you run lower cabin settings and dial in hot face vent temperatures.
You will probably find running a higher cabin temperature, say 20C, and setting the face thumbwheel more to the middle position, will give a more constant, but coolish flow. I run mine like that with low airflow intensity, (the lowest auto fan setting), regulating the face temperature to mood, and there are no comfort issues at all. Hardly necessary to touch the thumbwheel, unless there are seasonal temperature changes.
BTW, the face vent temperature is modulated on the warm up cycle to supply warmer air to the face vents, as the cabin heats up the face vents turn cooler to give you fresh air. That is normal in a BMW, always has been.
I've always found with BMW HVAC systems the less you mess with unusual settings, the better they perform.
HighlandPete
      01-24-2013, 04:53 PM   #11
Gilgorm
Drives: 2012 535i Xdrive
I also find things can get messed up if the far-right passenger face vent is turned off by the thumbwheel. It creates an air imbalance in the car.
2012 BMW 535i X-drive; Space Grey/Black Dakota, Fineline; Executive (Auto trunk, NAV, HiFi Prof, Lumbar, Rear Cam, SIRIUS, Voice), Technology (Blind Spot, Hi-Beam Assist, Lane Departure, Surround View), APPS, Rear heated seats, Tint.
Retired: 78 300D, 81 300SD, 87 190E, 88 Porsche 924, 89 260E, 93 300E, 97 Volvo 850, 98 E320, 03 BMW 325iT, 02 C230 Sport Coupe, 08 BMW 535i
      01-25-2013, 02:54 PM   #12
jedpause
jedpause's Avatar
Drives: G30 M Sport
HighlandPete
Will try as suggested
