01-24-2013, 01:54 PM | #1 |
![]() 14
Rep 95
Just Dynoed my Dinan Stage 2 550i
I have my car getting installed a custom exhaust at Active Autoworks here in Miami and they did a pull with my car on their Mustang Dynojet..
The numbers look good 385lbs of tourque at the wheels and 369hp at the wheels Does anyone know how much power is lost between the crank and the wheels on the F10 550i? Once we put the exhaust we will Dyno it again, I will then go to Stage 3 and do another pull.. Ill keep posting my results for you guys to see THE CAR: 2012 550i Dinan Stage 2 Factory Exhaust H&R Springs |
01-24-2013, 02:21 PM | #3 |
![]() 4
Rep 199
wow nearly 80 whp differncea at 6k+ rpm niceee.
2011 550i gray/cbrwn Sport, Zf8spd JB Beta tune
![]() 2008 335xi alpine white/coral red- gone 2004 745li gone |
01-24-2013, 02:41 PM | #4 | |
![]() ![]() 81
Rep 1,113
I think that the Mustang numbers are pretty low compared to Dynojet and other dynos out there. With a 15% drivetrain loss, a stage 2 Dinan 550 should be putting down 415-425hp to the wheels (assuming 501hp advertised at the crank). I would not expect a huge difference with stage 3 and axle back exhaust..maybe 6-8 hp at the wheels. Not sure if you are getting a custom full exhaust...as that should give you significantly more power.
2018 F90 M5
2015 F80 M3 2013 F10 550i MSport 2011 E92 M3 2008 E92 335i |
01-24-2013, 03:07 PM | #5 | |
![]() ![]() ![]() -103
Rep 527
01-24-2013, 09:34 PM | #6 | ||
![]() 14
Rep 95
I want to make sure I am getting what the advertise |
01-25-2013, 07:12 AM | #7 |
![]() ![]() ![]() ![]() 14
Rep 490
Yeah i don't think your tune is working. You are only getting about 420hp. Which is much much lower than the Dinan advertised 501hp.
Actually Stock 550i were dyno at 380 wheel hp. So you are pretty much stock. You should get it check out.
2011 535i Alpine White, Oyster on black interior, Premium 1 & 2 Package, Magnaflow Full Cat-Back Exhaust, JB4 Stage 2
01-25-2013, 08:35 AM | #8 | |
![]() ![]() ![]() ![]() ![]() 22
Rep 951
People making assumptions by looking at the absolute numbers only have no idea what they are talking about. |
01-25-2013, 11:32 AM | #9 |
![]() 4
Rep 199
ACTIVE autowerks reads lower you can see his stock baseline was around 310 so compare the two
01-25-2013, 02:03 PM | #10 |
![]() ![]() 6
Rep 175
My F10 550i dynoed stock at 320 whp at a Mustang Dynomemeter. Not sure if the versions of the Mustang dyno give different numbers. Haven't got to re-dyno since I installed the AR Downpipes and Hartge ECU. Will post if done.
So is Dinan Stage 2 just an ECU tune?
F10 550i M-sport: Space Grey/Oyster Black
E39 M5 : Carbon Black/Caramel E39 520i : Titanium Silver/Beige (Sold) |
01-25-2013, 03:47 PM | #11 | |
Rep 527
BMW advertises ~400/450 for the n63 but the real numbers are 30-40 higher. Same reason - so as not to further poach the M version of the same vehicle. Everything relies on boost. The Dinan tune gets the n63 up around 14psi, 2.5 or so over stock. |
01-25-2013, 03:52 PM | #12 | |
Rep 527
Stage 3 is exhaust work + an ECU tune. So it looks like you two had almost identical output on a Mustang Dyno. ~320whp @ 5100rpm's or so. |
01-25-2013, 08:33 PM | #13 | |
![]() ![]() 81
Rep 1,113
Actually, the Dinan tune is about 4-5 psi higher than stock ~9psi.
2018 F90 M5
01-25-2013, 08:35 PM | #14 | |
![]() ![]() 81
Rep 1,113
2018 F90 M5
Daniel232.50 |
01-25-2013, 08:41 PM | #15 |
Rep 527
01-26-2013, 12:22 PM | #18 |
Rep 527
99% of the engineering difference between the s63 and the n63 exists in the intake design. With the s63, air is shot directly to the turbos through the intake boxes. With the n63, the air must circulate through an upper and lower portion of each intake. These boxes function as air restrictors.
. . . Last edited by mryakanisachoad; 01-26-2013 at 12:29 PM. |
01-26-2013, 01:25 PM | #19 | |
Rep 951
01-26-2013, 07:45 PM | #20 | |
Rep 10
I see two problems with your dyno graph. The first is that the stock pull is not your car and was done months before. While the same dyno, you want to eliminate as many variables as possible. The temperature, humidity, fan speed and oh yeah, it's not your car are all different. Second, your car only had an increase of 34 ft/lbs of torque and 46 of hp. Those should be around 100 and 85 respectively according to the Dinan website (I already subtracted 15 percent from claims since their numbers are at the crank). The best would have been to do back to back pulls with your car but even so, your increase in torque and hp are way low.
2012 550i xDrive,
2009 Nissan GT-R , 2007 Toyota Sienna, 2005 Audi A6 4.2 1997 Porsche 911 Cabriolet, 1996 Honda Magna |
01-26-2013, 08:45 PM | #21 |
![]() ![]() 81
Rep 1,113
9.8, from what I have read.
2018 F90 M5
01-26-2013, 10:42 PM | #22 | |
![]() 14
Rep 95
I will do a few more pulls and if the numbers dont get better I will have a talk with Dinan I am doing exhaust now and was thinking of going to stage 4 but if the numbers dont make sense I might just stop here... Is there anyone from Dinan on this forum? |
