2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Dinan springs install question
      01-19-2013, 06:29 PM   #1
kthankzbye
kthankzbye's Avatar
33
Drives: 2011 550i DGM
I recently installed dinan springs and after two weeks and an alignment. I realized that both passenger front and rear sits 20mm lower than the drivers. Did they install it bad or something is wrong with my car? thank you
      01-26-2013, 12:44 PM   #2
schneller
2013 550i xDrive MSport, carbon black
Drives: 2013 550i xDrive MSport
Dinan springs on my 550 xDrive: left and right side match. The Dinan upgrade dropped it from a loose three finger gap all around (50mm +) to a tight two finger gap in the front (about 35mm) and a slightly tighter two finger gap at both rear fenders.
      01-26-2013, 04:56 PM   #3
kthankzbye
kthankzbye's Avatar
33
Can you do a favor for me and measure the height from the floor to the lower part of the fender?
My front right is 27 1/4
Front left is 28"
Rear right and left are 27 1/2"
I've contacted dinan and they've said my front right is a bit on the lower side and 28" is where it's suppose to be at. But stock is 28 1/4".
Thanks for your reply.
