2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications AR downpipes 535i
      01-31-2013, 07:07 PM   #23
gragi
Drives: 2011 535i xDr F10 M Sport
Originally Posted by Rich@GTBPerformance View Post
AR Design just started accepting orders for their F10 535i Downpipe.
Shoot us a PM and we can get you a price!
Hey Rich, I had my AFE catback installed 3 days ago however when cruising 60-70-80 m/h drowning comes. Do you suggest anything? Any resonators I should buy?
Thanks,
1996 E36 328i Touring
2000 E46 328Ci
2004 E46 M3 Dinan Exhaust
2011 535xDrive F10 AFE CATBACK, AFE SCORCHER, AFE Performance Air Filter, H&R, AR Down Pipe, ER Charge Pipe.
      01-31-2013, 10:36 PM   #24
richb811
richb811's Avatar
312
Drives: 2011 E92 JZB M3, 2000 750iL
Thanks,
New exhausts can take a while to "Season". You'll get a slight carbon buildup on the inside of the pipes which will help dampen the droning a little bit.
I would wait a few weeks before deciding if you need a resonator. The sound usually does mellow a bit.
      02-01-2013, 12:34 AM   #25
gragi
Ok, good. Thanks Rich. I have it installed as per manufacture on/with clamps, however I was told that if welded would be better. Do you suggest welding instead and why?
Gent
2000 E46 328Ci
      02-01-2013, 01:39 PM   #26
richb811
richb811's Avatar
312
Gent
If the exhaust specifies clamps, clamps will work just fine. Welding isn't going to change anything unless you've got an exhaust leak.
I wouldn't weld an aftermarket exhaust to your OEM if you ever plan on selling the system either.
