2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes M5 Sway bar to 550i?
      02-04-2013, 02:03 PM   #67
Alan l.
Alan l.'s Avatar
1654
Drives: 2016 F85M
I also want to add the install for the M5 front sway bar is super easy. You can do it with the car on ramps in no more than 30mins and thats taking your time.
I normally DIY all of my parts but now with a baby I decided to let my shop do it. I watched the whole process and it was in and out in 30mins and that includes getting the car on and off the lift. Theres maybe a dozen small bolts that holds the belly pan up and once that is off you have a total of 6 bolts that holds the sway bar in place. Its in a area that isn't blocked by anything and you can reach all of the bolts with ease.
My stock front sway bar
      02-04-2013, 11:13 PM   #68
cko
Drives: 2013 550xi
First post from a new member - Many thanks to Alan. Great research and willingness to be a guinea pig. I'm a relatively new owner of a 2013xi, M-sport with DDC but no ARS. I have the Dinan springs and I'm going in for the Shockware. It sound like the M5 sway bar will round out the suspension upgrades well. Thanks for providing some great info.
      02-05-2013, 03:51 AM   #69
gre8tw8LL
Drives: 2012 F10 535i
Originally Posted by Analog
Originally Posted by Silververtu
We need a group buy now!!!
I am down
I'm down also
2012 535i Alpine White | Oyster Black Dakota Interior | Hamann Front Lip | LiteSpeed Catback Exhaust | M5 Diffuser| Painted Calipers & Reflectors | Black Gloss Grill | LED interior lights | Piaa Plasma Yellow Foglights | Born on 1/30/12
      02-07-2013, 10:47 AM   #70
Alan l.
Alan l.'s Avatar
1654
Drives: 2016 F85M
Any luck on the 550GT bar Joe?
According to realoem it looks like we need the bar plus two bushings only.
Alan
      02-07-2013, 11:46 AM   #71
528imsport
528imsport's Avatar
Drives: Msport
Originally Posted by Alan l. View Post
All I have to say is wow and everyone must do this. This is how the car should have came stock. My car has DDC and ACS springs and I am in sport mode 99.9% of the time. Before the M5 sway bar I would rate the handling of my F10 a 4 or 5 out of 10 at best compared to my previous E46 and E90 on coilovers but now its a solid 7.
The suspension just feels tighter and more solid up front and you notice it this when going over bumps and uneven roads. The car is flatter during turns and the steering feels alittle more direct/precise during high speed lane changes. Before I would anticipate the roll/sway movement but now the car just points to where you want it. It isn't a track car by any means but that wallowing feeling is pretty much gone or barely noticeable anymore. Nothing negative about doing this mod at all so far. Very pleased.
Alan
Sound good but what about the feeling on the rear end, dose it feel unbalanced?
      02-07-2013, 12:00 PM   #72
528imsport
528imsport's Avatar
Drives: Msport
^^Joe@ptech is going to find that out real soon
Now with the rear bar.
Turns out on the 535 theres several sizes that the car comes with depending on options and if its RWD or AWD.
535i standard rear bar is 13MM
535i Msports rear bar is 14MM
535xi standard rear bar is 14MM
535xi with EDC/DDC rear bar is 15MM
I did not check this for the 528 or the 550 but you can easily do it with realoem.com
Since my car comes with a 15MM rear bar I will go with the 18MM F07 550GT's rear bar for a 3mm increase. Looks like you will also need to purchase new bushings with bigger internal diameter to hold the thicker bar. Hopefully thats it.
Alan
I check but the parts number are not the same for all 4 cars and also no info on how think the bars are but the image is the same for all 3 cars
will the M5 sway bar fit my 2012 528i car any one know?
My car has the M Sports suspension so here are the list:-
For vehicles with M Sports suspension
M5 parts no. 31352284460
http://realoem.com/bmw/showparts.do?...85&hg=31&fg=10
528i parts no.31356791924
http://realoem.com/bmw/showparts.do?...27&hg=31&fg=10
535i parts no.31356791925
550i parts no.31356793395
      02-07-2013, 03:52 PM   #73
joe@ptech
NorCal BMW Specialists
Drives: 17 M2|16 X5M|74 tii
Still waiting on this rear bar. I should have it this week or early next and will report back.
      02-07-2013, 04:50 PM   #74
Silververtu
Drives: 2015 Cayman S
Appreciate for the effort!!!
2015 Cayman S, 2015 X5 50i M Sport
Gone but not forgotten:
2006 2.0T A4 Avant, 2007 Z4 Roadster 3.0si, 2006 M Roadster, 2013 550i M Sport
      02-08-2013, 10:20 AM   #75
528imsport
528imsport's Avatar
Drives: Msport
hope all goes well
      02-08-2013, 10:47 AM   #76
Alan l.
Alan l.'s Avatar
1654
Drives: 2016 F85M
M 528i - Use this site to cross reference which models share the same parts
http://www.bmwstore.pl/pl/katalog/pr...ni-z-pod-gumow
Part# 31356791924 is what comes on a standard 535i here in the US. When i plugged in that number in that website it lists a bunch of cars that also uses the same part and your 528i is included. This means since the M5 bar fits a 535i, it will also fit a 528i.
Alan
      02-08-2013, 11:52 AM   #77
528imsport
528imsport's Avatar
Drives: Msport
Alan
So the M5 1 should fit the M Sport too, right?
      02-08-2013, 12:42 PM   #78
Alan l.
Alan l.'s Avatar
1654
Drives: 2016 F85M
There is no difference between the mount points between the standard, msport or whatever so it will fit.
      02-09-2013, 11:37 PM   #79
528imsport
528imsport's Avatar
Drives: Msport
thats I will get this later on then
      02-10-2013, 07:03 PM   #80
HDEddie1
HDEddie1's Avatar
Drives: '12 F10 550i, '08 E60 528i
M5 confirmed for us his rear bar on his F10 M5 is 18mm. For those of us wanting to match the factory set up when upgrading to the M5 front bar, the makes the choice for the REAR BAR real easy- 18mm
      02-11-2013, 12:11 AM   #81
hyperboost
hyperboost's Avatar
50
Drives: M3, 535XI Msport
if even@tischer can put together a package for the M5 rear sway bar, i can be the first and test fit this. especially for xi owners
F80 YMB M3 DD|16 RS7 Stock|16 Range Rover SC'ed|12 GTR Stock|F10 535XI Msport AW - Sold|E92 M3 MR exported to China |E93 M3 AW sold |E46 M3 IR ESS SC'ed with loads of mods|E46 M3 TiAg Track weapon Moton CS suspention - sold|Bentley Continental Mulliner package - sold|87 944 NA winter beater - gone|E39 540iA - sold|10 Cayman|04 G35 Turbo'ed 380rwhp - sold|03 350Z SC'ed - Sold|11 Mustang GT SC'ed 513rwhp - sold|AW SC'ed E92 M3 - gone
      02-11-2013, 02:03 PM   #82
Alan l.
Alan l.'s Avatar
1654
Drives: 2016 F85M
^^ the M5 rear bar is confirmed to not be a direct fit by Joe@ptech. The 550GT however is looking like a good alternative since it is also 18mm in diameter
Alan
      02-11-2013, 03:44 PM   #83
hyperboost
hyperboost's Avatar
50
^^^ sounds great. Even needs to chime in here with some part numbers
      02-12-2013, 02:00 AM   #84
Douggie
Drives: BMW X1, 5
Alan
So the 550GT rear sway bar will fit?
      02-12-2013, 10:39 AM   #85
Alan l.
Alan l.'s Avatar
1654
Drives: 2016 F85M
Waiting for Joe@ptech to confirm. He's waiting for the bar to arrive but looking at realoem.com this bar should fit the F10.
Alan
      02-12-2013, 03:07 PM   #86
joe@ptech
We tried this already and the bar mounts differently. Even with longer links, I'm not sure it will work.
      02-15-2013, 01:51 AM   #87
bodonx
Drives: 2014 F10 M5 CP
Any update on M550DX rear bar?
Sorry, I can't wait
      02-19-2013, 09:49 AM   #88
Silververtu
Joe, any update?
