2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Is there a charger for key fob?
      03-17-2013, 11:35 AM   #23
AP
AP's Avatar
2882
Drives: G30 M550
wireless charging? I know thats technically possible now but I've not seen anything in the manual either for that.
      03-17-2013, 11:36 AM   #24
Estimated Prophet
Drives: 2012 550i / Stage 2
Originally Posted by Screamin View Post
I've quickly reviewed this in the owner's manual and didn't see anything specific.
It is on page 31 of the 2012 manual.
      03-17-2013, 12:48 PM   #25
Gilgorm
Drives: 2018 640i Xdrive GT
I was just at the dealer and this came up. Sales Rep said just hold it close the steering column and it will charge. I've quickly reviewed this in the owner's manual and didn't see anything specific.
Your sales rep needs to familiarize himself with what he is selling. Any Comfort Access car uses non-rechargeable batteries.
Based on his assumption, you should invite him over to your house so he can sit in your car foolishly holding the key for an hour or two or more while your batteries recharge or perhaps he would suggest duct tape next time.
The keyfob can be "detected" but not charged if held to the steering column.
2018 640ix GT; Alpine White, Blk Nappa, Piano; M-sport, Premium (Ceramic, SIRIUS, Soft-close, Vent/Massage Comfort seats, Surround, Sunshades, Parking Ass't), Advanced Driver Ass't (Lane keep, Steering/Lane control, Cross traffic, ACC with Stop/Go), Smartphone, Tint.
Retired: 78 300D, 81 300SD, 87 190E, 88 Porsche 924, 89 260E, 93 300E, 97 Volvo 850, 98 E320, 03 BMW 325iT, 02 C230 Sport Coupe, 08 BMW 535i, 12 BMW 535i X-drive
      03-17-2013, 05:10 PM   #26
OzDriver
OzDriver's Avatar
Australia
Drives: '13 535i & '08 530i
Originally Posted by Gilgorm View Post
... you should invite him over to your house so he can sit in your car foolishly holding the key for an hour or two or more while your batteries recharge or perhaps he would suggest duct tape next time.
      06-14-2015, 03:30 PM   #27
charmin
charmin's Avatar
Drives: 320i M-Sport June 2009
BMW Key Fob - to charge or not to charge...
It is really so simple....
If you have Comfort Opening i.e. you don't need to insert your fob anywhere... but just have it in the car, then the fob has a REPLACABLE battery, a button cell that fits in the fob and lasts about 2 to 3 years, often they will replace the battery free of charge at many BMW dealers.... this battery does not recharge no matter where you put it.....! if the battery is almost flat then on some cars, putting it next to the steering column may help the low signal from the fob start the car, the receiver is located around there.
If you do not have Comfort Opening then you will have a rechargeable battery fitted in the key fob, this charges when you are driving, and only when you are driving and only when it is inserted in the fob slot...... the rechargeable battery should last many, many years and cannot be changed (easily), a new fob or forcing it apart and following a fix off U tube or somewhere is necessary, not easy.
If you have an old rechargeable fob that hasn't been used (charged) for some time you will see a charge symbol appear on the dash, it needs putting in the slot and drive the car for at least 30 mins to an hour to charge it up.
If you have a fob (battery type) with a flat battery the symbol will also appear on the dash, just fit a new battery... £3 ish
You cant recharge this type of fob.
Rechargeable fobs simply do not have a any access to inside the fob, whereas replaceable battery ones have a flap you lift up with a small screwdriver...
Hope this helps..
      06-15-2015, 12:10 PM   #28
RSBro
RSBro's Avatar
Drives: 2012 550i M-Sport
Make sure and take your FOB out of the car. When I first got mine, I left it in the little seat by the cupholders. Apparently, the signal from the FOB will still transmit to your car even when off, running the battery down.
Now I take it out and the FOB has lasted much longer. This is what I've read and worked for me, anyway...
2012 550i///M-Sport///Carbon Black Metallic///Oyster+Black Dakota///ZCV+ZLS+ZMP+ZPP+ZPS+ZSP+ZTP...M5 exhaust///iND Tricolor grilles///H&R Sport Springs///Turner Motorsport 12mm+15mm spacers
      06-16-2015, 02:07 PM   #29
M5Beast_NYC
Drives: 15 M5
Originally Posted by ImSW1 View Post
Yes. Only option is a new battery.
Sean
+1.
When i bought my car i had the remote battery warning. The dealer replaced the batteries on both my remotes. No recharging feature as previously metnioned.
      06-16-2015, 11:08 PM   #30
BMW FOREVER
BMW FOREVER's Avatar
Drives: 2014 535i Xdrive
For the F10, the comfort access option doesnt matter. Whether you have the option or not, there is no slot in the car to charge the battery
      09-04-2015, 09:12 AM   #31
Bery
Drives: 2010 Series 5
I am new to this forum and not sure I can start a new thread- my problem is related to this thread.
For my 2010 520D ( 27k miles) both remotes open the doors of the car OK but when I press the start button the car will not start and the message on the dash is that I should hold the remote by the steering wheel- this starts the engine. The batteries on both remotes are OK.
An independent BMW garage could not help- the diagnostic report showed all sorts of issues but none related to this issue, so could not help
Any ideas?
