2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Excessive oil consumption
      12-07-2011, 04:42 PM   #23
Jimefam
Drives: 2011 550I Msport
Well your not burning oil like me but since you are in a much colder climate maybe you might be interested in the Mobil 1 0W-40 that I used on my last oil change. You probably won't change oil again before the winters over but the 0w will protect more on start up and I think the thicker viscosity at high temp is the reason I'm only down a 1/4 of a quart through 3,000 miles when I was burning a quart every 2k before. It's also on BMW's approved LL-01(long life) oils so no warranty issues should something happen. I'm sure what you used is more than good enough just thought I'd bring up positive results I've had with the switch.
      02-27-2012, 10:50 AM   #24
alextremo
Drives: F10 550i
Originally Posted by alextremo View Post
Nope. They said they didn't see anything else wrong when they opened it up. Maybe a defective gasket or it got nicked on install or something? (fingers crossed)
Went back under the car after a couple months of driving after they replaced the gasket and found that the oil pan was again covered in a light film of oil. Not as bad as last time, but definitely moist. It's back at the dealer now - they say they are going to replace the oil pan this time, they think there could have been a defect in the forging process. We'll see...
I also have them looking at a rough idle I've been experiencing, most prevalent when the engine is at operating temps. It's nothing you can see on the tach, but the rough idle is strong enough to shake you in your seat when it happens, worse than my 10yr old Jeep Wrangler does. Anyone else have this?
      02-27-2012, 05:10 PM   #25
Vinfast
Drives: '14 550i M-Sport
Mine does this at idle when at operating temperature, but my Dinan rep told me it was because of the Dinan Stage 2 tune --- mine doesn't shake you in your seat though.
      02-27-2012, 07:15 PM   #26
alextremo
Drives: F10 550i
Hmm - I'd be really surprised if it's the tune, i wouldn't think they'd change anything from the stock mapping at idle. It's strong enough that I can feel it shaking in my legs and butt. I don't think you should feel the engine idle at all in a 1 year old $75k luxury sedan.
      02-28-2012, 11:14 AM   #27
BMWrules7
Drives: 2015, 740 LdX, Alpine White
Originally Posted by Jimefam View Post
Did they tell you why that gasket failed? I can't think of a single reason why they would reuse the oil besides cost? As for break in I followed it completely for 2,000 miles during my ED, the last 1200 miles of the trip I drove it hard. I also put it on ramps last night and double checked for any sign of oil and everything is clean down there no signs of a problem.
I think you're right about the oil and cost, but maybe they would claim they are protecting the environment by reusing good oil?? Either way it was a bit surprising/annoying, but not that big an issue for me as I had already purchased the materials and had planned to do it myself.
My problem with reusing the oil is the possibility of contamination. Whatever device the dealer uses to reclaim the oil was probably used for some other purpose like reclaiming transmission fluid at one point.
I am not asking for a sterility here, but you know if a tech has to drain a liquid he is going to use the same device and this will lead to contamination.
      09-16-2012, 02:42 PM   #28
Ty
Drives: 2012 BMW 550i
Large oil consumption surprising for a new vehicle
I have a 2012 BMW 550i. I bought it in Texas on 6/30/12. it is a wonderful driving car. Yes, the ultimate driving machine I agree. It had 1800 mi when I purchased the vehicle. One month later and roughly 1400 mi of driving, the oil needed to be what BMW calls topped off due to the electronic sensor detection indicating low oil level. It is now Sept. 16, 2012, and I am nearly at the minimum level again with the vehicle at 4600 miles. Btw, the technician told me it is normal for this car to burn a quart of oil between 700 and 1k mi because its a high performance engine. Honestly, I believe that is crazy. I guess If I were to travel across the country, I will need to carry a a six pack of oil in the trunk of a new car... Btw, I have to use Castrol synthetic 5w30 weight oil at a little over $9/ quart. I believe there is a design flaw and am concerned... I just purchased 2 quarts of oil and have them handy as I motor around DFW...
      09-16-2012, 05:20 PM   #29
The X Men
Drives: 2013 X3 35i
Ty, burning a quart every 1500 miles is definitely not normal, hopefully the oil consumption will slow down as the engine age. Was your car a demo?
      10-07-2012, 09:04 AM   #30
mrainv23
mrainv23
mrainv23's Avatar
Drives: 2014 BMW M6 Gran Coupe F06
I have the same situation with my 550i. I add 1 quart approx. every 3000 miles. I have gotten use to keeping a spare quart in the vehicle. I am definitely going to ask about this at my first oil change at the end of this month.
      10-07-2012, 10:48 AM   #31
bubbahead
Drives: 2022 G05 40i Msport
I got 40000km on my car.. I was burning about 1 qt every 3000km.
As of now my SA told me to come in 5 times at 1000km intervals to measure the oil consumption and top off. After the 5th time they will add up the consumption and file some sort of report with BMW and see what they recommend we do, if anything. I will keep everyone posted. I'm going in for my 3rd checkup this week. I think if you have a good relationship with a SA, he/she will give the value added service.
2018 540ix msport
2015 X5 msport
2013 750ix msport
2011 550ix msport
2009 e92 335i msport
      11-27-2012, 02:02 AM   #32
limpeh
Drives: BMW F10M
My F10 M5 needs to top up 1 quart every 700km. During the 1st 2000km servicing, I have topped up 2 quarts. After oil change at about 2000km, I topped up 1 quart again at 2800km and just this morning another 1 quart at 3800km. My SA told me that this is still within BMW specs and assured me that the oil consumption will come down slightly at 5000km and significantly after 10,000km.
I never had any chance to rev my engine RPM beyond 4000rpm so far as I am caused in very bad traffic jams everyday since I bought the car. Not sure if this is the cause of my M5's high oil consumption?
      11-27-2012, 09:24 AM   #33
JNoSol
JNoSol's Avatar
Drives: 750 MSPORT & E90M3
Looks like BMW needs to go back to the drawing board. I'm waiting to hear if the '13 LCI 750 with the 445hp N63 has the same issue. I'm positive the re-tuned engine will hit the F10 LCI next summer, which I'm eagerly waiting for..
If I own a 550, I would use 2 oil catch cans (one for each intake). I believe it's not just burning oil, but sucking through the intake vacuum hose. No matter what the technicians tell you, burning at least 2qt between an oil change is not normal for a brand new car.
It's a business decision. It's cheaper to give you free oil within the warranty than repairing the engine flaw.
      04-23-2013, 05:06 PM   #34
dbs600
Drives: 2011 750LXi Individual
Is our excessive oil consumption problem a defect?
Volvo and Subaru are catching the attention of this firm for same: www.lemonlaw.com/wordpress
(March 19th and February 27th articles)
      04-23-2013, 08:16 PM   #35
Screamin
Drives: 2012 528i xDrive
All of my BMWs have burned more oil than I thought they should. I got in the habit of carrying a couple quarts in the trunk. They are notorious for burning oil.
'12 F10 528i xDrive (Jet Black)
'11 E71 X6 xDrive35i (Black Sapphire Metallic) - Gone
'06 E60 530xi (Titanium Silver Metallic) - Gone
'97 E39 528i (Arctic Silver Metallic) - Gone
      04-23-2013, 10:04 PM   #36
dbs600
But should they be allowed to be?
      04-24-2013, 08:17 PM   #37
Screamin
No, probably not. But it's become part of my weekly maintenance ritual the past few years to check it, I don't even bother to sweat it. To me it's less annoying than the later models loosing that distinctive BMW interior smell, but that's another thread.
      04-24-2013, 11:24 PM   #38
Lee
Germany
64
Drives: '17 X5 50i/'01 Z3
Interesting thread. Just hit 10K and added my second quart.
      05-02-2013, 11:10 AM   #39
Boulder Bill
Boulder Bill's Avatar
Drives: 2018 Porsche Cayman GTS
Adding the second quart today at just under 7,000 miles. SA says 1 quart every 1,000 miles is manufacturer specification. I said that I thought that was ridiculous and he just shrugged and said that was what they were told.
It will be interesting to see how much oil is burned after 10-20,000 miles. Anyone with a 2011 550 have any experiences to report?
2013 F10 550i | 6 Speed Manual | M Sport Package | Carbon Black | Oyster & Black Nappa | Dynamic Handling w/Dynamic Damper Control | Executive Package (Comfort Access - Soft Close - HUD) | B&O Sound | Luxury Seating & Heated Seats
(retired: 2002 E39 540i | 6 Speed Manual)
      05-02-2013, 12:55 PM   #40
JamRWS6
Drives: 2022 X3M Competition
Just rolled 11K and had to have the dealer add a quart. I changed the oil at 1K so make it about 10K before needing a quart.
      05-02-2013, 02:17 PM   #41
Chili Palmer
Master Of My Domain
Drives: 2015 650i Gran Coupe
You're right it's a business decision because it's such an inconvenience to go to the dealer and sit for 30-60 minutes while they have to have to pull a tech away from what he's doing to put one quart of oil into the car, most people would just do it themselves then hassle it. That's what they're betting on and winning.
      05-02-2013, 02:22 PM   #42
dbs600
Everything about this company has become so frustrating! Total, unacceptable BS.
      05-02-2013, 03:33 PM   #43
JamRWS6
I pulled in to the service drive, told the guy about my minimum oil message. He came right back w/ a quart, put it in the car, and then we re-checked the oil level and I was on my way. Waiting for a tech would be pretty frustrating.
      05-02-2013, 08:49 PM   #44
Screamin
Do you feel it's the company or the dealer?
