2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Replaced all eight spark plugs
      08-04-2015, 11:11 AM   #23
Zer0Cool92
Drives: blue metallic
Originally Posted by badblack550xi View Post
ordered my sparks sick price way cheaper than from dealer will do them next week.
What type of spark plugs and from where did you get em?
      08-04-2015, 12:02 PM   #24
badblack550xi
badblack550xi's Avatar
BOSCH the same ones our cars use from Amazon, so much cheaper than from BMW. by about $100 that's with 20% shop discount.
http://amzn.com/B00RY4J38U
2011 550i RWD 60-130 7.35
      08-04-2015, 12:06 PM   #25
gclions
gclions's Avatar
78
Drives: 2011 550i
I left my car with the dealer, and boy I'm not so sure anymore. They say I have a misfire on cylinders 5 and 7 now (which shouldn't be the case), and nothing on cylinder 1 (which had a misfire locked in when I dropped it off). 5 and 7 injectors were already replaced as discussed in my first post, and I'm starting to think I may need to grab a new set of coils after all. Time to do some more shopping.
I hope they're smart enough to pull #1 plug like I suggested, if so, it definitely will give the tell-tale sign that the injector is leaking.
Who else has done a coil swap, and is there an upgraded set of coils out there for the N63? I thought I saw something on ECS before, but I can't find it now.
2011 BMW 550 i / Sophisto Grey / BMS Stage 2
      08-06-2015, 01:32 PM   #26
mdavis1722
mdavis1722's Avatar
Drives: 2011 550i XDrive M-Sport
Just brought mine, thanks for the link.
      08-08-2015, 04:18 AM   #27
badblack550xi
did mine.... so easy to do car feels much better
      08-18-2015, 04:55 PM   #28
Paul1994
Drives: 2018 BMW M4 comp -- BMW x5 G05
  [0.00]
Where to start
does anyone have any pictures around the removal of the shrouds and the location of the spark plugs.. I have a gist but with the turbo this is a little bit different from my e60..
      08-24-2015, 06:22 PM   #29
peter91118
peter91118's Avatar
30
Drives: '01 325xit, '09 335i
The whole job is simple. I did it yesterday in the street waiting for my girlfriend to get out of the shower. Took 40 minutes.
The turbo's dont even come into play with this. Unplug the MAF and loosen one of the two hose clamps to the box. Pull the hose back and then pry the tab out of the tube below. Release the metal clip by the orange rubber mount and remove the o2 sensor wires from the routing clips. The airbox then comes out with a good yank as an assembly.
It's a little tricky to pull the box the first time (because you're worried about breaking something). After you get the hang of it, it can be done in under a minute.
      08-25-2015, 06:34 PM   #30
911TBO
Drives: e90 335i
Replcacing and coding injectors
I am having some issues with my N63 engine 550i. Recently, it has started misfiring slightly on cold start and will trip the "drivetrain error" warning. When I read the codes, it is a cyl 5 misfire - injection shut down.
I pulled the spark plugs (dealer was supposed to change ~10k miles ago) but they looked a little worn. What I think is cyl # 5 plug looked normal colour. Am I right in assuming the RHS while looking at the front of the engine is #5 and #1 is front LHS?
Interestingly, plug #1 looked more problematic. Was very black.
I have changed all the plugs but I don't think it solved the issue. It sounds like an injector issue to me. But is it #5 or #1?
If I change injectors, can I just change one? Or do I need to do them all? Do I really need to recode? If so, where can I buy the tool?
Thanks in advance
      09-19-2015, 07:02 PM   #31
Zer0Cool92
This site has Bosch spark plugs for 100 and genuine bmw spark plugs for 150. Is there any major difference between the two ?
https://www.ecstuning.com/BMW-F10-55...ugs/ES2794923/
      09-21-2015, 08:34 AM   #32
550Reasons
550Reasons's Avatar
Drives: F10 550i
found them a bit cheaper, $87 shipped
http://www.ebay.com/itm/BMW-F01-F02-...21f277&vxp=mtr
Already ordered the socket, gonna order this ones on the next paycheck.
My car is getting close to 40k miles, and supposed to be done every 30k, and I do drive it fairly hard with the Stage 1.
Lets see how they turn out.
2011 550i
2013 M5
2014 M5 CP
2016 550i
      09-21-2015, 08:19 PM   #33
Autobuffoonery
I am groot
Autobuffoonery's Avatar
25
Drives: 550I M SPORT
The Manuel that came with my 550 says to change plugs at 50k. Is there an adendem to this interval?
2011 550i M SPORT
CF kidney grills, rear diffuser, rear spoiler, bmw emblems, Megan Racing mufflers, H&R Sport Springs, Forgestar F14's Front 20x9/275/30r20 Rear 20x11 305/25r20, AQ3500d, Audio Control LC2, custom ascendant audio 12" chaos/mayhem's 4th order
      09-22-2015, 07:44 AM   #34
550Reasons
550Reasons's Avatar
Drives: F10 550i
I recently got an email about service and said oil and spark plugs, and I read somewhere every 30k miles is about right, specially if your tuned. I rather not run the risk for 100 bucks total (i'll be doing it myself)
I didnt change the spark plugs in my G37 until after 100k, and was running perfectly fine.
2011 550i
2013 M5
2014 M5 CP
2016 550i
      09-23-2015, 11:46 PM   #35
Autobuffoonery
I am groot
25
I get my car back from the dealer tomorrow for HPFP recall, I'm changing the plugs when I get it home. Rock auto has the stock Bosch (BOSCH ZR5TPP33 OE) plugs for $8.88 each or $76.66 for all 8 shipped. This is where I bought mine
2011 550i M SPORT
      09-24-2015, 01:02 AM   #36
FenixMike
Drives: 2014 BMW M5 Competition
Im due for mine pretty quick as I'm about to hit 60,000 miles, I called NGK and they don't make a plug so I'm just going to do stockers as well. my car runs flawless on the ones it has so I see no reason to upgrade at this point, but I would like to run a heat range cooler for increased boost.
2014 M5 Competition with ESS Tuning Flash
Gone but never forgotten...2015 X5 50i M Sport, 2015 550i M-Sport, 2015 M3, 2014 X5 50i M Sport, 2015 435i M Sport, 2011 550i, 2011 535i
      09-24-2015, 02:39 AM   #37
Autobuffoonery
I am groot
25
Any special tools? Someone mentioned a bmw spark plug socket, will a regular spark plug socket work?
2011 550i M SPORT
      09-24-2015, 07:41 AM   #38
550Reasons
550Reasons's Avatar
Drives: F10 550i
not really, you need a thin wall socket
2011 550i
2013 M5
2014 M5 CP
2016 550i
      09-24-2015, 08:59 AM   #39
Simple5
Drives: F90 M5 and E84 X1 Xdrive35i
Is it the same as the n54 socket? I still got that from my old 550i.
      09-24-2015, 09:16 AM   #40
550Reasons
550Reasons's Avatar
Drives: F10 550i
As long as its 3/8" 14mm thin wall you good
2011 550i
2013 M5
2014 M5 CP
2016 550i
      09-24-2015, 10:28 AM   #41
Zer0Cool92
What'r some symptoms your guys car felt before you changed the spark plugs ?
      09-24-2015, 03:26 PM   #42
Autobuffoonery
I am groot
25
I'm changing my plugs to hopefully get rid of a slight rough idle and when I say rough I mean it's barely noticeable. I picked my car up from the dealer today, for the fuel pump recall and it feels the same as it did before I took it in. My plugs won't be here till Monday, a shipping error on thier part. So I won't be able to say if it helped my issue, but it needs them anyway based on mileage.
2011 550i M SPORT
      09-24-2015, 03:52 PM   #43
Zer0Cool92
Ya I also have a very slight rough idle.. Keep us posted if changing the spark plugs makes a difference.
I'm looking to get mine swapped out as well. How hard is the install? Is it like changing spark plugs on any other car or is there some computer programming that bmw dealer has to do ?
      09-25-2015, 11:27 AM   #44
Autobuffoonery
I am groot
25
I will definitely post back after the plug change. The SA from bmw told me the car feels fine and he didn't notice anything, my next option is to test drive a new 550 and see how it idles, I bought my car used with 51k on the clock so I don't know what It was like when new. My girlfriend has an e60 and always tells me her car doesn't idle like that and something is wrong, I tell her it's my "hard on" she's feeling when I get behind the wheel of this beast! She's a little jealous, but her car is what had me looking at bmw's in the first place.
2011 550i M SPORT
