08-28-2015, 11:20 PM | #1 |
Dream crusher
984
Rep 2,421
Reading around about the VRSF DP it appeared everybody was pretty content on overall fit and finish and no long term problems seemed to have surfaced. Given the price point along with other users seemly satisfied i went ahead and ordered it.
Removal of the OEM DP was a PITA. The flange in the catback side did not want to wiggle out easily. We ended up dropping the entire exhaust system and then cork-screwed it out. It was a very tight fit as expected for OEM. Placing the VRSF into the piping before mounting we immediately noticed a problem. The flange on the cat back side was not a snug fit and in fact was way to loose for our comfort. We figured once exhaust was back up the clamp would bite into the DP alleviating the loose connection. We tighten the clamp down as far as the we could and the VRSF DP easily slid out by pulling on it. Truly unacceptable. I had to start wondering about those other reviews. Then we thought maybe it was just user error so we continued to wrestle with the clamp without snapping the bolt. We ended up pinching the bolt, applying pressure and wrenching the crap out of it. We managed not to snap the bolt and getting it to bite down on the VRSF DP, but by no means is it a perfect design. After install, started the engine and was bummed that I didn't get an increase in exhaust note. The damn 5 series is so freaking quite with those grandpa mufflers. Took it out for spin and the turbos are way more audible, but not necessarily in a good way. It sounds very metallic not awesome, but not horrible. It's cool I guess still getting used to it. I was really hoping it reduced turbo lag as our 5 series are notorious for that. It reduced it, but not by much. I've heard people claim as much as 50%, but I would venture to say more like 20-25%. So not much help on the low end, but that comes with the heavy 5 series we push around. The top end however there was a very noticeable increase and worthy upgrade for that portion of the car. Freeway passing has improved and the turbo sounds at those speeds is awesome. If I had to do it again I think I would not. Our OEM DP is not as restrictive as we think. Maybe they are for other chassis' but it's not a crazy bump in power or sound. Sound in terms of exhaust notes. If you like a really busy sounding turbo you may like that byproduct of the VRSF DP. Maybe other DP perform differently and this is just my personal experience. I thought I would share. UPDATED/edited: Ok some updates here and a slight apology to the VRSF DP product. I took my car to a known exhaust shop that does work on high end and muscle cars and they said it was not seated properly. They put it up on a lift and, used a crowbar to push the exhaust towards the DP and then tighten it. I will say that it has cured 90% of that leak sound, but I guess there's a natural metal sounding ring from the VRSF DP in higher RPM's. So my apologies to Tiago for improper install and review.
IG: @bmwdoubles |
08-29-2015, 12:09 PM | #3 | |
Rep 844
2014 M5 Competition with ESS Tuning Flash
Gone but never forgotten...2015 X5 50i M Sport, 2015 550i M-Sport, 2015 M3, 2014 X5 50i M Sport, 2015 435i M Sport, 2011 550i, 2011 535i |
08-29-2015, 01:48 PM | #4 |
Dream crusher
984
Rep 2,421
I will say that I just added this mod and I'm not sure about adaption time if any. Also my current tune probably needs to be updated to leverage it. I'll be visiting GSR soon and give updates at that point. The best effect was top end has noticeably improved.
Also my car smells like a carbureted big block when idling at the light. I don't mind just wish I had the exhaust note to match. Stupid 5 series grandpa mufflers are killing my exhaust game.
IG: @bmwdoubles |
08-29-2015, 01:56 PM | #5 | |
Rep 844
08-30-2015, 08:56 PM | #6 |
IG @bmwF9xG80
3817
Rep 7,595
Drives: G80 M3, X4M, G07 X7m50
Damn really the DP didn't add no extra sound ? and minimal gains?
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
08-30-2015, 09:27 PM | #7 | |
Dream crusher
984
Rep 2,421
IG: @bmwdoubles |
08-31-2015, 01:58 PM | #8 |
Joint Chiefs of Staff
24491
Rep 191,486
Sorry to hear that
Did you contact VRSF about the issue?
https://x-ph.com/sale/ Phone number 702-494-9435 |
08-31-2015, 02:11 PM | #10 | |
24491
Rep 191,486
Gas smell inside the car indicates you have a leak. Double check your installation.
poverty.f1078.00 |
08-31-2015, 02:58 PM | #11 | |
Dream crusher
984
Rep 2,421
1. The fitment on the outlet side was grossly off. 2. When we finally got the OEM bracket to bite the DP we didn't feel it was sealed 360 degrees. 3. That metallic sound I referred to earlier sounds more like a leak. The gas smell doesn't come in to the cabin unless my windows are rolled down. I think the DP is either defective or it needs to be flared before installing. I didn't measure it, but I do know OEM exhaust piping is 2.36 and the way the VRSF slid in and out seems like it was for a 2.5 diameter fit.
IG: @bmwdoubles |
09-01-2015, 10:52 AM | #12 | |
24491
Rep 191,486
09-01-2015, 10:56 AM | #13 |
Dream crusher
984
Rep 2,421
Ok will do thanks.
IG: @bmwdoubles |
09-01-2015, 09:58 PM | #14 |
Dream crusher
984
Rep 2,421
Here's the videos. You can hear the loud swoosh of air-sound. In Person it has a metallic ring to it. It's a leak.
IG: @bmwdoubles |
09-03-2015, 08:59 PM | #16 |
Dream crusher
984
Rep 2,421
Ok took a picture of the stock DP outlet diameter. Came out to 8cm or 3.149 inches. We're reaching out to Tiago to see if they'll just send a replacement with the correct size. I guess they had this down-pat for the n54 motor and n55 still needs some R&D?
IG: @bmwdoubles |
09-05-2015, 11:50 AM | #18 | |
Dream crusher
984
Rep 2,421
IG: @bmwdoubles |
09-05-2015, 12:28 PM | #19 | |
Rep 844
http://www.nationaltoolwarehouse.com...ampaign=bingPA Ive used them in a pinch and with an impact, they work well... that being said, Stainless is VERY hard to stretch so you may have to work at it a bit (factory stainless is typically very strong). At most it will take you 5 min and you can at least get a solid slip fit with it.
09-05-2015, 01:52 PM | #21 |
Rep 844
Id be willing to bet the downpipes may not even be made by them other than the original design, so while its "their fault" it didnt fit, it very well could have been assembly error or poor quality control by the true manufacturer. Other than a handful of large companies with the ability to mass produce mandrel bends and/or lots of welding, many shops will produce the prototype and send it out for mass production. Even with a jig and ordering the components in mass, its very time consuming to tig weld everything together, polish it and get it "sale ready". If they were all hand built on a jig, the quality control would likely be better, but at an increased cost of having to factor a couple hours of assembly time plus prep into each one and having one guy down all the time doing it.
09-06-2015, 12:04 PM | #22 | ||
Dream crusher
984
Rep 2,421
IG: @bmwdoubles |
