2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Front brake pad change - torque settings required
      01-04-2016, 12:49 PM   #1
sixer
Drives: F10 520d
Hi I am about to change my front pads on my F11 2014. Does anyone know the torque specs for the job?
I have done a search and can find lots of info in the job but no torque specs so far.
Thanks
      01-06-2016, 01:44 AM   #2
Teddylongtooth
ZEROdoubleZERO
Teddylongtooth's Avatar
228
Drives: 2011 550i m sport
You don't need the torque specs, just tighten down the caliper bolts till their nice and tight. You do need to torque the wheels thou, I torque my wheels to 105flbs. If you must have the specs for the calipers you can always put you torque wrench on the bolts and see how much it needs to take them off just start at 40ftlbs and increase 5ftlbs at a time till the wrench clicks and it breaks the bolts loose at the same time, then use that number to put them back on. Just remember to retorque the wheels after you drive 25-30 miles.
      01-07-2016, 09:46 AM   #3
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
^^^^^What Teddy said ^^^^^
      02-19-2016, 04:11 PM   #4
jooobi3
jooobi3's Avatar
Drives: 2011 BMW 535i XDrive
My rear pad is due soon. Looking to it myself. Do I need to purchased new sensors every time the brake pad is up for due?
      02-22-2016, 11:52 PM   #5
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
I wouldn't unless you damage them.
