2010 2011 BMW 5 Series Forum F10 BMW F10 Coding DIY (and other Fxx models) |
03-20-2017, 07:04 PM | #221 |
Rep 3
New BMW owner.
Hello,
I'm a new BMW owner that is interested in learning to code. May I get some info on where to download the proper files? I have a cable coming from Amazon. TIA Sean |
03-20-2017, 08:13 PM | #222 |
Rep 41,218
Drives: 2018 Alpina B6 650ix GC
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
03-29-2017, 11:16 AM | #223 |
Rep 5
Esys Download Link
Hi Am new here,
I have a BMW 520 D Msport F10 2011 I am looking for esys download link as I want to code few things on my car can anyone help? sorry if this has already been asked before but I cant find the link anywhere |
03-29-2017, 11:32 AM | #224 |
Rep 41,218
PM sent.
04-04-2017, 07:50 PM | #225 |
Rep 3
Thank you for help with coding
Hello, Thanks to all on here for the plethora of information and help I received with the software setup. I finally got it all figured out and have coded the car.
04-04-2017, 08:20 PM | #226 |
Rep 41,218
04-04-2017, 08:43 PM | #227 | |
Rep 8,364
04-25-2017, 01:18 PM | #228 |
Rep 3
I got my ENET cable today, and where do I start?
Hello,
I got my ENET cable today, and I have downloaded the e-sys 3.28.1, I also downloaded the psdzdata 61.2.0500 lite version, everything seems to be ready, however so many things come up to my mind before I dare to code. 1. What are Launchers? I have seen many website providing Esys Launchers to download, do I need them? 2. I also found a Chinese software call esysplus, what is that? 3. What is EST token? What is that used for? 4. What is ISTA-P? Do I need that? 5. Before the version 3.27.1, there is a patch coming with the package, and it seems you need to use the patch to make esys work, but i don't find the patch in esys 3.28.1, how come? Sorry i have so many questions. I just want to make sure i have everything needed in hand Thanks. |
04-25-2017, 01:31 PM | #229 | |
Rep 41,218
2) E-Sys Plus is a similar Chinese Tool, but no where near as functional as E-Sys Launcher is. 3) .EST Token is required by E-Sys in order to invoke the FDL Editor (Make FDL Code Changes). 4) ISTA/P is Dealership Software for Programming (Flashing ECU's) and Encoding (VO Coding) them. E-Sys can do the same. 5) Patch no longer needed as .EST Token Solution is provided by E-Sys Launcher now.
04-26-2017, 03:16 AM | #230 |
Rep 3
Shawn,
Thank you so much for the answers. I came across some problems while installing E-sys launcher. 1. I installed e-sys 3.28.1 and it went well. 2. I then install e-sys launcher premiere, and it went well too. 3. When i started e-sys launcher, the program prompted me for activation code, which i didn't have one 4. I jsut followed the instructions and sent an email to TokenMaster, but still got no reply 5. Can i just run e-sys 3.28.1 with token that was generated by token generator without launcher Thank you very much |
04-26-2017, 06:55 AM | #231 | |
Rep 41,218
08-15-2017, 07:15 AM | #233 |
Rep 107
I want to code blinkers in HUD and "Auto-on high beam assistent".
Do i have to code all this parameters to it works normal? And is brake force correct for EU roads? |
08-15-2017, 03:54 PM | #234 | |
Rep 8,364
For HUD, yes, you must code KOMBI and HU_NBT. For EU BFD, enabling is the same; but should be on from factory in EU vehicles with a few different parameter settings. |
Bruno11219.50 |
08-23-2017, 08:56 AM | #235 |
Petrolhead
445
Rep 814
I took the lazy route and got Carly. I was able to get done 99% of what I wanted done.
The only other thing I wasn't able to do and I'd love to know if it's possible is enabling auto parking brake. I sorely miss this feature on my MB. I didn't see a mention of it in the coding guide. Anyone know if it's possible? |
08-23-2017, 09:23 AM | #236 |
Rep 8,364
I have not seen coding to enable auto-E-brake, but it will engage automatically if you use Auto-H. It auto-releases as well if seat belt buckled.
08-23-2017, 10:25 AM | #237 |
Rep 118
Drives: BMW F80 M3
Hi,
I have installed the same esys and version on two computers, and the laptop when I want to select the version of the car appears blank, someone knows why it happens? Laptop win10 Someone can help me to download the latest version with the launcher? |
08-23-2017, 10:39 AM | #238 | |
Rep 8,364
Coding: (No Request) Latest Software Links |
DeividF80M344.00 |
08-23-2017, 10:53 AM | #239 | |
Rep 118
Drives: BMW F80 M3
08-23-2017, 11:51 AM | #240 | |
Rep 5,409
08-23-2017, 11:54 AM | #241 | |
Rep 8,364
Bad cable will make it difficult to connect via VIN, but target window will still be populated. |
08-23-2017, 11:58 AM | #242 |
Rep 118
Drives: BMW F80 M3
