2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Help with alpina turbos
      03-13-2018, 12:41 PM   #1
Morebs4me
Drives: 550i
So I received the ebay alpinas and had one diverter valve bad as soon as I installed. I swapped with one out of my Garrett 2256, the stock n63 turbo, and got it driving but the boost between banks is insane. Bank one with my 2256 diverter valve is right on target, but bank 2 is anywhere from 3-6 psi higher. I marked the wastegate and tried to get closer but ran out of room on the rod to loosen it. Could it really be the diverter valve causing this, I assumed it played no part until releasing boost when you let off the throttle. I have two new ones on the way, but the only issue I have is the imbalance. I went to make the diverters matching from my old turbos and find my second diverter valve ripped to shreds. I bet that’s why I could never get my boost up like I could a year ago. Any advice?
      03-13-2018, 11:59 PM   #2
Morebs4me
Drives: 550i
Gonna get matching diverter valves and go from there. Alternator died today, so hopefully tomorrow I’ll fix that and by Thursday or Friday I can pull the turbo and change one or both diverter.
      03-15-2018, 02:42 PM   #3
addy27
Drives: F10 550i
What Alpina Turbos did you end up getting? the newest ones with the 60mm impeller and the Alpina BOV or from the Pre-LCI Alpina with Diverter valves?
      03-15-2018, 09:51 PM   #4
Morebs4me
Drives: 550i
2012 with diverter valves. Turns out both my old turbos diverter valves were shot and I missed it at midnight installing it. A new diverter valve in the alpinas and I’m only a few psi off. It feels insane now, so much more power. The case is 2259 so I assume still 59 or 60mm impeller.
      03-16-2018, 04:06 AM   #5
addy27
Drives: F10 550i
Just wanting to confirm, are your alpina turbos the same as this listing :
https://www.ebay.com/itm/Right-Turbo...1aowq0&vxp=mtr
or this one :
https://www.ebay.com/itm/Turbocharge...FZn7YC&vxp=mtr
The second one is the bigger turbo with a much bigger diverter/blow off valve. First one looks like a stock N63 Diverter.
      03-16-2018, 04:15 AM   #6
addy27
Drives: F10 550i
Also, what tune are you running? or have you got JB4 or other piggyback added?
      03-16-2018, 10:39 AM   #7
Morebs4me
Drives: 550i
Serg tuned it but for stock turbos not these. I have jb4 but still on map 0. Both turbos are the same I think when I checked part numbers. My diverter valves are huge compared to n63, I ordered a pair for both turbos.
      03-16-2018, 01:23 PM   #8
addy27
Drives: F10 550i
So i looked and it seems the alpina blowoff valve is essenstially a beefier diverted valve. The function is the same : to send excess air back to intake side. I’ll read up on Serg’ s tune. My car is a daily so shipping DME is a concern. Did dinan ever really tune the n63 or just released the dinantronics piggy back system?
      03-16-2018, 07:22 PM   #9
Morebs4me
Drives: 550i
Idk. With my alpina Serg’s tune is doing 12.1-12.2 at 118-119 mph but my launch is awful. Over 2 second 60 ft lmao.
      03-16-2018, 08:00 PM   #10
badblack550xi
badblack550xi's Avatar
just need more time on track and you will be in 11's
2011 550i RWD 60-130 7.35
      03-16-2018, 09:34 PM   #11
Morebs4me
Drives: 550i
11.964 at 118.68 with 1.939 60 ft.
      03-17-2018, 10:22 PM   #12
warpeacelove
Drives: 550i
So you weren’t able to TUNE the upgraded Alpina B5 (803709-0007) Turbo’s-Is that correct?
      03-18-2018, 11:41 AM   #13
Morebs4me
Drives: 550i
Haven’t been up to try, I installed it and was testing on my current tune and had plenty of fuel for e30 and 16-18 psi
      03-19-2018, 12:26 AM   #14
SchillerM
Drives: 11' 550i, '00 M5, '11 E90 335i
N63 they tuned. Stage 6 is for Alpina turbos, IC, exhaust, and intake. Not listed in their site but available by request. They never got CARB approval so they stopped listing it.
The TU gets the dinantronics system.
      03-19-2018, 12:01 PM   #15
warpeacelove
Drives: 550i
How much HP/TQ does stage produce in comparison to JB4 Beta + BCM?
      03-19-2018, 01:24 PM   #16
badblack550xi
nothing dinan can compare to JB4 even stage 1
      03-19-2018, 02:01 PM   #17
Morebs4me
Drives: 550i
I’m doing 16-18psi on e30 on alpina turbos. I’m 100% dinan wont touch the numbers I’ll get when I dyno.
      03-19-2018, 03:18 PM   #18
SchillerM
542/587 for stage 6
521/585 for stage 5
Not a huge difference in peak numbers, but I believe the curve was good all the way.
The ideal to me would be Stage 6 for daily use, and a JB4 to manipulate 3.5Bar sensors, and have the ability to go wild when needed.
2011 Space Grey 550i - Eisenmann exhaust, ACS Springs, Dinan Intercoolers, Intake, & Stage 5 tune
2011 Space Grey 335i - M Performance exhaust - Wifes
Past: 2000 Avus Blue M5 - Dinan exhaust, flywheel, & tune 180k+miles
      03-19-2018, 06:47 PM   #19
Morebs4me
Drives: 550i
I did 525 on stock turbo with jb4 and bcm with similar psi, I don’t know what I’ll dyno now.
      03-19-2018, 09:12 PM   #20
warpeacelove
Drives: 550i
You mean additives? With Dinan tune no additives are being used. Now with the JB4 + BCM it requires high octane fuel. I want to make power without steroids.
      03-19-2018, 09:17 PM   #21
badblack550xi
pull out the turbos then
      03-19-2018, 09:56 PM   #22
warpeacelove
Drives: 550i
I forgot Dinan use upgraded Turbos.
