2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions F10 550i electromechanical power steering help
      01-12-2019, 09:16 PM   #1
335socal
Drives: Alpine white 335 coupe
Having issue with my steering. Every time drive and turn the wheel to left or right I hear a grabbing sound on the passenger side. It sounds like the brake pads is grabbing. I already changed wheel hub bearing assembly, brake pads and rotors and steering fluid (11s) noise still there!
      01-12-2019, 09:37 PM   #2
jonobro
Drives: bmw f10 535i
Originally Posted by 335socal View Post
Anyone got a good diy for doing power steering flush? Couldnt find any. Greatly appreciate it! Thanks!
Why are you doing this ?
      01-12-2019, 10:12 PM   #3
335socal
I am hearing a whiring sound when turning left and right at slow speed.
      01-12-2019, 10:16 PM   #4
Always a good idea to flush fluids on a regular basis.
      01-12-2019, 10:32 PM   #5
335socal
Please do! Always! Make it part of your oil change every 3k miles. Dont be like me.
      01-12-2019, 11:46 PM   #6
jonobro
What fluids exactly ? I'm at 110k+ I have yet to flush anything besides oil change of course haha
      01-12-2019, 11:49 PM   #7
335socal
CHF 11s
      01-12-2019, 11:57 PM   #8
jonobro
CHF 11s
No I'm asking what things does he recommend to flush often
      01-13-2019, 10:43 AM   #9
335socal
Nobody done PS flush?
      01-13-2019, 03:20 PM   #10
I didn't saw often, I said regularly. I would follow BMW on the brake fluid. I would flush the trans and change the diff every 75Kish miles. I would do the coolant every 2 years. I would do the P/S fluid every 2 years also, if I had mechanical P/S.
      01-13-2019, 03:21 PM   #11
Only the X-Drive (maybe the "D"?) has mechanical P/S. The RWDers have electric P/S.
      01-13-2019, 05:46 PM   #12
335socal
That kinda makes sense. Hmmm. So its my EPS thats messed up? Already changed wheel bearing assmbly, rotors, brake pads.
      01-13-2019, 05:59 PM   #13
Any concern other than the noise? I have read about bad racks...
      01-13-2019, 09:06 PM   #14
335socal
https://youtu.be/3TPWyW1iYmk
When I reset my EPS via ISTA+ the sound went away and came back after reboot. Then when I am turning left and right while moving with little throttle the sound is more pronounce. Like the brake pads is grabbing.
      01-13-2019, 10:12 PM   #15
335socal
my theory is that my EPS is about to get fkd. EPS is more to the right of the car and that's where I hear most of the noise coming form. specially when turning.
      01-14-2019, 09:55 PM   #16
335socal
got tired of diagnosing the issue. Brough it to one of the shops near me that is certified DINAN distributor/installer.
      01-15-2019, 05:51 PM   #17
335socal
UPDATE! UPDATE! UPDATE! The shop mechanic says that it is my ARS... Hmmm. It make sense and after searching ARS it shows that it is an issue to some as well. Hope extended warranty will be able to cover it.
      04-09-2019, 08:20 AM   #18
Encendido3
Encendido3's Avatar
Drives: 2016 535i M Sport
What exactly did the do to fix the issue?
      04-09-2019, 02:11 PM   #19
335socal
There is a TSB for the ARS need to have a bushing. Then the valve block got replaced as well. The EPS started to make noise and will be replacing it. Already ordered the parts.
      04-10-2019, 12:35 AM   #20
535_BiTurbo
Drives: 2012 550I - BMS Stg 1 & CAI
How hard was it to change the wheel hub assembly?
      04-10-2019, 12:11 PM   #21
Encendido3
Encendido3's Avatar
If you don't mind me asking, where did you get the part? And did you order the EPS motor only?
      04-10-2019, 04:11 PM   #22
335socal
I had the dealership do the TSB due to the extended warranty wont payout to replace the valve block if TSB is not complete. less than $200 to install the bushing. The EPS does not come separate. I had to order the whole system which is lessl than $3k after the core has been returned. Installation should be pretty straight forward coz it is electric and not hydraulic.
