2010 2011 BMW 5 Series Forum F10 Nickco43's Cheap Used Car 2011 535XI Build Log |
06-10-2020, 10:40 PM | #45 | |
Rep 1,933
Trainwreck914132.00 |
06-10-2020, 10:42 PM | #46 | |
Rep 1,917
06-11-2020, 11:49 AM | #47 | ||
Rep 1,933
Scroll down to parts for his info. Hope he can help you out! |
06-12-2020, 03:26 PM | #48 |
Rep 1,917
I finished my OFH and took it for a drive to the gas station. The car was starting to overheat reaching the dead center of the oil temp gauge. I sat there for a while and heard a shit ton of air come out the expansion tank. Once cooled down I make it back home were I found out my easy fill coolant funnel has an attachment for BMW.
Tonight I need to put the CIC gear back in the car to flash my ZGW from CIC to NBT. That is the cause of my issues with car functions on the NBT Evo. My $40 NBT screen also arrived. |
06-12-2020, 03:41 PM | #49 |
Rep 68
Drives: 2011 535ix M-sport
Did you also activate the electronic water pump to bleed/purge the coolant system?
'11 535ix M-Sport - FMIC, CP, BM3 engine & trans, CQuartz Finest Ceramic, Poly tension bushings, Dynamic, Active Roll, Flappy paddles, HUD, Premium(s), Cold, Convenience, 5-cameras, 4-zones, Driver's Assist, Auto high, Hex trim
'92 850i, '08 XC90 3.2 Past: '93 525i w/ S38B36 M5 engine/trans swap, '99 540i/6sp Sport, etc. |
06-12-2020, 10:14 PM | #50 |
Rep 1,917
06-12-2020, 10:54 PM | #51 |
Rep 68
That should have worked. Sometimes you don't hear it right away. Good thing you are going old school with the procedure.
https://blog.bavauto.com/13140/bmw-c...bleeder-screw/
06-13-2020, 02:09 AM | #52 |
Rep 1,917
I got my interior mostly back together and I put 20 miles on the car today. I need a ZGW2 for the NBT Evo to fully work with the car. Last edited by Nickco43; 06-21-2020 at 10:34 PM.. |
ezaircon4jc4557.50 OnlyGerman363.50 |
06-16-2020, 08:50 AM | #53 | |
Rep 29
06-16-2020, 08:55 AM | #54 | ||
Rep 751
Drives: '13 F13 M6, '94 JDM Supra
If you can afford to go coilovers do it, if not most of the springs out there are pretty similar, provided your stock dampers are young and healthy. My car had super low miles and lived in Florida all its life so I went with H&R springs and I'm very happy.
2013 F13 ///M6 Alpine White • Zandvoort Full Merino Driving Assistance Pkg • Exec Pkg • Vent Seats
Vorsteiner VFF-103 Carbon Graphite 343M dimensions • H&R Lowering Springs • Soul PP Resonated Muffler Delete • AeroFunction AF-1 Carbon Front Lip • Carbon Front Grilles • Carbon Mirror Caps • IND Black Fender Vents |
06-16-2020, 10:41 AM | #55 |
Rep 1,917
My car is at the dealer and it passed emission and inspection. Sadly my vanos bolt heads did not drop and I will not get a free oil pan gasket. The front axles are throwing grease everywhere and the dealer wanted $1600 for new CV boots. I spent $675 on rock auto for both new axles and front diff fluid. My 6WA cluster comes in today. I got a call from FCP on Monday and they said that they are going to reimburse me for my OFH.
I rang up kies about their M sport front bumper kit since my front bumper is shot and it turns out it drop ships from California. I bet it is the same bumper on eBay that is priced $200 cheaper. I don't know why people buy from kies. They are not a retailer, they are just drop shippers that add zero value for the markup they charge. Last edited by Nickco43; 06-16-2020 at 10:49 AM.. |
06-16-2020, 05:03 PM | #56 |
Rep 1,264
06-17-2020, 01:09 AM | #57 |
Rep 1,917
ezaircon4jc4557.50 |
06-21-2020, 06:40 PM | #58 |
Rep 1,917
I did both front axles, polished my windshield and put on a windshield coating. What a dirty job but it was worth it for the cost savings.
This week I want to get an alignment, do driveline fluids, finish my NBT Evo and get a quote to have my front bumper resprayed. |
06-21-2020, 10:31 PM | #60 |
Rep 1,917
The windshield coating was a demo kit of glassparency that I got a while back. I scrubbed my windshield with their cleaner before hand but after I put the coating on I noticed some hard water spots on the far passenger side of the glass.
I used this product to polish scratches out of my windshield: https://www.amazon.com/Polishing-Gor...MED8HJERYM3553 It takes a while but it took out two wiper marks on my F10 and one pretty deep one on my E90. You mix the powder in a slurry and you use a corded drill to slowly polish the glass. My dream is to get a $1500 climate comfort windshield with HUD and KAFAS support but I don't know if I will ever justify that. Currently my windshield is now in excellent condition. |
06-22-2020, 02:16 PM | #61 |
Rep 1,917
I went to the body shop today and they told me it is not worth it fixing my factory bumper. I called Kies to see if I could local pickup there m sport front bumper kit and it turns out they drop ship from CA (ie it is just a marked up eBay bumper). So instead of overpaying for their bumper I just went ahead and got the bumper direct from eBay.
https://www.ebay.com/itm/PreLCI-F10-...72.m2749.l2649 Body shop said it would be about $350 to paint it which is pretty good for a OEM quality proper paint job. |
06-27-2020, 10:14 AM | #62 |
Rep 1,917
I replaced my transmission fluid, transfer case fluid, windshield cowl and blower motor. I thought the rattle was the motor itself and not that outer filter that deteriorates into the motor. I ordered a new outer filter as well as a new cabin air filter that should be here next week. The old transmission and transfer case fluid looked great at almost 100k miles. I highly recommend doing drive line fluids if you are keeping your car long term. I took the car on a two hour trip into South Jersey this weekend and it performed great. The only issue is that the seat cause my back to hurt after a while. I am not sure how to properly adjust the lumbar for my back. I also noticed that the OEM pads really dirty the wheels. I am so use to ceramic low dust brake pads that I will probably swap in soon.
06-29-2020, 10:19 AM | #63 |
Rep 1,917
Last night I replaced my truck shocks and dyed some of the worn bits of my interior. I put a bit too much dye on the driver's side center console but overall it turned out great! Beats buying a new door card and center console lid. I used this kit from eBay: https://www.ebay.com/itm/BMW-OYSTER-...72.m2749.l2649
As for the trunk shocks the only side that has a shock is the passenger side. I bought both sides aftermarket on eBay for $30 and they work pretty good. At least my trunk does not slam open anymore. |
06-29-2020, 05:06 PM | #65 | |
Rep 63
Drives: 2012 BMW 535xi
06-29-2020, 06:57 PM | #66 |
Rep 1,917
It is dry to the touch is about 10-15 minutes. If I were to do it again I would have used the smallest amount to help keep the grain of the leather. I mean you need like a few drops of the dye on the included brush.
Today I replaced my interior door handle trim with the new eBay unit and it looks amazing. The eBay trunk shocks are junk and I am going to get OEM ones eventually. I still need to fix my dash cam install and my rear sun shade. |
