2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Nickco43's Cheap Used Car 2011 535XI Build Log
      06-29-2020, 07:52 PM   #67
Unspec
Unspec's Avatar
1312
Drives: 2015 BMW 535xi
Nickco, how did you get the original mickey mouse flange out? I couldn't get it out for the life of me to do the metal flange upgrade.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      06-29-2020, 07:55 PM   #68
Dan944
Drives: 2012 BMW 535xi
2012 BMW 535xi  [0.00]
Originally Posted by Nickco43 View Post
Originally Posted by Dan944 View Post
Nice! I need to do the same. What's the cure time?
It is dry to the touch is about 10-15 minutes. If I were to do it again I would have used the smallest amount to help keep the grain of the leather. I mean you need like a few drops of the dye on the included brush.
Today I replaced my interior door handle trim with the new eBay unit and it looks amazing. The eBay trunk shocks are junk and I am going to get OEM ones eventually.
I still need to fix my dash cam install and my rear sun shade.
Your build is coming out very nice. I need to do the dye on the driver door. My center is fine. I also have to change new door trims in black this time (the part that gets a gooey feeling). I just hope I don't break anything when taking apart the door panel. The part with the handle seems like it will be a pain.
      06-29-2020, 08:26 PM   #69
Nickco43
Nickco43's Avatar
1489
Drives: 08 E92 BMW M3
2008 BMW  [0.00]
I took a pair of vice grips and broke it. Then it pulled right out. Make sure the plastic bits do not go into the coolant hose.
I took my time with the door panel, this car is built too well. I just kept pulling on the one corner and I didn't break any tabs.
      06-29-2020, 08:45 PM   #70
Unspec
Unspec's Avatar
1312
Did you squeeze on the metal band area, or on the O-ring part?
2015 BMW 535xi
      06-29-2020, 09:22 PM   #71
Nickco43
Nickco43's Avatar
1489
2008 BMW  [0.00]
I squeezed near the metal band.
Unspec1311.50
      06-29-2020, 11:04 PM   #72
M_Bimmer
M_Bimmer's Avatar
612
Drives: G12 B7, G07 XB7, F02 B7, 991.1
Hey Nickco43,
When you get your rear sun shade installed, and run your white and green wires to your Junction Box (pin 3 and 30?) can you post what values you changed in the JBE VO?
I have swapped my Junction Box with an M5 version that had the rear sunshade, but my VO changes did nothing....and would love to get this activated.
Thanks!
      06-30-2020, 10:24 PM   #73
Nickco43
Nickco43's Avatar
1489
2008 BMW  [0.00]
Originally Posted by M_Bimmer View Post
Hey Nickco43,
Thanks!
You should be able to just add the VO code for sun shade and then factory code it to the jbbf. My car has the power sun shade from factory but it gets stuck up. I have my rear parcel shelf apart currently and I lubed everything up but it still gets stuck. I tried everything and it still gets stuck. I took apart the motor assembly and it seems to me like the spring inside gets weak overtime and does not have enough strength to go back down anymore. Unless anyone has any ideas I think tomorrow I am just going to delete the power sun shade. I don't think it is worth the $800 for a new one. I might buy a E31 sun shade motor and see if it will bolt up.
https://parts.bmwofsouthatlanta.com/...or-51461388215
      07-01-2020, 08:44 AM   #74
Unspec
Unspec's Avatar
1312
Maybe try too get a motor from a salvage car? I believe 6 and 7 series shared a ton of parts with the 5, so there should be a good selection
2015 BMW 535xi
      07-01-2020, 10:13 AM   #75
Nickco43
Nickco43's Avatar
1489
2008 BMW  [0.00]
I could only find the entire assembly for about $200. I would rather have a brand new motor for that price. I went ahead and ordered the E31 motor. I don't feel like putting my interior back in so I will drive my e90 around for a bit while I wait on the part.
      07-01-2020, 03:16 PM   #76
Nickco43
Nickco43's Avatar
1489
2008 BMW  [0.00]
My bumper came today and confirmed it is the same bumper kies sells for almost double the price. The fitment is pretty good and I can not wait to get it painted. I found out that my inter cooler must have cancer as the fins are just falling off.
      07-01-2020, 03:21 PM   #77
Dan944
[img]https://i.postimg.cc/d0c0kj5v/IMG-3706.jpg[/img]
[img]https://i.postimg.cc/gk5jdWRx/IMG-3715.jpg[/img]
[img]https://i.postimg.cc/VkC6kVBD/IMG-3716.jpg[/img]
[img]https://i.postimg.cc/L4xhCf8B/IMG-3723.jpg[/img]
[img]https://i.postimg.cc/kXDGk4Vr/IMG-3724.jpg[/img]
The fitment looks great. That's the mtech one right?
      07-01-2020, 03:39 PM   #78
Nickco43
Nickco43's Avatar
1489
2008 BMW  [0.00]
https://www.ebay.com/itm/PreLCI-F10-...53.m2749.l2649
      07-01-2020, 04:14 PM   #79
beegeezy
beegeezy's Avatar
70
Drives: 2013 535i M-Sport
The G-Plus intercooler (wagner knock off) is a cheap and popular option.
      07-01-2020, 04:24 PM   #80
Nickco43
Nickco43's Avatar
1489
2008 BMW  [0.00]
Someone I know recommended me this intercooler from this eBay seller:
https://www.ebay.com/itm/Intercooler...53.m1438.l2649
I don't really care if the knock off flows worse than the real one or not as I am only going to go stage one. I might even just get a OE Nissans one from rock auto for $150.
      07-01-2020, 08:22 PM   #81
Unspec
Unspec's Avatar
1312
Yea that's the same as the g-plus, just without the g-plus branding. Probably from the same factory. Are you sure that's the intercooler losing the fins? IIRC, the intercooler doesn't directly face the exterior, I think that might be the radiator losing its brains.
Edit: That's the radiator (edit: jk it's the ac condenser), you can see the stock intercooler behind it in your picture. Stock intercooler has those thick ass bars between the plates.
Edit 2: The M sport retrofit they sell from ebay isn't quite complete. It's missing the foam absorber, p/n 51117903993. Base one is a bit thicker and might cause a large bumper-to-hood panel gap.
Edit: Probably the AC condenser based on what others have said.
2015 BMW 535xi
      07-01-2020, 10:41 PM   #82
Trainwreck914
Trainwreck914's Avatar
Drives: BMW F10 F15 E39 E90 E53
Actually. I think that may be the AC condenser. I just replaced mine. It was the very front item behind the bumper.
      07-01-2020, 11:27 PM   #83
Nickco43
Nickco43's Avatar
1489
2008 BMW  [0.00]
Edit: That's 100% the radiator, you can see the stock intercooler behind it in your picture. Stock intercooler has those thick ass bars between the plates.
Edit 2: The M sport retrofit they sell from ebay isn't quite complete. It's missing the foam absorber, p/n 5111790399. Base one is a bit thicker and might cause a large bumper-to-hood panel gap.
This bumper might have been shaped to go around the stock foam pad. I will see how much the dealer wants for the foam pad tomorrow.
My AC still blows 100% ice cold so I will hold off on replacing the condenser. I am going to be honest I am getting tired of dumping money into this thing. The check engine light came back on today. I still have the bad cat code and now I have a evap leak. With the body shop bill I am going to be past 13k into the car.
      07-02-2020, 08:15 AM   #84
Unspec
Unspec's Avatar
1312
The bumper is not, it uses the same mold as factory. It even comes with the little X marks (if you get one without PDC pre-drilled) for where to drill the PDC. It's 80 bucks off of FCPEuro but I know you're not too keen on them right now. You can also find it cheaper off of ebay, but shipping times will be pretty long.
2015 BMW 535xi
      07-02-2020, 09:01 AM   #85
Dan944
Are you talking about this one? https://www.fcpeuro.com/products/bmw...-m-51117903993
      07-02-2020, 09:07 AM   #86
Unspec
Unspec's Avatar
1312
That is the part, yup
2015 BMW 535xi
      07-02-2020, 08:17 PM   #87
Nickco43
Nickco43's Avatar
1489
2008 BMW  [0.00]
The bumper foam was $84 from the dealer shipped. The car is at the body shop and should be done Monday. I went ahead and bought a charge pipe and a MHD flasher thing from BMS. Apparently MHD has a better tune for my 11 N55 which is more like a E90 N55 then anything else.
      07-02-2020, 09:48 PM   #88
Trainwreck914
If the ac is still working I wouldn't dump the money til it goes out. But the condenser are known to have a weak point.
