2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum F10 Carplay
      07-26-2020, 04:37 PM   #1
Philgau1
Drives: BMW F10 20212
F10 Carplay
Hi, I have 2012 f10 with a cic system, and my friend has an older bimmer tech cp-bm12 Multimedia Interface, now the lvds plugs are showing 6 pins, and my system is 4 pin, is there a way I have rewire this to work, or is it worth getting a cic mmi?
      07-26-2020, 05:27 PM   #2
OnlyGerman
OnlyGerman's Avatar
Drives: F15, F13, F10, E60
Bimmertech is making another unit for CIC
      07-30-2020, 09:00 AM   #3
dzz
Drives: 2015 BMW 535xi, MHD Stage 2+
2015 BMW  [0.00]
You'll save a lot of money and get same functionality as bimmertech by getting Android based unit https://www.android-car-dvd.com/prod...35143168819363
you can find them for even less (between $220-$240) on Aliexpress
And you'll get a touchscreen. I think bimmertech unit is using original screen
      07-30-2020, 09:14 AM   #4
AmooManiak
Drives: 21 X5 M50i -> M2C -> 21 M5C
I don't recommend going aftermarket unless you really don't care about qulaity. The quality will not be up to BMW standards. All of these units are cheap and made in China. I had something similar in my E39 and the processor that they use is so slow and does not work as intended a lot of times. I compare it to seeing Youtube reviews when someone buys a knockoff Iphone or Samsung phone, where they make the presenation look nice in pictures, but once you get it, you wish you never had ordered it.
I had Bimmertech on the NBT, but sold my unit as I was not happy with the quality of the picture for $600.
I finally ended up going NBT Evo ID6 and it is probably my favorite mod I've done to the car as it's something I use every day. The picture is sooo crisp and clear, much better than my wive's 2018 Q5, which was good to begin with when it was introduced. Not to mention you get touch screen and BMW quality.
      07-30-2020, 10:15 PM   #5
dzz
2015 BMW  [0.00]
I had similar experience with Bimmertech and their front view camera is $50 camera they sell for $250
I agree that NBT Evo is the best, but there is also the question of cost, $220-$240 for Android based system, $650 for Bimmertech MMI and Bimmertech sells NBT Evo retrofit for F10 for $2,200
      07-30-2020, 11:42 PM   #6
Nickco43
Nickco43's Avatar
1489
Drives: 08 E92 BMW M3
2008 BMW  [0.00]
Go buy the carplay box from aliexpress for like $300. One of them is the exact same box bimmertech sells.
      07-31-2020, 12:44 AM   #7
Unspec
Unspec's Avatar
1312
Software is pretty different though. Bimmertech one has some improvements that have yet to trickle down to the other boxes. This is probably the most comprehensive thread on the topic:
https://f30.bimmerpost.com/forums/sh....php?t=1675929
2015 BMW 535xi
ISTA VM Setup/Tutorial
      07-31-2020, 08:19 AM   #8
AmooManiak
I paid around $1,600-$1,700. This includes the screen, NBT Evo, regular I-Drive touch controller and coding. All items were in like new condition. IMO, that extra $1,000 over just the module is worth every penny.
Ended up upgrading to Cermaic I-drive controller which I'm not including in the cost as it was not needed, but I wanted to have it match the rest of the interior.
      08-01-2020, 08:11 AM   #9
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
i really need to update my tiny 6" screen. so much info out there as to which way to go
      08-04-2020, 10:55 PM   #10
ChampagneQrtzPapi
Drives: BMW 535i
I need to replace my screen and I feel overwhelmed on where to start! Idk if I should just replace it or replace it with an upgrade.
I do know, however, that I'm not a fan of the G30 screen. It looks really outta place.
      08-04-2020, 11:30 PM   #11
dzz
2015 BMW  [0.00]
I am not sure that Bimmertech's improvements justify almost 3x the price. The hardware is exactly the same
      08-04-2020, 11:31 PM   #12
dzz
2015 BMW  [0.00]
Keep your screen and use this https://www.android-car-dvd.com/coll...32066140471432
      08-05-2020, 08:15 AM   #13
OnlyGerman
OnlyGerman's Avatar
I have a feeling it won't look as clean on CIC given the lower resolution compared to NBT
      08-05-2020, 09:06 AM   #14
Unspec
Unspec's Avatar
1312
Quick update for those interested. Forums members over at the F30 side managed to basically unlock the software DRMs that the manufactures have started placing. You can buy the Aliexpress units and run the Bimmertech software on it now, along with other various improvements, via custom firmware.
2015 BMW 535xi
      08-05-2020, 10:36 AM   #15
OnlyGerman
OnlyGerman's Avatar
I believe you could upgrade the screen to the large and code the resolution. Obviously this doesn't just add any features, just gets rid of ugly small screen.
      08-05-2020, 11:43 AM   #16
lsturbointeg
Do you know which app would allow me to code this? Carly?
      08-05-2020, 12:12 PM   #17
Unspec
Unspec's Avatar
1312
Bimmercode can.
2015 BMW 535xi
      08-05-2020, 02:56 PM   #18
ChampagneQrtzPapi
Drives: BMW 535i
The thing is I have some dead pixels on my current screen, assuming from the previous owner. I'll need to replace it as well. I'm just not sure if any upgrades will be worth it.
      08-05-2020, 03:25 PM   #19
OnlyGerman
OnlyGerman's Avatar
Definitely bimmercode via expert mode but this info was from the f30 forums, have not seen anyone with f10 do it.
      08-09-2020, 11:59 AM   #20
dzz
2015 BMW  [0.00]
E-sys will do it too, this is from F30 thread, but HU_NBT is the same module in F10 and F30 https://f30.bimmerpost.com/forums/sh...730&page=4
"After replacing the screen you need to code the following values:
HU_NBT > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480
HU_NBT > 3001 EXBOX > DISPLAY_VARIANTE = breites_display"
