2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Xhd trans tune?
      01-06-2021, 10:07 PM   #243
ansonliu99
Drives: F10 535i
Worth the money to spend on it?
      01-07-2021, 04:45 PM   #244
labenzm5
Drives: E39 m5
100 percent
      01-07-2021, 05:01 PM   #245
Sylverlee
Drives: White 535i M-Sport, 911 GTS
I wish Sport shift speed could be applied to Comfort. The only thing I would change.
      02-09-2021, 08:12 PM   #246
Unspec
Unspec's Avatar
1312
Drives: 2015 BMW 535xi
Honestly I think the greatest feature of xHP is the fact that your car will go into 8th gear when cruise control is on and you're in sport mode. It was always my biggest gripe with the stock logic, since either I have to turn off sport or go 300+ miles in 7th gear. Sure it's only one or two MPG difference, but it adds up on long road trips.
Now, I can cruise in 8th and the second I turn it off, I'm in 7th or 6th ready to go.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      02-16-2021, 11:09 PM   #247
Unspec
Unspec's Avatar
1312
Hm, anyone notice that there's a slight delay to the paddles? On the pre-XHP setup, as soon as I tapped the paddle it started shift. Now, it takes maybe half a second to shift. This is on sport+ with the shifter to the left.
2015 BMW 535xi
      02-17-2021, 07:57 AM   #248
Surly73
That sounds like what I observe in full comfort mode (now that I have a DEC switch retrofitted). Definitely not what it did pre-DEC or post-DEC in anything but "COMFORT".
      02-17-2021, 08:35 AM   #249
Unspec
Unspec's Avatar
1312
Hm, time to reach out to RBT
2015 BMW 535xi
      02-17-2021, 09:07 AM   #250
Sylverlee
My paddle response was much improved over stock. Although I'm pre-LCI
      02-18-2021, 05:21 PM   #251
dzz
Drives: 2015 BMW 535xi, MHD Stage 2+
2015 BMW  [0.00]
No delay at all, shifts are faster than pre-XHP in my case in Sport/Sport+ mode
      11-11-2021, 11:33 PM   #252
TuckerE36
TuckerE36's Avatar
50
Drives: BMW 550i M Sport
Any resolution? stage 2 xHp in sport/sport+ when I tap the paddles there is almost 1/2 second delay, pre-xhp there wasnt near that much delay. So far I'm really not happy with xHp. Comfort D it puts the transmission in 8th gear at 40 mph and 1k RPM. Shifting is much more rough than it was stock in all drive modes, E/C/S/S+. Maybe I need to reset the adaptation
2014 BMW 550i M Sport- Tuned by Matt @Cedar Performance-Daily Driver
2016 Audi Q5 3.0T Prestige-Weekend Warrior
2008 Infiniti G37S Coupe 6MT-RIP
2015 Lexus RC350 FS-SOLD
      11-12-2021, 06:53 AM   #253
Surly73
Back in my early days with xHP (years ago) I noticed behaviour like this. At the beginning they had NO support for cars without a DEC switch (seems rare). They made some software change, possibly just for me, and it supported non-DEC cars.
One time after they did a major update I ran into more problems. It had to do with how I coded paddle support. I had VO coded 2TB, but did not have a DEC switch. According to xHP this created a combination which did not exist (all factory 2TB cars would have a DEC switch) and caused worse-than-stock performance because there were no maps for these non-existant cars. At the time, I changed to FDP coding just the paddles into the SZL, removed the 2TB and xHP worked great again.
I kept running into xHP bugs, unrefined shifts in some conditions and eventually retrofitted a DEC switch. As soon as I did that, any remaining slight dissatisfaction with xHP was gone. It's been great since. I can VO code 2TB and everything works great.
So, all that to say - those with worse-than-stock performance out of the box: Any interesting retrofits on your cars? Any FDL or VO coding done? Either way, definitely contact them - xHP is great for me and they're still adding features and controls.
      11-14-2021, 07:55 PM   #254
TuckerE36
TuckerE36's Avatar
50
Maybe I should reach out or just reconfig to my liking.
      11-20-2021, 05:22 PM   #255
wihaM5
Drives: BMW 550i ; BMW 335i
2011 Bmw 550i  [0.00]
I know this post is quite old but does anyone know of a similar trans update for the f10 550i. I have had a ton of trouble getting good information on this. I plan to do a bunch of mods this winter and I would like to prepare for putting the power down without issues when it comes to the transmission.
CSS
      11-21-2021, 12:02 PM   #256
Surly73
I don't understand what you mean or why you don't think xHP is suitable.
xHP is for all 6HP and 8HP transmissions, 550 included. It does increase line pressure, but there's only so much you can do in software.
      12-02-2021, 02:37 PM   #257
wihaM5
Ya I understand what you mean I was just considering trying to get ahead of a possible issue. What would be my recourse then idk
CSS
      07-13-2022, 04:04 PM   #258
automaz_
Enthusiast
automaz_'s Avatar
585
Drives: 2025 M4 Comp xDrive
I am currently FBO MHD Stage 2+ On my 2012 535xi. I would like to go XHP stage 3 and am wondering if I need to select the XHP option in MHD first then re flash stage 2+ first in order to then do XHP stage 3
