2010 2011 BMW 5 Series Forum F10 Bmw 5 series 535i 2011 Knocking sound |
09-14-2021, 03:38 PM | #1 |
Rep 4
I recently encountered a knocking sound from the engine. It knocks , then stops them later on it comes back it’s not permanent but it comes every now and then. The car has 84kmi. Changed valve cover, boost solenoid , tranny service, it’s tuned stage 2. Drives smooth. But it has that knocking sound that comes and goes. I’m thinking it’s the rod bearings but i don’t know much. Can anyone help ?
09-14-2021, 08:46 PM | #2 | |
Rep 35
www.blackstone-labs.com Send them an oil sample… it will be $30 well spent and you will know what is going on inside your engine. Good luck! |
09-15-2021, 06:49 AM | #5 | |
Rep 156
2014 BMW 550i M Sport- Tuned by Matt @Cedar Performance-Daily Driver
2016 Audi Q5 3.0T Prestige-Weekend Warrior 2008 Infiniti G37S Coupe 6MT-RIP 2015 Lexus RC350 FS-SOLD |
09-15-2021, 06:57 AM | #6 | ||
Rep 35
If we run MoS2 anti-friction I wonder how much that effects the oil analysis[/QUOTE] When you send in your sample, they ask if you use any additives. They can adjust for that in the analysis. Similarly, they ask what oil you use as different oils have different additive packages which will show up in the results. |
TuckerE3649.50 |
09-15-2021, 11:27 AM | #7 |
Rep 2,595
To be honest, if it's rod knock, an oil analysis won't tell you anything you won't already know.
2015 BMW 535xi
11-07-2021, 11:33 PM | #8 |
Rep 916
Rod knock will not come and go also.
Instgram @burninja
