2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Can I get a CEL P0456 by changing the engine air filter?
      11-12-2023, 01:52 PM   #1
VAB5
Drives: '15 535; '15 328; '05 ZHP conv
I changed the engine air filter on my 2015 535i, and upon startup I got a CEL with code P0456, Evaporative Emission Systems Leak. As far as I know, this doesn't seem possible unless I knocked something.
Any ideas? I carefully re-installed the air box and reset the code, and it stayed off for a couple hundred miles. Then the CEL came back, same code.
      11-12-2023, 06:14 PM   #2
Conserve
Drives: 1976 BMW 2002 & 2015 BMW535i
Check your gas tank cap. Perhaps not sealing correctly. Issue is minor leak in fuel/evaporation system. Also check post #4 in this post. that purge valve is on the left side of throttle body. Perhaps electrical connection to it become loose when you were working on air box somehow.
https://f10.5post.com/forums/showthread.php?t=1829080
