BMW 3-Series (E90 E92) Forum
Glow plug issue - Advice?
03-23-2022, 04:32 AM | #1 |
Rep 346
I was doing some work recently which involved having the manifold off and noticed I had an error on one glow plug so I thought I'd go ahead and replace all 6 (all 6 glow plugs and modules were replaced about a year ago previously). I didn't have any bad symptoms like a rough/lumpy cold start in regards to the one glow plug error.
Once I changed the glow plugs (I went for these https://www.ebay.co.uk/itm/372618154461) straight away on cold starts, especially in the colder mornings the car would run lumpy for 5-10 secs. I checked for errors and now it brings up an error on all 6 glow plugs (DDE: Glow plug, cylinder 'X' activation). So either all 6 plugs are defective or the glow plug module is, most probably the latter. So my question is, should you always replace the glow plug module together with the plugs? If you don't do this, can this cause the glow plug module to go bad? Seems a bit of a coincidence that as soon as the new 6 plugs were installed it runs worse and I go from one plug error to six. |
03-26-2022, 05:40 PM | #3 | |
Rep 346
Im just trying to understand if you should always change both at the same time and if maybe that is what caused my issue. I have heard it is a pig. Im probably going to do the valve/rocker cover gasket in the next couple of months so I’ll probably do it the. |
03-28-2022, 12:54 PM | #4 | |
Rep 667
I've had 4 330d's over the years and never changed any glow plugs, it's always been the controller, you don't need the change the plugs at the same time.
BMW E90 330d M Sport LCI in Sapphire Black
POBEP374.50 |
03-28-2022, 01:26 PM | #5 | |
Rep 558
I got my 335d (M57Y) last year, 131K miles - seller had paperwork on-hand with both glow plugs and module replaced recently. It would not pass emissions test as check engine light was on. The failed glow module appeared to be made by OE supplier. I replaced it with BMW branded one without taking off intake manifold. No more glow plug codes so far (1 year, 10K miles)
Rich_D96.00 |
03-29-2022, 04:19 AM | #6 |
Rep 317
Had a similar issue with my dad's old 535d. Replaced glow plugs and controller with OE parts and it had 6 glow plug faults registered after.
I would only ever buy a genuine controller next time. |
03-29-2022, 07:35 AM | #7 |
Rep 667
For information, the OEM glow plug controllers are made for BMW by Beru, so you can get the same part for less money, I fitted a Beru one in my current 330d well over 2 years ago and it resolved all glow plug errors.
The M57 uses a GSE102 and the N57 uses a GSE108, for the E9X generation.
03-29-2022, 10:30 AM | #8 |
Rep 346
Thanks, guys, good to know that it's not needed to change both together.
Strange how when installing the 6 new bosch glow plugs that it caused the glow plug module to go faulty straight away. Anyway, this job will be added to the list. |
03-29-2022, 10:31 AM | #9 | |
Rep 346
03-29-2022, 12:01 PM | #10 | |
Rep 558
E90 335d - M57Y is North America (SCR) version of the M57D30T2, (see attached document)
(my E91 is N52K/6AT, dreaming of swapping it with M57Y/6MT one day) Quote:
The trick is to detach (but not remove) Y-coolant pipe and (top) dipstick mounts. You then can get your (right) hand into the glow plug controller mount/connector area. I followed this video:
Rich_D96.00 |
03-29-2022, 12:43 PM | #11 |
Rep 667
realoem states you should not mix systems, i.e. Bosch plugs & Beru controller, for the N57 engine at least.
03-29-2022, 12:46 PM | #12 |
Rep 346
Ahh ok, that’s interesting. I’m not sure what make glow plug module it is as the last owner changed it, not me. Could explain why though. If it’s the same for the M57
03-30-2022, 06:57 AM | #13 | |
Rep 667
Could explain your issue though.
Processing6164.00 |
04-05-2022, 04:16 PM | #14 | |
Rep 346
I'll see now if the fact that I have bosch plugs and beru module will cause any issues. |
POBEP374.50 |
04-06-2022, 02:44 AM | #15 |
Rep 287
I probably wouldn't worry. I've got Bosch plugs and Beru controller with no issues at all on N57
Processing6164.00 |
02-27-2024, 11:37 AM | #16 |
Rep 43
While replacing glow plugs I noticed that M47 and M47N2 engines' glow plugs are not exactly the same. M47N2 glow plug has a designation groove. When I tried to install the M47's glow plugs to M47N2, I couldn't tighten them in properly. Every time I try to tighten them they get stuck halfway through. Greasing etc. does not work. But, when I again install the old one, it goes all the way without any problems. Yes they look same, however threads of both glow plugs are slightly different I think. 🤔
