2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Anyone do the F10 Dashboard Ambient Light Mod?
      10-03-2020, 07:25 PM   #1
M_Bimmer
M_Bimmer's Avatar
612
Drives: G12 B7, G07 XB7, F02 B7, 991.1
I thought I saw someone mod their F10 dashboard with ambient lighting....if you've done the mod, can you post a picture?
(Red lines in picture)
Although there are eBay light strips you can tuck under the dashboard trim, I want to use BMW parts (same parts used on the door trim)...but not sure if I want it all across the trim (above the glove box and radio) or just above the glovebox, so any pics would help.....
Thanks!
      10-05-2020, 05:05 PM   #2
OnlyGerman
OnlyGerman's Avatar
Drives: F15, F13, F10, E60
I tried this. I thought I could use the USB port in the glove box but it did not work and killed my idea. You won't be able to use Bmw genuine parts on this.
      10-05-2020, 09:29 PM   #3
M_Bimmer
M_Bimmer's Avatar
612
Almost done with the mod...biggest effort is trimming the bottom of the trim and not messing up the trim itself.
I'm using the 90 degree LED source from the door panel pocket, and ran the wires down to the footwell light wires. The footwell light modules has two lights sources and 4 wires, ambient red, and courtesy white LED light.
I used the long light guide from the top of the door panel, and uses a little heat to curve it to the dashboard curvature.
The LED light is being driven by the footwell module, so by tapping into the gray and gray w/ red dash wires, they work like "factory".
I will do the trim above the head light switch on the driver's side in a few weeks (need another LED connector)
I will post pictures this weekend. It looks awesome.....
Cheers
Nickco431488.50
Jamesmick131.00
      10-06-2020, 08:24 AM   #4
delviacv2
delviacv2's Avatar
Drives: 2014 X5 50i & 2015 535d
LED
Cheers
I purchased one of this sets and ended up not using it because the instructions were not clear, so is sitting collecting dust in my garage , post pictures of your final results
https://www.aliexpress.com/item/4000010385914.html
2015 535d Xdrive Sophisto Grey Metallic
-DUDMD Stage 1
-xHP Transmission Flash
2014 X5 50i Carbon Black/ M Sport
-BM3 Stage 1
      02-02-2021, 06:57 AM   #5
Scott523
Drives: Bmw f11
Hi iv done the ambient light install
      02-02-2021, 11:48 PM   #6
M_Bimmer
M_Bimmer's Avatar
612
Are you teasing us, or are you going to post a picture or two?
      02-03-2021, 03:41 PM   #7
With instructions.
      05-24-2023, 03:39 AM   #8
Napas
Drives: f11 520d m
teasing only
      05-31-2023, 01:52 AM   #9
Matgsand
Drives: BMW F1O 520d N47
Close to 10 hours spent fitting the ambient lights, but well worth it
      05-31-2023, 02:00 AM   #10
Matgsand
With led on only half the dash
EV8634.00
      06-01-2023, 08:22 PM   #11
DonDee
DonDee's Avatar
Drives: BMW 535i xdrive
2013   [9.50]
Nice
      10-30-2023, 01:57 PM   #12
RichUK
Drives: m5 competition f10
any chance of a link to where I can buy led strip-aliexpress is it?
      01-28-2024, 07:27 AM   #13
Lady_n52
Drives: 2011 BMW 528i
Reviving this old post. But I have a kit from aliexpress that plugs into the idrive. Was this the kit you used?
      03-24-2024, 01:04 PM   #14
mylanezu
mylanezu's Avatar
Romania
Drives: BMW 5 Series F11 LCI 2014
Hello,
I have a big issue with my BMW F11 LCI.
I have OEM ambient light and I replaced with beter one, Symphony 64 collors (5 different modules)
The ptoblem is that my light are flikkering when is turning on (like in the video). The new modules are powered by the original ambient light source from the doors.
Can somebody help me with some hints how to fix this ?
Thank you in advance !
      03-24-2024, 01:44 PM   #15
M_Bimmer
M_Bimmer's Avatar
612
Originally Posted by mylanezu View Post
...The new modules are powered by the original ambient light source from the doors.
You might want to go back and review the installation instructions that came with your aftermarket kit.
The OEM driver to your ambient lighting uses PWM from the Footwell Module (A58), and unless you are driving your aftermarket LED's (via resistor only) directly from the Footwell Module (A58) via the gray + gray/red wire pair, the aftermarket driver module is receiving a PWM power source from A58, which acts like cycling power on/off, which in turns, cycles the power to the aftermarket LEDs. You will get pulses LED operation.
To correct your aftermarket installation, your driver modules needs to be tapped into a constant 12VDC ignition source.
Given the complexity of your F11, and it's electronics, I'd never put ANYTHING aftermarket electronics in the vehicle.
Good luck trying to find a power source that will work as intended, other than your lighter socket, which it too will do funny things, like stay powered on for a bit of time after the ignition power has been turned off in the vehicle.
Do not hook your aftermarket LED controller straight to your battery, else you'll be back on the forum asking for more help.
Let us know how it turns out.
Cheers.
      03-24-2024, 02:31 PM   #16
zrile
zrile's Avatar
Croatia
102
Drives: BMW F31 320xd
Omg. 🤦🏻‍♂️ i would ban this by law.
      03-25-2024, 08:01 AM   #17
mylanezu
mylanezu's Avatar
Romania
Cheers.
Thank you @M_Bimmer for detailed explanation.
I still have some concerns about this, why the same kit works very well on BMW F36 2018 also with OEM ambient light ?
I will try to keep ''permanent'' 12V from other source for the doors modules and only Main module will remain connected to the OEM ambient ligth source (to have the trigger ON/OFF). Hope to be OK after that.
PS: Of course, lighter socket will not be taken into account !
      03-25-2024, 09:43 PM   #18
M_Bimmer
M_Bimmer's Avatar
612
I will try to keep ''permanent'' 12V from other source for the doors modules and only Main module will remain connected to the OEM ambient light source (to have the trigger ON/OFF). Hope to be OK after that.
Did your aftermarket LED kit come with wiring directions? If if did, can you take a photo and post it? If not, I don't want you to be concerned, and if you provide the kit part number, I can try to find the wiring information on the internet.
      03-26-2024, 03:37 AM   #19
mylanezu
mylanezu's Avatar
Romania
Hello. This is the kit used. It's not something science fiction Unfortunately, I saw a lot of people that it worked perfectly (even on F10). I don't understand why it does this for me when I set the intensity to maximum
I will check now also the voltage on the wiring, hope to have 12V...
      03-26-2024, 07:18 AM   #20
M_Bimmer
M_Bimmer's Avatar
612
Swap the wire connections on the power leads to the after market controller and the two wires you are using on the vehicle
