2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum More 2010 BMW 5 Series Details Emerge
      01-27-2009, 01:03 PM   #1
-=Hot|Ice=-
Been There, Done That.
-=Hot|Ice=-'s Avatar
Drives: 2013 BMW M3
New details of the 2010 BMW 5-Series are beginning to surface. Set for delivery during the 2nd quarter of 2010, the new 5-Series will carry a sportier design, and be slightly longer than the previous E60 generation.
Despite being longer, the functional dimensions stayed the same. Only the wheelbase was increased slightly. Aside from the sedan, a Touring version will come to market. That model should see daylight in October 2010. Each will have the wider BMW grille reminiscent of the BMW CS Concept, first shown in the Shanghai motor show 2007.
Several driver-assist systems will be available on the car, including a steering system with an active rear axle. This system will be speed-dependent, and help to prevent rear-end swing-out, making the car easier to control when cornering. The damping control on the car will be fully adjustable, with several different driving modes selectable on the fly. Night vision, lane-assist, active braking, and an advanced cruise control system will also be available.
The 5-Series will have a choice of petrol engines ranging from 180 to 370 hp, and diesel engines that output 180 to 290 hp. One of these options will be the 2.0-liter twin-turbo 204hp four-cylinder found on the 1-Series. From 2011 onward, a mild hybrid may also be available. As seen in the BMW 7-Series Active Hybrid Concept, mild hybrids function by cutting off the engine when the car is coasting, or at a dead stop. Mild hybrids can also assist with power output at higher speeds.
Eventually, we should also see the release of a new M5. This car would likely come with a huge 500+ hp V10, and a dual-clutch transmission.
http://www.worldcarfans.com/9090127....details-emerge
Originally Posted by Jaypod View Post
You sound like my buddies who have AMG's - Slam the gas, slam the brakes...
      01-27-2009, 05:46 PM   #2
-=Hot|Ice=-
Drives: 2013 BMW M3
More:
A class leader since its inception, the 5-series remains a crucial car in BMW's lineup, so there's a great deal of anticipation surrounding the next-generation model. That car is due to arrive late this year for the 2010 model year, and heavily disguised sedan prototypes have already been seen testing around the streets of Munich, as have Touring variants. Today new details have emerged from Germany outlining the car's appearance and features.
Most of the planned changes are just skin-deep. Contrary to some reports that the 5-series would shrug off its controversial exterior for the next generation, the latest news, issuing from Auto Zeitung, reveals that BMW may in fact be embracing the 5-series' polarizing looks, including some influence from the inflammatory CS Concept. This is an odd strategy, however, given that the recently revealed all-new 7-series has moved away from the Bangle-influence flame-surfacing design to a more generally palatable look.
Under the new sheet metal, inclusion of some aspects of the new 7-series' technical upgrades is possible as well. Dynamic Drive active anti-roll bars, four-wheel steering and active dampers could all be part of a higher-end performance package for the executive sedan. Some safety features, such as the night-vision system, lane departure warning and active brake assist are likely to make the migration to the 5-series as well.
BMW will also continue with its new found love of turbocharging. The 4.4L twin-turbo V8 from the X6 is expected to appear in a range topping model, while more turbo-diesel variants are expected to join the lineup as well. BMW is currently developing its second generation common rail system for its diesel powerplants, which operate at greater pressure for improved performance. In Europe, a 204hp (152kW) 2.0L twin-turbo four-cylinder diesel engine is also likely to be included, but isn't expected to hop the pond to the U.S. Eventually, hybrid versions will also be on the table, though possibly not until a mid-cycle refresh several years after the new car's debut.
The transmission systems will include a six-speed manual and a six-speed Steptronic semi-auto gearbox, however a new eight-speed unit from ZF is also expected to be available. Coming in towards the end of 2010 will be the next-generation M5 sporting a larger displacement 5.5L V10 and possibly forced induction for extra power. Later in 2011, expect the inclusion of stop-start technology for reduced emissions and improved fuel economy in the less performance-oriented models.
Performance of all models will be improved thanks to the extensive use of lightweight materials including carbon-fiber and aluminum. The car’s construction will be a hybrid of an aluminum spaceframe for the front section, and a traditional steel monocoque for the passenger compartment and rear. This will ensure a favorable front-to-rear weight distribution and improved handling. Up front will be an independent suspension with MacPherson struts, with a multi-link layout for the rear. High-performance models will include carbon-fiber body panels to shed even more weight.
Inside, the car will have a more spacious interior, especially for rear-seat passengers, while the center console will be oriented more towards the driver and run an updated version of iDrive. Headroom will be similar to the current model, despite a shorter roof for the new car, while trunk volume will grow to 550L. Wheel sizes will range from 17, 18 and 19in, and a new electrohydraulic brake system will also be added, which will improve braking distances and stability.
http://www.motorauthority.com/previe...-5-series.html
      01-27-2009, 10:34 PM   #3
venom7777
Drives: BMW 328xi
Good stuff, thanks for posting this!
      01-28-2009, 09:40 PM   #4
RT8_M3
drives a BMW
RT8_M3's Avatar
Drives: e46 M3/F10 535i/e93 335i
+1.
Can't wait til they reveal more of the car.
-2oo3 AW E46 M3
-2o11 SG F10 535i 6MT
-2o12 AW E93 335i
